Rim lock hole
Discussion in 'The Garage' started by lakser, Sep 15, 2013.
  1. lakser
    lakser Been here awhile
    Oct 13, 2012
    156
    Bushwick, Brooklyn NY
    Curious what people are using to cover rim lock holes?
    I am not running a rim locks and I changed my tire with out plugging the hole.
    Can I still cover the hole properly without taking my tire off?
  2. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    Two layers of electrical tape from the inside.
  3. PineyMountainRacing
    PineyMountainRacing Oops....
    Jul 2, 2008
    8,526
    SRQ FL
    I use an aluminum tape made by 3M. I usually put a piece on the inside and 1 on the outside. It's pretty heavy duty, actually made for temporary patch jobs on aircraft skin. I've seen similar products at hardware stores. If I already had the tire mounted I would just put a piece on the outside to keep out sand and water.
  4. kenny61
    kenny61 old and crippled
    Jul 11, 2010
    26,392
    in a drainage ditch
    You have to use rim lock plug adhesive. otherwise the centrifugal force will drive the plug into the tube at high speeds resulting in a blow out. Electrical tape is not strong enough and aluminum tape as stated is only for temporary use:deal
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    12,155
    Anchorage, formerly Spenard (hub of the universe)
    I put a patch of duct tape on the inside and fill the hole with RTV from the outside. no problems in uhhhhh.... 30 plus years or so... don't remember when I did the first one
  6. ZEmann
    ZEmann want to be riding
    Jul 19, 2013
    664
    Arizona
    Kenny needs his to be complete waterproof as He is a submarine biker :lol3
    mine came with a grommet but those got tossed when I added locks
  7. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    10,737
    Southern Illinois USA
    Yamaha part # 90480-10068-00 I think?
  8. MrPulldown
    MrPulldown Long timer
    Aug 18, 2009
    10,734
    Truckee
    Just patched mine this weekend with a chunk of old inner tube held in place by a couple of strips of electrical tape. I would think that just a rim tape would be ok.
    #8
  9. Switchblade315
    Switchblade315 I make people disappear
    Oct 10, 2009
    8,128
    Watching Bridges Burn
    yeah they do make plugs. seen hondas with one rim lock but a place for a second and a plug in it.
    #9
  10. lakser
    Oct 13, 2012
    156
    I am thinking if I need to take the tire off to do this right I might as well put the rim lock back on.
    Thanks for the input.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    #10
  11. kenny61
    Jul 11, 2010
    26,392
    in a drainage ditch
    dude just get the adnesive and do it right the first time:deal
    #11
  12. lakser
    Oct 13, 2012
    156
    unfortunately doing a google search for rim lock plug adhesive, just brings me to this thread :clap so I am not sure what product you are referring to.
    My works schedule right now is not great for getting to any type of shop when they are open, so ordering online is big help for getting things done during odd hours.
    maybe I can run to a few on saturday and see what they have. but if you could link me to what I should be looking for that would me much appreciated.
    #12
  13. MrPulldown
    Aug 18, 2009
    10,734
    Truckee
    I would not sweet it. The stock rim lock hole plug for the DR is just a little rubber plug with no adhesive. The Right vs Wrong on this one is so slight it not even worth sweating over.
    #13
  14. Beezer
    Oct 26, 2004
    12,155
    ya... fill the hole with RTV & put a piece of foil tape over the top. plug it from the inside next tire change. maybe let the air out of the tire to get a good fill
    #14
