Do the 950SE and 950 adventure use the same silencers? Are there any changes to the engine between the two?
I hear the Akros have a different part number for the SE cans. I need to look into this after hearing Infracaninophile's pipes Brian
i installed fmf ti-Qs from an adv on my se, and they fit right on, and the exit angle is correct. i would guess some pipes may have differently angled tips, but cant imagine that they all wouldnt bolt right on skull
Hello skullhat! me too i just installed the Ti Q's on my SE based on your experience they fit perfect!! thx dave
Manny: Ok, I might be wrong. You are quoting the Akro set for the different bikes. I was pointing out that the OEM mufflers on the bikes LOOK different. But, I may be wrong. I have parked my bike right next to JediBri's and the output piece of the bikes LOOK different. T.
The output tip angle is different in stock form, but are interchangable. I looked at the adv & se today.
I installed a set of 950 Adv pipes on my SE as well. It was a direct bolt on If you do a search on here there is an old thread with the part numbers and the diff. which is the case of the akras is just the tips. Noone else even makes pipes for the Se yet as far as my knowledge goes.
