Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 08-09-2014, 05:55 PM   #1
Klaschikart OP
Klaschikart's Avatar
Oddometer: 12
Question HeLp! 2008 KLR650
So (2) months ago I had the problem of only able to run with the Choke on. Took the carb out, cleaned, Seafoamed, New Plug, New Air Filter and New gas. Ran GREAT!
Now I'm back to the same thing. Anyone out there experiencing this problem? I ride every day. Never sits for longer than the night or while @ work. Just took the carb off again. Did the same routine and this time no improvement.
Klaschikart is offline   Reply With Quote
Old 08-09-2014, 10:05 PM   #2
peterman
cop magnet
peterman's Avatar
Oddometer: 13,788
look for an older model KLR,,like pre 2006,,all yer problems will be solved.
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 08-10-2014, 06:51 AM   #3
doggitter
Oddometer: 2,073
Sure helps to actually find the problem when you dig into a symptom, instead of just doing work that should fix it.
So many rides, so little time.
Loren, somewhere on a DR350SE
doggitter is offline   Reply With Quote
Old 08-10-2014, 06:51 AM   #4
Idarider
R1200GS
Idarider's Avatar
Oddometer: 2,075
Is there a screen in the fuel valve that might have junk on it ? I ad that happen from a rusty gas can.
R1200GS, DR350SE
Idarider is offline   Reply With Quote
Old 08-10-2014, 08:41 AM   #5
WB-PDX
WB-PDX's Avatar
Oddometer: 3,744
Add a in-line fuel filter this time when you clean the carb. They sell little generic ones at Cycle Gear for $3. You can also find them sometimes at O'Riely in the lawnmower section.
It won't happen again.
This is classic "My pilot/idle jet is getting clogged."
WB-PDX is offline   Reply With Quote
Old 08-10-2014, 10:35 AM   #6
Klaschikart OP
Oddometer: 12
Saved by the little Fuel Filter
Thanks everyone! I thought I did a thorough job yesterday, but I guess not. Took the carb apart again this morning. Soaked, cleaned, compressed air and added a 3rd #40 washer to the needle. Went and got a fuel filter and Presto!! She's running like brand new again!!
Thank you "WB-PDX" for the tip!
And "Peterman"....I will not go to a pre 2006. They have their problems as well. Been there Done that!
Old 08-10-2014, 10:55 AM   #7
Sliverpicker
Sliverpicker's Avatar
Oddometer: 171
One thing you might consider is trash the vacuum petcock and install a manual one. Read up on those vacuum petcocks------I hate em ! I have had 2 motors fill up with fuel due to those things.
Sliverpicker is offline   Reply With Quote
Times are GMT -7.   It's 05:57 AM.
