junk items from harbor freight
Discussion in 'The Garage' started by stainlesscycle, Mar 17, 2010.
  1. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    the other thread pretty much extolls the virtues of some harbor freight items.. and i think harbor freight serves a purpose, but some things are just bad news....
    this thread is for items that broke pretty much instantaneously...
    6" safety wire pliers : broke on first use.
    handheld rivet gun: broke on first use. (i just needed the nosepieces anyways..)
    dust collector (get the extended warranty!!!! i've been through 3 of these units in 2 years....they don't grease the motor bearings...they really start squealing in cold weather. then they fail. it's easier to return then to tear it apart and grease the bearings. i've done both...)
  2. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,737
    VA Beach, VA
    I bought one of the orange square base palm sanders. What a total POS!!!
  3. ~AJ~
    ~AJ~ Adventure pooper
    Sep 16, 2008
    224
    Sacramento, CA
    Torque wrench. Broke within a month.
  4. B02S4
    B02S4 Aye
    Mar 9, 2009
    2,619
    HFT should make good on the warranty...
  5. victor441
    victor441 Long timer
    Jul 27, 2009
    4,028
    Sonoma Co., Calif.
    bought a router speed control last year, only lasted about 2 months before dying...,
  6. Bentley
    Bentley Wannabe Adventurer
    Jan 15, 2003
    237
    Austin
    Floor jack. Lasted about 1 year - roughly $6 per lift.
    B
  7. duck
    duck Banned
    Mar 19, 2004
    10,403
    Seattle (Berkeley with rain)
    The $3.99 battery tender.
    Their zip-ties are cheap too. They break when you're installing them and try to pull them even halfway tight. They get probably get shipped over here because even the Chinese won't use them.
  8. Skippii
    Skippii Did you eat my Zinger???
    May 11, 2008
    6,705
    Richmond, Va
    Great. I bought one of those yesterday. Haven't used it. It was for a friend.
    #8
  9. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    20,594
    New(er) Mexico
    Rubber strap wrench. Snapped the rubber off at the handle while trying to loosen a stubborn oil filter. I was pissed for a minute then remember the damn thing cost like $2 so fuck it.
    #9
  10. bete
    bete misguided adventurer
    Mar 22, 2008
    1,132
    kansas Flint Hills
    Some friend you are. :D . bete.
    #10
  11. MiamiMotorcyclist
    MiamiMotorcyclist used to be -MiamiUly
    Jul 11, 2007
    10,390
    Miami, Fl.
    Hmmmm.... cheap slide hammer broke one of it's attachments real quickly.
    I'm sure there have been other fails.
    I did try that plastic welder long ago and had no luck with that.
    All and all I've done okay with HF though.
    #11
  12. racermdub
    racermdub Adventurer
    Jun 7, 2008
    94
    Abductor pollicis brevis
    Must be that I've gotten lucky, I've used the safety wire pliers and $3.99 battery tender without fail for 4 years now.
    #12
  13. P B G
    P B G Long timer
    Mar 7, 2008
    10,004
    Greater Chicago
    Craftsmen's is no better, they just don't work on oil filters what so ever, ok for a stuck hose spigot.
    #13
  14. Tacodog
    Tacodog Old Guy
    Sep 21, 2008
    44
    Tucson Arizona USA
    Harbor Freight = disposable tools. If you want something to last a lifetime, buy elsewhere. If you need a tool for a one time deal, then Harbor Freight is mostly worth what you pay. :1drink
    #14
  15. ridewestKTM
    ridewestKTM Long timer
    Jun 7, 2007
    2,183
    Mesquite NV
    I bought a Harbor Freight End Mill - just love it
    Bought a cutoff band saw and it's not great but I'm happy with it.
    Press plates -havent broken or bent
    misc lathe tools - just fine
    #15
  16. Green427
    Green427 Comfortably Dumb
    Oct 11, 2007
    1,091
    Cooch's Bridge Battlefield
    HF's quick grips. After sitting in my garage for 3 years, I finally used them. Plastic grips snapped easily. All three of them. Plastic became brittle from being stored in cold & hot weather.
    Liquid hand suction pump. Plastic became brittle. Pump would not work after using it to suck antifreeze.
    Automatic wire cutter/stripper. What a cheap piece of shit. Not even worth the sidewalk sale price of $2.99.
    Multifunction tool. Works great for the application, but needs to be whacked with a hammer to keep on running.
    Multimeter. Gotta keep fiddling with the probe connectors to get a reading.
    All their recipro saw blades lasted 10 minutes.
    I've had good luck with their pneumatic nailers, air compressors, power saws, drills, and generators.
    #16
  17. B02S4
    B02S4 Aye
    Mar 9, 2009
    2,619
    #17
  18. DirtyOldMan
    DirtyOldMan Motorsickle enthusiast
    May 2, 2006
    2,838
    Cass Co MO
    4x36 belt disc sander. Burnt up quickly. I don't mean "it got hot and quit in a coupla hrs."
    I mean "within 30 seconds of no load run time it burst into freaking flames!"
    took it back and got another and it did the same thing. Apparently they don't run well when installed sideways.
    #18
  19. swingset
    swingset Got the knack.
    Mar 11, 2008
    12,058
    Austin, TX
    Tried one of the chainsaw sharpening machines. It's not that it broke, it was just so woefully inaccurate and sloppy it would ruin a decent chain with uneven grinding very quickly. Total waste. They took it back, so no harm.
    A $7 hand-file is more accurate and faster with practice, I learned.
    #19
  20. garfield
    garfield Garfield
    Aug 5, 2007
    65
    Santa Barbara/Gaviota, Ca.
    the Rigid copy power pipe threader they sell is junk! gave it away after 2 days of frustration. got the Rigid now, $700. more but it works
    #20
