KLR650 Only Thread......
Discussion in 'Thumpers' started by willys, Nov 19, 2011.
  1. Canuman
    Canuman Crusty & Unobliging
    Jun 21, 2008
    4,689
    The Palace of the People, VT
    It would be the wrong decision for sticky mud conditions, but in the loose/damp/slimy/wet conditions here in the Northeast, the Arrowhead superbike low fender mod simply works, especially if you machine some spacers for it as I posted some moons ago. All day ride in the rain, with a clean rad and cooling system, and my toes were dry.
  2. ctb619
    ctb619 n00b
    Feb 3, 2012
    5
    Socal
    Anyone in N. Colorado have an extra inner chain adjuster for a 1st gen? I'm currently in the Fort Collins area but need to get home to California ASAP.
  3. IDRIDR
    IDRIDR Take me to the River
    Jun 16, 2010
    3,306
    Boise
    Dang, that headlight is bright. Couldn't even see the fender!
  4. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    9,788
    Maine, USA
    Make some peg mounts.
    You don't have to mount BOTH peg mounts at the same time unless you want to take a picture showing the difference.
    For me 1.5" down and 1" back made a huge difference.
  5. L-ucky-S-ix
    L-ucky-S-ix Dadgum'd
    Jun 20, 2010
    366
    Fort C, CO
    I sent a PM as I do have whatchya need.
  6. Canuman
    Jun 21, 2008
    4,689
  7. hydrashoks
    hydrashoks Adventurer
    Oct 1, 2012
    47
    Death Valley, CT
    as posted in another KLR thread I started, but looking for advice from the collective...
    SO, i cannot figger why it wont start any way other then in neutral. I havent taken the controls apart, but where it the damn clutch bypass, how does it work, etc....it should from what here is telling me, start in any gear w the cluch pulled in...it doesnt. I also noticed that when i tightened the bark buster, that when the clutch was pulled in, it didnt return all the way out. stupid design. HELP w this if you have spec knowledge, i'm still searching for a factory service manual....where do I double check to see if there is a malfunction here?
    NEXT BIGGER PROBLEM.
    I LOST THE DAMN EXHAUST FROM THE HEAD PIPE BACK ON THE HIGHWAY FRIDAY!!! How the F does this happen?
    I don't even have a full tank of gas thru this...cornering into an on-ramp, it dissapeared...drove it 10mi home w just the head pipe...looked under there, no clamp on the head pipe and apparently there's 2 mount holes on the rider's LHS frame, where it should have been fastened.
    So pissed. i;ve had this bike 2 weeks, 16k on a 05.
    Called the dealer, and the sales manager said that he'd reach out to the boss...no reply. Called them the next day, and he said that he still hadnt heard from the boss, and that the boss would call me Tuesday...obviously loosing an exhaust off a bike they just sold, and almost wiping out the rider isnt a big concern for them...
    Fvcking BS.
    Anyone have any advice on a slip on pipe that doesnt need re jetting? if not, a pipe / jet kit combo?
    Who the F doesnt check this on a bike before they sell it?
  8. Thumper26
    Thumper26 Adventurer
    Jul 22, 2012
    15
    A barrier island in NJ
    Don't know if this will help you, but I thought it was worth sharing just in case:
    http://www.kawasaki-techinfo.net/se...12&view_lang=EN&spec=OC&category=MC&page_no=1
    Thumper26
  9. Canuman
    Jun 21, 2008
    4,689
    You need to do both the clutch switch AND the side-stand switch mod. It will only start in neutral with the side-stand down, even if the clutch mod has been done. Check your side-stand each time you take off! Having one deployed is an easy way to engage in some high-speed soil-sampling.
    There are plenty of aftermarket mufflers out there, from the Tractor Supply mod for about $30 up to full systems that cost as much as the bike. Most offer significant weight savings over stock. Don't expect a muffler to turn the KLR into a race bike. Power gains are minimal.
    I guess the lesson here is that you need to check everything you can on the bike. Obviously the dealer didn't. I'd be making friends with a tube of Loc-Tite. This is more-or-less standard procedure, anyway. It's said you can track a KLR by the fasteners it leaves behind. :evil
    Getting the bark busters not to interfere with the levers is simply a matter of adjusting the bark buster. Many simply clip an inch off the lever. I like the Polisport hand guards, as they haven't interfered with the controls on any of the four bikes I've put them on.
