Sigutech clutch slave cylinder piston
Discussion in 'Dakar champion (950/990)' started by johnyred, May 24, 2015.
  1. johnyred
    johnyred Johnyred
    Jul 22, 2006
    40
    Greece
    990 Adv 2007
    I have a leaking clutch slave cylinder.
    Changed o-ring once but problem came back.
    Thinking about Sigutech slave cylinder piston.
    http://www.sigutech.com/english/e-knz-kolben/
    Has anyone tried it?
    Is the company still in business?
    Tried to contact them but didnt get any reply.
  2. rattis
    rattis Long timer
    Apr 3, 2010
    5,027
    East of the seas of Kattegat
    Got one works well :clap
  3. roookie1
    roookie1 Long timer
    Jun 15, 2009
    1,364
    Norway
    I have been using a Sigutech slave for the last 20.000 km, no problems..
    To my knowledge, still in business..Well their Fb site looks kinda dead..
  4. brooks
    brooks Been here awhile
    Jul 2, 2006
    457
    Port Angeles
    my stock one went out last year on a trip. fixed with a new oring from carquest and it lasted 5000 more miles than went out again so replaced with a sigutech and love it:D
  5. johnyred
    johnyred Johnyred
    Jul 22, 2006
    40
    Greece
    I did the same.
    Now also looking for a more permanent solution.
  6. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,155
    East Med, Greece
    Could you tell if the cylinder is scored at the inner surface, or the piston is cracked close to the nipple?
  7. johnyred
    johnyred Johnyred
    Jul 22, 2006
    40
    Greece
    All seem ok.
    Guess the piston some times gets little side ways and thus allowing oil to leak.
    This why I am looking for the option to just change the piston and not the entire slave cylinder.
    Havent found someone else selling just the piston and Sigutech seems out of bussiness.
  8. brooks
    Jul 2, 2006
    457
    Port Angeles
    my piston was scored cleaned up with a little emery cloth and put a new oring in so if anyone ever needs one in a emergency i could send it to them.
    #8
  9. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,155
    East Med, Greece
    my guess is it got scored contacting the cylinder surface. That means the cylinder is also scored. Orings cannot seal a scored cylinder, they will fail in a short time.
    New cylinder needed.
    My $0.02
    Cheers.
    #9
  10. johnyred
    johnyred Johnyred
    Jul 22, 2006
    40
    Greece
    I wont disagree. Most probably you are right.
    Just thought i could take my chances since there is big difference in price.
    Seems there is no such option since Sigutech seems out of business and no one else makes just the piston.
    So there is just Oberon for the whole cylinder slave.
    #10
  11. tommytiger
    tommytiger Been here awhile
    Jun 25, 2005
    273
    somewhere
    have my sigutech on my second LC8 now for total 40.000 km without problems
    #11
  12. wsmc99
    wsmc99 Been here awhile
    Jan 9, 2004
    585
    SD, CA.
    Mine went "out" the other day.
    Checked o-ring: Fine
    Piston: Fine
    Hit the barrel with 2000 grit, siliconed the o-ring and re-installed.
    Went to bleed it and the line nut under the bleeder moved with the bleeder.
    Snugged it down, bled, fine!
    Sometimes it's the details.
    #12
  13. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,155
    East Med, Greece
    You can copy it at a workshop. The sealing is accomplished with the oring, so no need for super smooth surfaces. If the piston is the faulty part, it isn't too expensive to fabricate one on lathe. Just keep the bottom of the bearing ball slightly shallower (1mm) to avoid cracking of the piston.
    Cheers.
    #13
  14. cow
    cow SprMoto
    Jun 23, 2016
    12
    Felton, Santa Cruz Mts. Ca
    just searched 'sigutech' and found the webpage, but only in german. Couldn't find an english page... want one for my 950sm. still searching, tho
    #14
  15. FriedDuck
    FriedDuck Why die all tensed up?
    Jun 6, 2004
    534
    Atlanta, GA
    I bought my piston from Sigutech's german site. Just used Google translate to handle the communication and everything went smoothly. This wasn't recent, but still.
    #15
  16. lukylaci
    lukylaci Adventurer
    Sep 7, 2014
    40
    Hungary
    +1 for Sigutech, quality product and do the job.
    #16
  17. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,155
    East Med, Greece
    It was cheaper also, but out not in business any more??
    #17
  18. Marco SiguTECH
    Marco SiguTECH n00b
    Dec 13, 2016
    5
    #18
  19. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    5,095
    Toronto Canada
    Is there a North American source for Sigutech?
    #19
  20. alongat
    alongat Fesh Fesh
    Jan 20, 2010
    5,095
    Toronto Canada
    I've heard very good things about the Sigutech unit from many RC8 users. I just don't want to buy something in Europe and pay a fortune for shipping, currency exchange, VAT (that's 20% alone if they don't remove it) plus my own Canadian customs duties.
    #20
