Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 5.00 average. Display Modes
Old 10-03-2014, 01:03 PM   #751
Countdown
Oddometer: 5,289
Originally Posted by DualDude450 View Post
They are listed in the Tracks file on the GPS unit. I select them and it goes to the screen that gives you the option to Show, Hide, Delete, etc. When I choose Delete nothing happens...they stay there.
I have not spent a lot of time on my 78 and this is a new one to me.
What happens if you try to "Archive" these tracks? It should push them from Current folder to Archive Folder an not visible on he screen.
I would try using File Explorer on your PC. Since it puts GPS into memory mode and PC is in control not GPS firmware that could work
Don't know why Emmbeedee has not commented, he really knows this device. Try PMing him.
Jerry Counts
Countdown is offline   Reply With Quote
Old 10-03-2014, 01:30 PM   #752
DualDude450
DualDude450's Avatar
Oddometer: 13
Thanks Jerry. I will try "archiving" the tracks when I get home this evening and I'll let you know. I will also PM Emmbeedee.
KTM MXC 550 "Smoker"
Yamaha WR450F "Plated"
DualDude450 is offline   Reply With Quote
Old 10-03-2014, 01:42 PM   #753
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,376
No need. I would suggest what Jerry already has. Try Archiving them if they're not already, or "Make Favorite" if they're already in the Archive, to get them into the Track Manager to be deleted.
If that fails, download and run Javawa Device Manager and run a check for bad files, and it'll probably help delete those.
Old 10-09-2014, 01:11 PM   #754
DualDude450
Oddometer: 13
Thumb
I was unable to archive the tracks...I will try the Javawa route this evening when I get home. Thanks.
Old 10-09-2014, 01:28 PM   #755
Countdown
Oddometer: 5,289
Have you tried just using File Explorer on your PC?
That is all I ukse to move tracks into/out of my 78 and also to move from back and forth between Current and Archive folder in 78.
Jerry Counts
HTML code is Off
Times are GMT -7.   It's 06:49 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