  10. hydrashoks
    Oct 1, 2012
    47
    Death Valley, CT
    Ok, I need to clarify.
    The stock exhaust is gone. prolly in the woods, starting a fire. I went back and looked for it, but w cars zipping by me on a blind exit ramp, it wasnt the safest place to picnic.
    i'd like to do a new pipe from the head pipe back, as that's what's missing. So i'd need a mid pipe/can. No jetting required if possible. not making a race bike. I have my ZRX for that.
    as for the bark buster, i tightened the screw that went thru the clutch perch that holds the buster on. doing that must squeeze the clutch to the point that it doesnt go back out when pulled in. it isnt a issue of the buster hitting the lever, and im sure as hell not cutting down a short lever to begin with.
    I need direction on these mods. the search function here is poop.
    I dont want to mod the kickstand switch unless I have to. i've seen too many hardley riders eat it by leaving it down.
    I just want a bike I can pull the clutch in, and start it. in any gear.
    and a exhaust pipe. the neighbors would appreciate that.
    TIA
  11. GAS GUY
    GAS GUY MILE EATER
    Jul 27, 2007
    7,677
    Garden City, Michigan
    For the muffler, check out the Leo Vince X3.
    I think I will be trying one of these in the spring.
  12. GAS GUY
    GAS GUY MILE EATER
    Jul 27, 2007
    7,677
    I eliminate the clutch and side stand switch.
    Get some real aluminum barkbusters.
  13. Canuman
    Jun 21, 2008
    4,689
    Yes, "Barkbuster" is a brand name that implies a full-loop aluminum hand-guard. The stock "twig guards" are almost useless for serious protection.
    This is the type of item that works:
    Use Google to search for the electrical mods. There's plenty of information here and on Thumper Talk, and the muffler question has been "exhaustively" discussed!
    Try this:
    http://www.advrider.com/forums/showthread.php?t=611580
  14. nigelcorn
    nigelcorn Wannabe.
    Aug 17, 2007
    1,159
    Las Vegas, NV
    Hey guys. I've had 2 KLR's in the past, and keep trading them for something else, then coming right back.
    Now it's time to come back. I have a pristine PC800 (the KLR of the street bike world) that I'm looking to trade for something like a KLR.
    If you know anyone with a KLR that isn't riding much dirt, send them my way. I'm in the Vegas area, and my bike is realistically worth about $3500, so looking for something with similar value.
  15. Canuman
    Jun 21, 2008
    4,689
    I have a PC800, and my KLR is plenty dirty, but I agree with your assessment! :freaky
  16. KL_ARRR
    KL_ARRR Adventure Piggy
    Oct 24, 2011
    725
    Central NJ
    The green wire looked okay near the counter sprocket. It also happened in the rain when I rode home tonight, so I suspect it could be under the dash. The hunt continues...
  17. y0y02369
    y0y02369 Long timer
    Apr 26, 2011
    1,359
    Bay Area
    It could be just me but i just wouldn't put used tires on a bike but mainly for me becuase i commute on it. I mean just try them out would be my best guess but maybe bring em to a bike shop and ask them...? usually they are friendly and honest enough.
  18. y0y02369
    y0y02369 Long timer
    Apr 26, 2011
    1,359
    Bay Area
    That actually happened word for word for me as well! I was riding home from work and then it went from regular exhaust noise to a very loud noise. Stopped on the side of freeway and noticed it was gone! :ddog
    I got a DG exhaust. SOunds really sick but after 300 miles, back firing started so now need to jet it... cost for kit is 60 bucks but since i do not know how to do it, i gotta pay for mechanic to do it. Shoot me a message if you want pictures... i will try to post some soon.
  19. y0y02369
    y0y02369 Long timer
    Apr 26, 2011
    1,359
    Bay Area
    that'd be exactly what i need! how did you make it??
  20. y0y02369
    y0y02369 Long timer
    Apr 26, 2011
    1,359
    Bay Area
    might have missed it... but what auction site..?
