Why won't my Garmin GPS V acquire satellites?
Discussion in 'Mapping & Navigation' started by bluegroove, Mar 23, 2012.
  1. bluegroove
    bluegroove Motorcycle junkie
    Feb 24, 2008
    637
    Sacramento, CA
    It just won't acquire at all anymore. It does everything else, all the screens and menus work. no satellites... grrrr..
    I took off the antenna to look and the connector looks fine.
    Any ideas?
  2. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,564
    Near Ottawa, ON, Canada
    Did you try updating the software on the unit? That would be the first thing to try.
  3. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,630
    Central Ohio
    If updating doesn't do any good, the next step would be to open up the case to see if something is disconnected inside. Just remove the antenna nut, take out the screws, and gently pry the case halves apart. Not that difficult, and may be an easy fix.
  4. bluegroove
    Feb 24, 2008
    637
    Sacramento, CA
    hmm... it never ocurred to me that Garmin might have an update for my old unit. guess I'll take a look. and take it apart. thanks
  5. gosling1
    gosling1 Been here awhile
    Jan 30, 2006
    303
    That 3rd World Country know as South Carolina
    Try turning it on while holding the power button and the "zoom out" button simultaneously - this is supposed to do a "cold-boot" of the unit - I had to do this in the past a few times when it wouldn't acquire the satellites upon boot-up.
    Because it is a "cold-boot", it will take longer to obtain a 3-D fix since it's starting from scratch...hth
  6. mcnut
    mcnut Long timer Supporter
    Apr 26, 2006
    1,812
    Bakersfield CA
    Agree that you should be running the latest firmware (ver 2.60, Oct 30,2008). Might consider a hard reset, unfortunately I don't remember how.
    I have seen the antenna fail internally with no outwardly visible signs.
    Bruce
  7. bluegroove
    Feb 24, 2008
    637
    Sacramento, CA
    woo hoo! I just did the cold boot and it works!! super easy! thanks a million! I was reluctantly thinking I was gonna have to buy a new one.
  8. bluegroove
    Feb 24, 2008
    637
    Sacramento, CA
    how do i find out what firmware version i have? I'm wandering around in the menus with no luck
    will it run faster with the latest?
    #8
  9. bluegroove
    Feb 24, 2008
    637
    Sacramento, CA
    will updating the firmware wipeout all my settings?
    #9
  10. Emmbeedee
    Mar 19, 2008
    11,564
    I don't think so, but it's been years since I've owned a V. But even if it does, is that too high a price to pay if it fixes it? And if it doesn't work right now, what good do the settings do? :wink:
    #10
