How do you keep the Ram X-Grip from wobbling?
Discussion in 'Equipment' started by zeeede, Jun 2, 2014.
  1. zeeede
    zeeede Long timer
    Mar 6, 2012
    1,158
    When I have my phone in a Ram X-Grip mount, it has a little bit of free play (maybe 10 degrees each way?). I use the phone for navigation, and it's kind of annoying always looking at it tilted slightly one way or another. Is there any way to lock it in place and prevent that wobble?
  2. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    6,396
    San Bernardino, CA
    I noticed that it wobbles one way more than the other. Position it so that the wobble is already maxed out.
    flyaway likes this.
  3. worwig
    worwig Long timer
    Nov 30, 2009
    2,143
    Hog Mountain
    I fixed mine.
    I put it in the car. Damn thing was annoying.
    I only use a RAM Universal Finger Grip mount on the motorcycle. It also protects the back side of the phone/camera lens better.
  4. bwringer
    bwringer Gimpy, Yet Alacritous
    Jan 22, 2008
    4,203
    Indianapolis
  5. zeeede
    zeeede Long timer
    Mar 6, 2012
    1,158
    Sucks. I went with the X-grip because of the way everyone raved about them here on ADV. I ended up buying 3... one for each motorcycle and one for the bicycle.
    I hope someone can recommend a fix before I end up having to spend another $50 on phone holders.
  6. danisOTR
    danisOTR Living Life on the Road
    Apr 13, 2007
    1,239
    Traveling
    Funny I just mounted mine last night and discovered the wobble issue also. I used a strong rubber band and wrapped it around the ram handle and the ram mount handle on the opposite side. I tested it this morning for the first time and it worked fine.
    Sent from my iPad using Tapatalk
  7. Kickstand Down
    Kickstand Down Been here awhile
    May 29, 2014
    378
    Arkansas
    I've never used the X grip, but I can attest to the finger grip being rock solid. As someone else said, it also takes the bugs instead of the phone.
  8. seatec
    seatec Dutch Transplant
    Jan 17, 2006
    941
    Clearwater
    Buy an Otterbox Defender. It has a great case but more importantly , it has a solid belt clip. I took the belt clip and drilled the clip part and bolted on a ram mount. Solid as a rock!
    #8
  9. zeeede
    zeeede Long timer
    Mar 6, 2012
    1,158
    I keep my phone in a case similar to the Otterbox Defender all the time. I don't want a ram ball on the back because that would make it very difficult to pocket carry.
    I liked the idea of the X-grip, but in practice, I don't like the wobble and I don't like the fact that I can't mount/unmount the phone one-handed.
    How is the finger grip for one-handed mount/unmount?
    #9
  10. zeeede
    zeeede Long timer
    Mar 6, 2012
    1,158
    I'll try this on my ride home today. Thanks!
    #10
  11. worwig
    worwig Long timer
    Nov 30, 2009
    2,143
    Hog Mountain
    You can definitely unmount it from the finger grip single handed. I suspect you could also mount it single handed. But I usually flex the fingers apart a bit with one hand and slip in the phone with the other hand. I can tell it is secured that way.
    #11
  12. Kickstand Down
    May 29, 2014
    378
    Arkansas
    It may depend on your phone and how tight the various finger lengths you choose are. I use the mediums on a Galaxy s3, and I one hand on and off. Put one side in and push the second past the fingers.
    I did find that the rubber gripper things they include are useless and make it very difficult to get a phone in the thing. Luckily they are optional. Side note, if the fingers line up with the volume buttons on the phone, put that side down first or you'll blast or mute your music when it pushes past the fingers lol.
    #12
  13. WoodButcher
    WoodButcher Long timer
    Sep 17, 2004
    2,398
    Austin, TX
    #13
  14. LouDiamond
    LouDiamond Adventurer
    Jul 17, 2013
    83
    that's odd, i've used mine for a year now and have never really gotten any wobble. i wonder if it's a matter of where i mounted it (on my bars w/in like 5" from the center vs further out on the bar, closer to the clutch...)
    #14
  15. worwig
    worwig Long timer
    Nov 30, 2009
    2,143
    Hog Mountain
    You may have a small phone. The larger the phone, the looser it is.
    #15
  16. zeeede
    zeeede Long timer
    Mar 6, 2012
    1,158
    Ah... and I have a largish phone (Droid Razr Maxx) in a huge case.
    #16
  17. morgantm
    morgantm Been here awhile
    May 15, 2014
    266
    Bahama, NC
    Ditto. I have 4000 miles on mine and while you can move it around some as long as you position it at the max of the move its never a issue.
    #17
  18. seatec
    Jan 17, 2006
    941
    Clearwater
    Pocket carry? I just unclip the defender case from the belt clip that's mounted to the bike and slide the phone into my pocket
    #18
  19. threadkiller
    threadkiller Long timer
    Jul 29, 2007
    1,823
    Middle Tennessee
    Can you post a picture of the ram mount?
    #19
