New seat for a Ural Tub
Discussion in 'Hacks' started by Melrone, Nov 30, 2011.
  1. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    I'm asking for some help from you Ural owners.I need to replace the seat in my tub.The stock seat is junk,my wife has some major back issues.So heres what I'm wondering is there a car seat that will work or will that shitty platform is good enough to have one built.Lets see them..Need some ideas
  2. Tarka
    Tarka Strangely strange. Oddly normal.
    May 10, 2007
    2,870
    Across the pond.
    Not tried any car seats although one could be fitted,I`m sure.
    The stock seat pads just pull out without any tools needed.
    There should be a pull loop at the back of the base pad,tucked in just under the bottom of the back pad....pull this loop to dislodge the rear of the base pad and then pivot the pad forwards and upwards to let the metal tang come out of the hole in the sidecar floor.
    Then push the back pad down to let the two metal prongs clear the inner flange of the sidecar body and remove the back pad.
    You`ve then got a clear view of the area available for a car seat which you can measure up.
    Only this last weekend,my girlfriend and I removed the seat pads from my 650 because it was feeling more 'squashy' and less supportive than my 750 (which is 4 years younger anyway).
    We found that the thin wooden base of the base pad had rotten with damp so we stripped the cover and foam off....I then made a new base panel from thicker wood and she remade the seats with new covers.
    The foam on mine was okay,so we re-used it.....but a firmer or more supportive seat could be made by using high density foam or by sending the stock units to an upholsterer/bike seat maker to get same size pads which refit easily but with custom padding on them.
  3. usgser
    usgser Long timer
    Nov 6, 2005
    3,580
    Westside WA
    On the Soviet Steeds forum a member Rich Maund makes custom hack seats for Urals. He also makes a custom tonneau cover that will fit over the higher back of the custom seat. He's got a good reputation for quality work, it'd be worth checking him out.
  4. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    I've had the stock seat out once,but what I'm kind of looking for is a automive seat with lumbar support that will fit.Its a good winter project..Wifes back is a mess so this is a priority..We want to ride to the RA Rally in Colorado.
  5. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,868
    I have looked into this and was not able to find any automotive seats that were not to wide to fit in the body.
    The current Ural seats are not all that bad, Early ones suck! they were stuffed with raw cotton over springs if you have an early one just going to a current one would help. The "deluxe" seat Ural has I found it to be not as good to sit on then the stock Ural seat.
    It might be possible to mount an automotive seat in our M72DX body being 4 inches wider. We have not looked into it as we make our own seats.
    Jay G
    DMC sidecars
    www.dmcsidecars.com
    866-638-1793
  6. Farmer1949
    Farmer1949 Out standing in his field
    Jun 30, 2007
    218
    Galt, CA
    Hannigan puts a seat in their cars that is an auto style bucket seat. It reclines, can have a head rest, the top folds down and it slides on two rails. Might be worth a look. The one I have, in a Hannigan Classic, has no lumbar support but maybe it is possible to add it?
    Just a thought.
  7. Sidecardoug
    Sidecardoug Pleasantly pleasing
    Dec 19, 2002
    1,794
    Raincity, Warshington
    I have one of Rich's seats in my hack and the monkeys like it. It's heated too
    Rich Maund is a great guy and does a lot of Ural work
  8. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    Well I got really do something right.Wife went to the doctor yesterday after the MRI and its not good,he said she's not suppose to ride.But being the typical Jewish momma she is, she the dotor she'll quit when shes dead..Now the GSA/Ural has new Works suspenion the ride is smooth.its time to get serious.I'll do some measuring for a junk yard seat and call a couple of seat makers to see what to do.I'm up for ideals......
    #8
  9. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    Hers a hint to all you Ural owners.I've been playing around doing the measurements and hitting a couple of bone yards.I found a Kia Reo seat will fit by measurement only.I'm going next week and getting the seat.To see if it really fits.I'll keep this posted and maybe even get some pictures out...Let you know how oit works:deal
    #9
  10. DRcruiser
    DRcruiser Tourin and Scootin
    Jun 1, 2006
    51
    Akron, Ohio
    What about the after market jeep or the racing seats. Most are light weight and many have a somewhat universal mount system.
    #10
  11. BeeMaa
    BeeMaa Submariner
    Feb 13, 2011
    1,106
    NoVA
    +1
    I have owned Jeeps and that is exactly what I was thinking while reading this.
    Actually thinking of looking into this for my rig too.
    #11
  12. KneeDrachen
    KneeDrachen Long timer
    Jul 23, 2006
    2,742
    NJ
    +2. SWMBO is in need of spinal surgery. I was flipping through some of my Jeep catalogs (had 2 TJs) and may have found a few possibilities. And the winches!!!!!
    #12
  13. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    Never thought about Jeep seats,racing seats don't have the back support and comfort we are looking for.Looked at a seat for bass boats.They were waterproof and comfortable,but no lumbar support.Thats why I've been looking at car seats..A buddy of mine has a shit load of Jeep parts might go pay him a visit.Thanks...:lol3
    #13
  14. KneeDrachen
    Jul 23, 2006
    2,742
    NJ
    If you check out Quadratec or "The Essentials" catalogs online, you should see some seats with lumbar support for Jeeps.
    #14
  15. planzman
    planzman commie bike rider
    Aug 28, 2006
    696
    Middle Ga
    when you finally get the seat to fit and if (IF) you are having it recovered, why not ad some heating pads like on the BMW heated seats, something both for the bottom and lower back areas, not just to keep warm, but also to be theraputic (is that spelled right?).
    cheers
    #15
