Clutch Slipping Update
Discussion in 'GS Boxers' started by Ausfahrt, Jun 28, 2015.
  1. Ausfahrt
    Ausfahrt Luftkopf
    Apr 17, 2008
    6,399
    Vermont
    The clutch on my '07 GSA has slipped occasionally and randomly. It always happens at high speed and full throttle but it doesn't do it all the time, only once in a while. I suspect that the common oil leak from the crankcase onto the clutch plate is the culprit.
    So last year I decided to change my oil from Mobil1 15w-50 to Pennzoil 10w-40 high mileage. The high mileage oil supposedly has seal conditioners that can help reduce gasket weeping.
    It seems to be working, I have been trying to induce slippage at high speeds I have not been able to do so. I changed the oil & filter today at 55,000 miles and I know that I'm just buying time until the clutch needs to be replaced but in the meantime I'm riding.:ricky
  2. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,653
    Coronado, CA - KNZY
    Stay close to home.
    These are the types of maintenance gripes that keep me awake at night until they are repaired, to me a bike that has a clutch problem (regardless of the cause) is virtually useless.
    I would only do thing to buy time if I were on the road trying to get home or to a repair shop, otherwise I would fix it at the very first chance I had.
  3. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    Are you certain the clutch is oiled? Why not remove the starter and confirm.
  4. Ausfahrt
    Ausfahrt Luftkopf
    Apr 17, 2008
    6,399
    Vermont
    That is certainly at the top of my "to do" list if the slipping clutch reappears.
  5. nowacuein
    nowacuein iamtioma
    Mar 9, 2013
    133
    NYC
    I might have a similar issue... What are the most obvious symptoms (apart from the nasty burnt clutch smell after high speed riding)?
  6. techgeek
    techgeek International Man of Mystery
    Apr 18, 2006
    189
    Boston & Maine
    I know it sounds stupid but check your hand guards.. they can rotate and depress the clutch lever and cause it to slip.
    It happened frequently enough that BMW actually issued a recall that consisted of sticking alignment stickers inside the hand guards so you could easily see where they should line up.
  7. bikeroz
    bikeroz Long timer
    Oct 18, 2012
    2,514
    Sydney Lower North Shore
    Would removing the starter just allow you to check for oil or would you be able to determine if the clutch is indeed toast?
  8. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,653
    Coronado, CA - KNZY
    You can measure the thickness of the clutch disk with the starter removed.
    Checking the hand-guard for clutch lever interference is actually a darn good idea, especially since the OP is reporting occasional and random slipping.
    #8
  9. bikeroz
    bikeroz Long timer
    Oct 18, 2012
    2,514
    I suppose that is what I'm looking for. The bad news before going the starter remove route.
    Photo is from front of brake lever and above manifold joint.
    #9
  10. calfroper
    calfroper In it to win it.
    Oct 2, 2014
    531
    Rhome, Tx
    This may seem really elementary but worth a look.
    I hade an 1150 with clutch slip random occurrence , it turned out to be simply the hand guard on clutch side had loosened and rotated down enough to sometimes catch the end of the clutch lever preventing it from completely returning.
    Boy was I feeling stupid when I figured it out, and relieved as well
    #10
  11. def
    Feb 28, 2004
    14,308
    Also, as our hydraulic clutches wear, the fluid level in the reservoir rises and if too full, may not allow the clutch to fully engage. Check the clutch fluid reservoir and remove some fluid if too full.
    The brakes are the opposite.
    #11
  12. 99p38a
    99p38a Been here awhile
    Oct 6, 2009
    321
    Michigan
    My 1150 that I put away 3 years ago and rode about 3 hours since then to burn thru the gas and stabil and refresh once a year has had a problem on this years ride and that sounds like this. Need help to determine where to look first.
    I rode an easy 10-15 miles and when I went to downshift it started slipping bad, then thru all gears it felt as if the clutch was pulled in 90%. I tried some other gears and it ended up worse. So now I pull in clutch and everything is good and it shifts fine. I let out clutch and it goes ker clunck chunk etc over and over and does not move.
    I checked my clutch fluid and it was higher than it should be, top of big circle. Bikes not at my house, some I'm stirring up ideas to check when I get to the bike.
    I'll start with fluid, but does it sound like clutch? final drive? My buddy said sounds like noise is coming from back of fd, but symptoms I felt where clutch?
    Experts? I need some help.
    Brian
    #12
