Yesterday, 06:58 AM
#691 | |
Ninjetter
Oddometer: 70
1) From total stop, balance the bike vertically, put both feet up on the pegs. From that position, if you don't turn the handlebar, the bike will fall to either side. Repeat and verify: the bike has no preferred side to fall onto. 2) From total stop, balance the bike vertically, put both feet up on the pegs. From that position, turn handlebar all the way to the left (full lock), the bike will consistently fall to the left side. Why?: You have moved the CG of the bike left and is now off the line that joins the contact patches of the front and rear tires. That is steering for you, and will work for standing still and for low speeds. 3) Next, let's find out what are those low speeds for which steering works and counter-steering doesn't. Repeat the #2 procedures, but start moving the bike really slowly, using the clutch. If you do it slow enough, the bike keeps leaning onto the left side. Little by little increase that speed, noticing that the tendency to left-lean is less and less as the speed increases. If you control is fine enough, you will find a speed for which the bike stays vertical while it turns. That is the critical speed below which steering works. Why?: The CG of the bike remains left-off the line that joins the contact patches of the front and rear tires, however, the circular movement induces a centrifugal force over the same CG that perfectly compensates for the off-center weight and keeps the bike balanced vertically. 4) Next, let's find out what are the speeds for which steering doesn't work anymore and counter-steering does. Repeat the #2 procedures but keep both feet down sliding over the pavement, but start moving the bike at about the critical speed that we have just found, using the clutch. If you do it fast enough, the bike starts leaning onto the right side (careful here, right foot ready to support the bike and hand ready to clutch-in). Little by little increase that speed, noticing that the tendency to right-lean is more and more as the speed increases. Why?: The CG of the bike remains left-off the line that joins the contact patches of the front and rear tires, however, the circular movement induces a centrifugal force over the same CG that overcomes the off-center weight and rolls the bike to the right. That is counter-steering for you, and will work for any speed above that critical speed that we found earlier. Now, that critical speed will be higher for less dramatic turn angles of the handlebar. This link explains it better than me: http://www.tonyfoale.com/Articles/Balance/BALANCE.htm lnewqban screwed with this post Yesterday at 10:02 AM |
Yesterday, 07:32 AM
#692 |
Chronic Noob
Oddometer: 2,304
You're right anyone could figure that.
Tony Foale probably figured it long ago and has been struggling explain it since. What I want to figure is what changes do I make to increase the speed at which steering still works and / or reduce the speed that countersteering kicks in. I figure trail, fork offset, rake & wheelbase as well as CoG are in play as I've modified those factors chasing other handling characteristics. A marked change in the steering options available was noticed. The 15-25 kph range is interesting as I seem to have both types of steering available. I suspect wheel diameter and tyre width have a bearing on the equation but those are fixed in my application. Thanks for the tip on speed of turning the bars on the srteering mode test. I'm probably auto correcting with body & throttle and haven't factored that in as a variable.
If the Earth is flat why are my tyres round? |
Yesterday, 08:41 AM
#693 | |
Cheesehead Klompen
Oddometer: 154
Oh, and by the way, I do enjoy grinding down the edges of my tucked in riding boots on the curves. Gotta wear off those chicken strips. But,....I also LOVE agrandizing discussions!!! Because, you know, I AM so self important!!
When life throws you a curve,.....lean into it! Andyvh1959 screwed with this post Yesterday at 02:57 PM |
Yesterday, 01:29 PM
#694 | |
Oddometer: 18,067
There is no magic speed when it "kicks in" other than moving/not moving.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
Yesterday, 03:05 PM
#695 |
Cheesehead Klompen
Oddometer: 154
Oh, and this: http://www.superbikeplanet.com/2009/Jan/090102b.htm
Very true, in respect to highly educated people learning to ride even at the basic level we teach in the MSF. I failed my orthopedic surgeon in the MSF BRC he was in. He's a very intelligent, bright educated man. But he simply would not "accept" the method of countersteering. I finally told him NOT to think it, just DO IT, feel it, and use it. Still would not let his brain accept it, and he failed the class on the swerve and evasive manuevers. Later I coached him separately and he eventually got his license and is still riding today, ten years later. But, intuitive? For him, no way.
When life throws you a curve,.....lean into it! |
Yesterday, 05:29 PM
#696 | |
Just Beastly
Oddometer: 6,482
As I said, I aggressively counter steer on my street bike, dirt bike, and supermoto track bike. VERY aggressively. But I believe (and I may be wrong) that you can turn a moto at some very low speed, and not counter steer. Again, I can do track stands on my motorcycle almost as well as I can on my mountain bike, no leaning involved at that speed, same same for .5 mph, 2mph, but I know at 20 mph I am fo sho counter steering. In between is a mystery. Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
Yesterday, 06:24 PM
#697 | |
Oddometer: 82
What does change with speed are the tactile and visual cues that the rider perceives. You don't feel the effect of angular momentum (the product of the front wheel's moment of inertia and its angular speed) on the steering at slow speeds because those forces are speed dependent. As you go faster (the rotational speed of the wheel increases) the angular momentum increases. As the rotational speed approaches 0.0 mph, the angular momentum approaches zero (0). So the sensation of the steering being stiff at speed goes away as you slow down until the only forces left are everything except the angular momentum of the spinning front wheel. Bicycles always seem to have "lighter" steering because their front wheels have a lower moment of inertia. But if you could get the bicycle going fast enough, you'd feel the same "stiffening" of the steering operating as you do on a moto. The same is true relative to trail-induced front wheel self-centering because those forces are speed and trail dependent. As the speeds go down the forces approach zero. As you slow down the required movement of the CoG as well as the angle of lean required for turning are reduced as well. Those requirements are still present they are just very small as the speeds approach zero. Since countersteering is only about controlling the relative location of the CoG in preparation for a lean into a turn, the sensations that we feel approach zero as the speeds decrease. But the physics remain and are still operating even if we cannot "feel" them at slow speeds. cheers |
Yesterday, 06:27 PM
#698 | |
Oddometer: 82
But that is just one type of learning methodology. The trick to being a good instructor, IMHO, is to assess the student's learning style and deliver the material in a manner that the student can process. Some people learn by doing and talking about it is useless, even counterproductive for them. Others only learn by watching other people perform and nothing but seeing it done will work for them. Other people have to figure it out for themselves and won't even hear the words when someone tries to explain it. There are more types and combinations of learning types than I could list. It's certainly NOT a matter of one-size-fits-all. cheers, |
Yesterday, 08:19 PM
#699 | |
Oddometer: 1,059
Yesterday, 10:26 PM
#700 |
Chronic Noob
Oddometer: 2,304
Did you try it?
Static bike!
Yesterday, 10:30 PM
#701 | |
Chronic Noob
Oddometer: 2,304
Congratulations.
Almost as good as Supershaft. Pretty good average. Well done.
Today, 12:04 AM
#702 | |
Adrenaline Junkie
Oddometer: 102
On the other hand if you look at it from the steering point of view. At one point your were steering in the direction you want to go and at a certain speed you begin to counter-steer in relation to direction. Might have to give him his gold star back.
