Auxiliary LED mini light bars!
Discussion in 'Vendors' started by michaelkozera, Apr 6, 2015.
  1. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,437
    calgary
    looking for a powerful yet very durable light bar for your motorbike? look no further, i have created to perfect solution for all us motorbike enthusiasts.
    i mill / build these myself. based in calgary, canada. built to withstand our crazy winters, and strong enough to survive a car crash.
    please help support my kickstarter:
    https://www.kickstarter.com/projects/719210371/bfl-30-mini-light-bar
    or visit my webpage for more info:
    http://lumitrex.ca/
    BFL-30 mini lightbar.
    key features:
    -BF-30 is 30w and produces 3280lm, this output is equivalent to a 200w halogen spotlight!
    -100% water proof, each light bar is "epoxy potted", and pressure washer safe.
    -Thick 8mm polycarbonate scratch resistant lens offers unmatched durability.
    -High quality 6061 aluminum housing for maximum strength and cooling capability.
    -Large cooling fins allow for our mini light bars to be 100% passive cooled, able to operate from -30C to +45C.
    -Extremely shock resistant.
    -Braided input wires for superior durability.
    -Cree Led XM-L2 diodes offer exceptional light output and high efficiency, 1080lm@10w.
    -Custom Lumitrex drivers with a true, "30w" output at the diodes.
    -Hybrid 15° spot optics with 100° total light coverage give the user the best of both words.
    -Quality stainless steel metric screws all around.
    -6061 aluminum C-clamp mounting brackets included.
    Mini light bar specs:
    -Input voltage: 11-24v Amp draw: 2.65A@12v
    -Rated wattage at diodes= 30w
    -Actual wattage draw 32-34w
    -Raw lumens= 3240lm 3x Diodes used are CREE LED XM-L2 with copper back plate Output color of 5500k, also available in 4700k
    -15° spot optics with 100° light coverage
    https://www.youtube.com/watch?v=CSXuaJf1uP8
    https://www.youtube.com/watch?v=P-_4FHU36bA
    https://www.youtube.com/watch?v=hH6Wz9A3zRY
    https://www.youtube.com/watch?v=z-r_8NaxeEk
    thankyou for your support, and PM me if you ahve any questions.
  2. wmfleet2
    wmfleet2 Long timer Supporter
    Oct 17, 2009
    14,549
    york,pa
    $980 dollars ?
  3. rockydog
    rockydog just a guy
    Feb 11, 2007
    1,351
    okieland
    what fare the prices for the models? thanks
  4. 2 SPOT
    2 SPOT bring the rape whistle
    Dec 14, 2005
    7,156
    Payson AZ
    When i look at the kickstarter link. I see one model, $160.
  5. Mr. Canoehead
    Mr. Canoehead Taste Gunnels!
    Apr 16, 2007
    3,625
    Calgary, dreaming of riding the Alps, again
    Nice work. I'm thinking these might bolt up to my GSA crashbars. Just wondering why the cable comes out the back right where the case would bolt to a crashbar? Also, what size are the mounting loops?
  6. genka
    genka Stand with Ukraine
    Mar 25, 2010
    2,141
    Baltimore, MD
    This light is considerably smaller than the others. It is 110x32x84mm instead of the 155x55x100mm of typical Chinese light. Unfortunately it still has simple optics, not very suitable for a road use.
  7. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    160$ CAD each (128usd)
    yup.
    or you can get 2 for 300cad (240usd)
  8. michaelkozera
    Jan 11, 2015
    1,437
    calgary
    ATM they are 20mm in diameter, however i was thinking of changing that to 7/8 to make it more usable to most people.
    the cable can come out where ever the user wants really, just email me and ill custom CNC it for you.
    thanks for your input.
    yes i built and designed these specifically for my crf250l, i wanted small, powerful and durable lights. these are perfect for dual sports.
    as for the optics. i really hated all other lighting options, flood is useless for on road, and even the best spot optics still fall short on-road. so i made a hybrid optics with 15degree spot, i then angled them slightly above parallel to reduce foreground and the output ( for highbeam only) was pretty good.
    these mini light bars are for bush use/ highbeam use only.
    #8
  9. JR356
    JR356 Long timer
    May 4, 2005
    7,062
    Way Northwest
    Belongs in Vendors section.
    JR356
    #9
  10. LocuL
    LocuL Gnarly Steward
    Dec 5, 2006
    3,336
    Denmark - Jutland
    Nice product.
    #10
