Brake Bleeding......why do you......
Discussion in 'GS Boxers' started by CHOPPASTYLE, Sep 8, 2011.
  1. CHOPPASTYLE
    CHOPPASTYLE Been here awhile
    May 20, 2009
    303
    San Antonio, TX (Heart of the Hill Country!)
    Howdy,
    I was watching Jim's video about brake bleeding. Why do you have to remove the front brake calipers to bleed the brakes? You don't have to remove the rear....... Could i just stick a wooden skewer in between the brake pads?
    Thanks,
    Choppastyle
  2. GoFar
    GoFar My butt hurts.
    Aug 3, 2004
    1,003
    Republic of Texas
    I suppose you could, but the BEST WAY to get the nasty old brake fluid out of the calipers is to push those pistons ALL THE WAY back and keep them there while you cycle new fluid through. Tough to do without removing them. It only takes what, 2 minutes to remove and another two to refit?
  3. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    It is not 100% necessary, but you leave the dirtiest fluid in the pistons if you do not push them in all the way. Some never do it.
    You could try to push a wedge past the pads beside the rotor, but it would be much harder since the gap is very small there.
    Jim :brow
  4. N1SP
    N1SP Roadwarrior
    Dec 1, 2007
    48
    Mt Airy, MD
    If you use a vacuum style bleeder powered by an air compressor it'll SUCK THEM back for you.
    Mine does.:clap
    Chris
  5. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    Do you have the servo-ABS? I wouldn't use a vacuum pump on the servo-ABS.
    Jim :brow
  6. N1SP
    N1SP Roadwarrior
    Dec 1, 2007
    48
    Mt Airy, MD
    Nope! Just ABS.
    Chris
