Blaze Anti Fog Kit (DON'T BUY IT)
Discussion in 'The Perfect Line and Other Riding Myths' started by mikesova, Feb 8, 2013.
  1. mikesova
    mikesova Michigander
    Apr 30, 2009
    2,304
    Gladwin, Mi
    I was taken, and I want to warn others against the stuff. I went to the Progressive International Motorcycle show in Novi last weekend and a guy offered to clean my glasses with this Blaze stuff. He did, and they looked really good after he cleaned them, then he showed me a visor that was half "blazed" and half not. One side fogged up like crazy over a steam machine and the other side didn't. Hmm , PRETTY SWEET. So I bought a kit for 20 bucks, which included a wax, and a couple bottles, a spray and a dropper. It also included a microfiber cloth. I tried it out today, just tooling around on the quad. The stuff doesn't work. My helmet and glasses fogged up just as bad as they always do. So if you want some really expensive lens cleaner that kind of smells, buy the Blaze stuff. Otherwise, save your money.
    FatherX likes this.
  2. helion42
    helion42 Been here awhile
    Jan 16, 2011
    227
    Salt Lake City, Zion Curtain, UT
    stuff like that has never worked for me. I ended up just getting a FF with a pinlock-ready visor, so you just snap in the second lens and no problems. For goggles, I never used them on the bike, but there's some hi-end snowboard co's that have double-pane lenses that kick ass.
  3. motorat
    motorat Is it raining
    Oct 9, 2007
    2,204
    SW WA
    that is probubly the same crap i bought 5 years ago...only it was blue back then,
    and it didn't work then either.
    other than a pinlock or fog city none of the anti fog stuff worked for me.
    dish soap worked but when i opened my visor and some water ran down the inside of the visor it left some lines.
  4. DAKEZ
    DAKEZ Long timer
    Mar 18, 2007
    19,879
    Begin Op Zoom
  5. Zanotti
    Zanotti Been here awhile
    Apr 8, 2004
    714
    Philly
  6. mikesova
    Apr 30, 2009
    2,304
    Gladwin, Mi
  7. schaffer40
    schaffer40 I look lived in.....
    May 5, 2009
    435
    Rowland Heights Ca.
    The Pinlock on the Neotec works great....but my glasses fog up like a mofo. I have not figured out any fix for that yet.
  8. andmoon
    andmoon Long timer
    Oct 28, 2004
    3,235
    NJ exit 10
    fogpro
    #8
  9. Truckin_Thumper
    Truckin_Thumper low profile
    Jun 28, 2007
    29,548
    Denton,TX
    ever try liquid dish soap? It works and smells OK.
    RainX on the outside will last a good day in the rain, but does work.
    FogX only reduces your wallet weight.
    #9
  10. windmill
    windmill Long timer
    Feb 18, 2008
    6,977
    Kent, Washington State
    So far I haven't found anything that works better then Gillette Foamy shave cream, but it needs to be redone every couple of days.
    #10
  11. der_saeufer
    der_saeufer Пу́тін хуйло́
    Apr 30, 2011
    1,622
    Delhi
    The only thing that's ever worked worth a damn for me is a Pinlock. I tried all manner of things that you apply to plastic and none worked well. The Pinlock stays clear even after 4 hours in pouring rain.
    As for my glasses, I had to switch to wearing contacts all the time. Nothing worked, though keeping the shield cracked worked OK when it wasn't raining. Of course, cracking the shield makes the Pinlock less effective since one thing keeping the Pinlock from fogging is that the inner lens isn't as cold.
    After Seattle and Sacramento winters, I eventually found the foolproof solution to shield fogging: I moved to LA.
    #11
  12. rdwalker
    rdwalker Long timer Supporter
    Jan 3, 2005
    2,640
    The Badlands (of NJ)
    Precisely. Same problem. Neotec Pinlock somewhat OK (not 100%), but glasses - even if plastic - fog up badly.
    #12
  13. Canuman
    Canuman Crusty & Unobliging
    Jun 21, 2008
    4,689
    The Palace of the People, VT
    I had much the same experience. I ended up buying a Fog City insert, as the wipe-on solutions were marginal at best on the visor. The Fog City isn't perfect, but it's better than the other things I've tried.
    However, I wear glasses. They are a problem. I have a couple of solutions that keep the glasses free of fog for a short period, but they require frequent application to have any effect at all, and are quite expensive. Maybe I should move to the high desert. Riding in the rain and cold here is problematic.
    #13
  14. univibe88
    univibe88 Long timer
    Aug 29, 2009
    2,824
    Exiled in Yankeeland
    Same problem here. Oddly my glasses didn't fog on my RF-1000, but they do on my Neotec.
    #14
  15. fast4d
    fast4d Long timer
    Jul 27, 2007
    3,103
    Los Angeles, CA
    they were at motogp (laguna) for a couple years. it was blue then it was orange.
    I got taken for $23 bucks as well.:puke1
    #15
  16. Cerberus83
    Cerberus83 The Wingman
    Feb 4, 2010
    143
    Cleveland, OH
    I was at the IMS in Cleveland a few weeks ago and I did see them doing a demo, but after looking at it a bit closer (esp. the price), I decided not to get it.
    The stuff I use on my visor is the same anti-fog solution I use on my dive mask. The tinny bottle cost maybe $8-$10 (any scuba diving shop will have this), but you only need a small amount such as a size of a eraser on a No2 pencil (it's gel-like so it spreads out easily). You let it sit for some 30 seconds and just rinse it with water. Works great and that small bottle will last you at least a year or two (probably longer depending on your riding conditions).
    There are different sizes, but the one I use is similar to the size of a white-out bottle.
    #16
  17. JustinP
    JustinP Bike Curious
    Jun 19, 2011
    15,654
    Staatsburg NY
    #17
    appliance57 likes this.
  18. univibe88
    Aug 29, 2009
    2,824
    You know you can use spit, right? It's free and works just as well.
    #18
  19. genespleen
    genespleen Been here awhile
    Feb 5, 2010
    186
    mid-Missouri
    #19
  20. ibafran
    ibafran villagidiot
    Apr 16, 2007
    2,520
    chicagoland
    I got suckered (usually I leave my wallet at home as I know that I am an e-z mark) at the Chicago IMS. BUT. I had 'em demo it on my salt encrusted helmet visor on saturday last. Haven't touched the visor since and it hasn't fogged up on my daily commute nor the 45 mile trip to my MC meeting last night. SO. It's werkin for me so far.
    I got sucked into the metal polsh 10 yrs ago. Polishes nice soft pop cans real good. Bike hard cases... hardly any shine. Mother's is way better. Nice to know that the IMS show really gives a shit about what is shilled to bikers. Makes every product/service vendor at the show suspect.
    edit: as noted, product seems to work on the visor. Does not work well on lenses close to my face, glasses & clip-on sunglasses. grrrrrr
    #20
