CRF230F Mechanical carb question
Discussion in 'Thumpers' started by Pwnzilla, Apr 12, 2011.
  1. Pwnzilla
    Pwnzilla Sexual Tyrannosaurus
    Jan 1, 2009
    230
    I recently modified my '09 CRF230F:
    132 main
    45 pilot
    921 power-up needle
    1.5 turns on mixture screw
    Air box snorkel removed
    FMF Power Core 4
    NoToil air cleaner
    The bike runs great, I can't find any flat spots etc in the rpm band.
    My question:
    If the bike is at idle and you crank the throttle quickly open to mid-full it stalls, or doesn't fire. This only happens off idle, once the engine revs up slightly it takes off and runs fine. I noticed my '05 230F does the same thing. If I turn the idle up to ~1800rpm it helps, but doesn't clear it completely. I have adjusted the fuel screw, tried different needle clip positions and it doesn't change.
    Is this normal due to the mechanical carb versus a CV carb? I never run into the problem when I'm riding. I was just curious if there is a fix or if that's just how it's supposed to be.
  2. NJ-Brett
    NJ-Brett Brett Supporter
    Sep 8, 2010
    14,775
    Southern New Jersey
    Without a pump, they can do that.
    If the carb is small for the motor size and set very rich, it reduces it.
    The cv carb was designed to prevent that and allow the mixture to be more stable without large changes in the air/fuel ratio.
    Pumper carbs seem to be the best of both worlds, great throttle response...
    Then you can set the jets on the lean side to get good mpg and keep the throttle response.
  3. Pwnzilla
    Jan 1, 2009
    230
    That's what I thought. Thank you for your input. I just wanted to confirm that it was normal for this type of carb.
  4. JayDub
    JayDub Havin Fun
    Jul 1, 2007
    147
    Wind Driven, Wyoming
    I know this thread is old but you might need a 48 pilot.
