Broken Headlight
Discussion in 'GS Boxers' started by CA Dreaming, Jan 31, 2011.
  1. CA Dreaming
    CA Dreaming Been here awhile
    Sep 25, 2002
    811
    Waddell, AZ
    I need to replace the lens (glass portion) of the headlight on my 09 GS.
    Do I have any options other than buying the entire assembly from BMW?
  2. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
  3. rebake
    rebake Long timer
    Jan 4, 2007
    2,906
    West Hartford CT
    Just went through the same thing.New assembly is 417 dollars.When i ordered mine,there were 14 units in the usa.I tried Beemerboneyard and about all the junkyards i could find before buying the new one.Sorry,but i think you are stuck...Ed
  4. GSNoël
    GSNoël Been here awhile
    Nov 29, 2006
    308
    Paris, France
    your insurance doesn't cover broken glasses ?
  5. Tosh Togo
    Tosh Togo Long timer
    Nov 21, 2010
    1,594
    The predicted cost might be less than his deductible, or so close that it's not worth putting a claim in for the small reimbursement. :deal
  6. lhendrik
    lhendrik Putins Puppet
    Dec 10, 2008
    2,983
    Woodbury, CT
    Was it a rock strike on the road? I ask because I have resisted getting one of those $100 headlight guards, but might if I hear that this was caused by an actual rock strike as opposed to running into the back of a garbage truck or something equally clever....:D
  7. CA Dreaming
    Sep 25, 2002
    811
    Waddell, AZ
    Near as I can tell my broken lens was caused by a cheapo lens protector I bought off eBay. I liked the idea of a simple plastic shield that fit between the bezel and the lens, problem is I think the plastic protector placed stress on the edge of the lens causing it to crack.
    In other words, DO NOT TRY TO GET BY CHEAP My $45 headlight protector is going to end up costing me over $400 AND I still have to buy another protector.
    But at least I use genuine BMW oil filters! :)
  8. rebake
    rebake Long timer
    Jan 4, 2007
    2,906
    West Hartford CT
    If it is just cracked without a chance of pieces falling out,i would superglue or epoxy it.I couldn't do that with mine or i would have.Ed
    #8
  9. Semper Fi
    Semper Fi Runs with Scissors
    Jul 14, 2008
    872
    Kingston, NH
    I too have been on the fence for getting a headlight protector - just for my own clarification are you talking about the plastic film you apply to the headlight or are you talking about a plastic shield that is mounted onto the headlight assembly?
    #9
  10. CA Dreaming
    Sep 25, 2002
    811
    Waddell, AZ
    A plastic shield that mounts between the lens and the bezel.
    #10
  11. CA Dreaming
    Sep 25, 2002
    811
    Waddell, AZ
    It's just cracked, so while I need to eventually replace it it's not critical. I may get some of the plastic film that adheres to the lens in hopes it will keep it intact until I can find a used one.
    #11
  12. JurgenB
    JurgenB daily rider
    Mar 11, 2007
    527
    Coloradio
    #12
  13. QED
    QED Been here awhile
    Apr 30, 2007
    361
    North Idaho
    I sure like my Aero Flow. looks good, inexpensive, works, easy to remove.
    #13
  14. MJS
    MJS Long timer
    Dec 23, 2005
    3,647
    On a beach off grid in San Felipe, Baja
    I like the look and convenience of the Cee Baily lens (I had one) but I have seen a lens get broken even with the CB guard in place. It is probably fine for street use but maybe not as much protection as possible on rocky trails.
    I have the TT unit now. More distance between the guard and lens but even that may not be enough. At least I can rationalize the cost that way :lol3
    #14
  15. Semper Fi
    Jul 14, 2008
    872
    Kingston, NH
    Would you mind posting a picture of the damage - so we can see how it occured and potentially helping in selecting a good headlight protector.
    #15
  16. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    I had that one forever. Worked great!
    Jim :brow
    #16
  17. rebake
    rebake Long timer
    Jan 4, 2007
    2,906
    West Hartford CT
    I bought a piece of lexan 18x24 inches for about 7 dollars.Looks like i can make 5 of those with it.I cut the first one with my jigsaw clamped upside down in a vise,then cleaned it up using my dremel tool sander.Attached it to the light with some dual-lock and a zip-tie to oil cooler rail.Ed
    #17
  18. Callisto224
    Callisto224 Long timer
    Jan 5, 2010
    10,695
    Atlanta(ish), GA
    I was just thinking about buying one of these off of fleabay. Sorry this happened to you but thanks for the warning. I won't waste my money!
    #18
  19. Semper Fi
    Jul 14, 2008
    872
    Kingston, NH
    Jim - any issues with light dispersement?
    Looks easy to clean with the velcro.
    I was thinking of the BMW lexan cover, worth it?
    #19
  20. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    No, none at all. It was like it didn't exist. Pop it off and clean it, pop it back on.
    In the sink at the hotel after thirteen straight days on the road.
    I also had an HID for a lot of the miles with no issues.
    Jim :brow
    #20
