Dedone trail reduce mods1100/ 1150gs
Discussion in 'Hacks' started by davebig, Apr 29, 2012.
  1. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    13,529
    Minnesota
    My welder buddy and I have recently done a Dedone style trail mod by shortening the telelever A-frame and lengthening the lower triple clamp or ball joint mount 3/4" Via Twintwin's suggestion, using a frame and triple clamps from ebay we have built a couple simple jigs, it wouldn't be hard to do a couple more if anyones interested.I don't know how it works as I'm probably 8 wks away from getting a chair.Thanks to Didier and Claude Stanley for there help.DB
    I can't seem to get images uploaded via google plus if anyone wants an image I can email them.DB
    https://picasaweb.google.com/101786199704810033431/Dedone?authuser=0&feat=directlink
  2. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,164
    Your imagination.
    Cool avatar pic ...
    davebig pic's ,
  3. davebig
    Jan 19, 2004
    13,529
    Minnesota
    FRZ 700 Couldn't you have posted the finished ones ? thanks
  4. Oldfatbeerman
    Oldfatbeerman Enroute to a PUB
    Dec 26, 2006
    7,330
    Lake Macquarie , NSW, Australia
    [​IMG][​IMG]
  5. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,164
    Your imagination.
    No "Z" /\ ...
    Still a cool Schnauzer ...
    I could have , but I always like the fab' pic's .
    hot linked from your own account :evil
    fuck ... 205'ed , at least it stayed in country .
  6. davebig
    Jan 19, 2004
    13,529
    Minnesota
    Discussed what we would need to get to do this mod with welder buddy, if anyone wanted to supply an A frame and ball joint amount it would run about 395.00 and shipping.DB
  7. davebig
    Jan 19, 2004
    13,529
    Minnesota
    Welder buddy and I are just finishing a second A frame shortening lower triple clamp extending mod for another inmate.We had to build a couple new jigs as we cut up our originals that are now part of skid loader mounted log splitter.
    It goes like this shorten A- frame .75"
    Lengthen triple clamp (lower ball joint mount .75"
    We used a r1100s clamp to donate the ball joint mount( cheap on fleabay)
    If we can help you with one just ask, more info here.
    http://www.advrider.com/forums/showthread.php?t=826829
    Onward and forward.DB
  8. davebig
    Jan 19, 2004
    13,529
    Minnesota
    This is the stuff we started with it had been out in the elements for awhile powder coat on a frame in bad shape lots of corrosion on triple tree.
    Done needs a trip to the powder coater, thanks twintwin.DB
    #8
  9. pops
    pops Long timer
    May 15, 2007
    2,009
    Stirling North South Australia
    Nice work on the trail reducer davebig :clap:clap.
    Cheers Ian
    #9
  10. Mr. Cob
    Mr. Cob Howling "Mad", Adventurer
    Aug 8, 2001
    11,846
    Granite Falls, Washington State, USA
    Howdy All,
    From what I understand and please correct me if I am wrong, THIS steering mod does NOT cause the front end to drop. The steering mod that is on my rig has caused the front end to drop at least 2.5-3 inches, it steers great but it now dives when going into corners at speed especially when I have a passenger in the hack. Had this mod been available when I had my R1150 GS, rig built I would have opted to go this way.
    #10
  11. davebig
    Jan 19, 2004
    13,529
    Minnesota
    The fork angle and fork remain in the same place, what actually happens is the head angle (non existent steer tube ) the line between the upper and lower ball joint is made steeper.
    Check my thread, pictures and a good diagram in French, http://www.advrider.com/forums/showthread.php?t=826829
    We can fix you up with one allot cheaper than what you have cost, Claude drove it and thought it worked well and it doesn't need a damper.DB
    #11
  12. Mr. Cob
    Aug 8, 2001
    11,846
    Howdy davebig,
    With the money I have tied up in this rig now, I am very reluctant to spend more on it, like I said if this had been available at the time of the build I would have had this done.
    #12
  13. davebig
    Jan 19, 2004
    13,529
    Minnesota
    Cob
    Your the king of the Urilista's, I know exactly what you mean there doesn't seem to be an end to fixing these things and I'm only a beginner its about 400 worth of cutting and welding and used parts.Take care, your onto a worthy project with your quad friend, I've spent a allot of time in hospitals myself.DB
    #13
  14. Mr. Cob
    Aug 8, 2001
    11,846
    Howdy DB,
    Yes I am working on giving Rick a ride, if it all comes to pass it will make us both smile for a long time.
    #14
  15. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    2,169
    Southwest Washington
    Dave,
    Got the parts and they look great. Will get the bearings/bushings out of the a-frame this weekend and then off to get them powder coated.
    Thanks,
    Ron
    #15
  16. Melrone
    Melrone Long timer
    Sep 5, 2009
    1,251
    Cheese Head Country
    You must have Jaays lower tree.Thats the same on mine..And I had the shock also lowered.It did ok but it would be nice to have it lifted a hair..Nice setupy the way.. A hellof alot cheaper..
    #16
  17. Mr. Cob
    Aug 8, 2001
    11,846
    Howdy Melrone,
    Yes, I have Jay's lower tree on my rig. Had I known the front of the rig would drop as much as it did, I think I would have tried the rig without the steering mod first and then have it done if it steered to heavy. As it is now I really like the way the rig handles I just don't care for how low it sits in front. I am thinking real strong about getting a two inch longer shock to mount up front.
    #17
  18. pops
    pops Long timer
    May 15, 2007
    2,009
    Hi Mr Cob.
    I had the same trouble when i made my own trail reducer for the gsa with the standard forks .
    I found that you could put a 15mm spacer on top of the stock shock before you fitted it to the bike as there was room to fit the spacer and still have room for the top nut to fit ,it lifted the front of my bike around 25mm to 30mm .
    Every bit of extra height helps :1drink
    I also think the 2004 front gsa front shock is around 25mm longer with a stronger spring than the gs had .
    Sorry i am real sure on that one .
    It was a while ago :ear
    But after saying all of that I did end up getting a longer wilbers shock with a stronger spring .
    All the best
    Ian
    #18
  19. Mr. Cob
    Aug 8, 2001
    11,846
    Howdy Ian,
    Thanks for the tip, much appreciated mate. :beer
    #19
  20. davebig
    Jan 19, 2004
    13,529
    Minnesota
    How goes it neighbor ? I'm sick to death of this up and down weather. Are you off to Soldiers Grove in the spring ? Have you ever been on the Wild Goose Run.DB
    #20
