990 fuel consumption
Discussion in 'Dakar champion (950/990)' started by paleface, Aug 7, 2010.
  1. paleface
    paleface Adventurer
    Dec 22, 2008
    14
    NW NC
    very weird, today i rode my 2007 990 and the fuel light came on at 95 miles. i've been getting 160+ on a tank in the past. just changed the oil today. i noticed the bike ran better today than ever. it has 17k on it,valves??
  2. boxermoose
    boxermoose Regressive airhead Supporter
    Sep 18, 2003
    3,894
    Baton Rouge Eh!
    make sure:D both take valves are open
  3. paleface
    paleface Adventurer
    Dec 22, 2008
    14
    NW NC
    Thanks boxer, they weren't.
  4. Gimme 2
    Gimme 2 wheels , with nobs
    Mar 29, 2009
    2,867
    Samsonvale
    That's a great way to find out your range , turn one tap off and let it run out .
    you should have double the range then.
  5. 950TRANSALP
    950TRANSALP Been here awhile
    Apr 15, 2005
    795
    Jackson , Wyoming
    The fuel pump takes up quite a bit of space .
  6. viola-tor
    viola-tor Needs to ride!
    Feb 27, 2008
    2,075
    Rockies. Freakin' Rockies.
    Oh man, I've actually seen the fuel light come on at 100mi under city driving conditions (with both tanks open, '07 990). BUT, I've also seen the fuel light come on at 170 mi cruising across Wyoming... Just depends on the conditions I guess. Having all the gas turned on def helps, but lower gearing hurts... Until you twist that throttle! :super
  7. Gimme 2
    Mar 29, 2009
    2,867
    Samsonvale
    Maybe 250 mls if yr lucky !:lol3
  8. crashmaster
    crashmaster ow, my balls!
    Mar 9, 2007
    5,566
    Alaska
    Yeah, that pump doesnt take up much space at all. I would say 250 mls is too high, probably a lot less.
    With the injected bikes fuel consumption will be all over the board depending on conditions. I can get as low as 30 mph near sea level pounding the throttle in sand and rock, or I have gotten 56 mpg cruising along near 4000 meters elevation.
    #8
  9. skier
    skier genius or insanity?
    Jun 6, 2007
    343
    Durango/Silverton, Colorado
    They definitely like elevation. I rode the Durango-Dolores-Rico-Telluride-Ridgeway-Silverton loop a week ago in some scattered showers and got 46 mpg without ever using 6th gear.
    #9
  10. Gimme 2
    Mar 29, 2009
    2,867
    Samsonvale
    The best i'm getting atm is 330 k's per 22 liters the worst 250
    Fuel type makes a difference.
    I rekon if i could sit on 100 kph i'd get 350 maybe more?
    #10
  11. Night Falcon
    Night Falcon Previous Rider
    Dec 25, 2008
    10,821
    New Zealand
    I've had 370ks before I got to gas station with about half litre left...long straits crusing at 120klm tail wind :D
    #11
  12. Gimme 2
    Mar 29, 2009
    2,867
    Samsonvale
    I ran out of fuel like that once , on the Nullabour wind going against me:deal
    #12
  13. KatoomDownUnder
    KatoomDownUnder Safer off a horse than on
    Feb 21, 2006
    1,011
    North of the Parramatta river
    I'm lucky to get 200 around Shitney before the reserve light comes on but on the highway I'll get about 300 odd.
    It's apparently all in the wrist :lol3
    #13
  14. rean1mator
    rean1mator Been here awhile
    Aug 24, 2008
    179
    my 990 varies in mpg more than any bike i've ever owned. all depends on whyat type of riding i'm doing. in lots of stop and go riding i've gotten as little as 90mile before light. in mostly highway as much as 160miles before light. probably sumething to do with teh crappy fi at the lower rpms on the bike.
    #14
  15. 950TRANSALP
    Apr 15, 2005
    795
    Jackson , Wyoming
    I thought it was much different , sorry .
    A friend of mines 990 ran out of gas before my fuel light came on my 950 .
    We had maxed out our tanks because we knew the fuel stops in western Montana were spaced out .
    #15
  16. Gimme 2
    Mar 29, 2009
    2,867
    Samsonvale
    Has he got mapping pipes etc, and is your's standard?
    #16
  17. 950TRANSALP
    Apr 15, 2005
    795
    Jackson , Wyoming
    Lots o little diff. , mine has a single Jardine with Headwinds prefilter and rejet . While he has Akro's prefilter and stock map .
    No a fair compario ...
    #17
  18. catalina38
    catalina38 Long timer
    Oct 24, 2006
    1,846
    Stingray bay CA.
    2010 990R 1800 mile trip with a good mix of interstate,secondary and dirt roads with side and top case, stock windshield and 908RR front and rear
    43mpg overall. A low 37 on interstate at 80ish, high 44mpg secondary roads.
    Stock MAP with FMF mufflers.
    #18
  19. nvdesertrat
    nvdesertrat Nevada Desert Rat
    Sep 23, 2009
    213
    Northern Nevada
    My 2009 990R with Akro's with Akro Map has averaged 40 Mpg the last two trips as well as running around locally.
    #19
  20. K2m
    K2m Long timer
    Feb 27, 2005
    2,262
    Sydney
    I get exactly that with FCR's Sydney commuting. 15 Kpl
    #20
