Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 09-01-2014, 08:12 AM   #1
Guano11 OP
Half Decaf
Guano11's Avatar
Oddometer: 1,276
Toyota Mechanic Recommendations, Renton?
My '96 RAV4 needs a clutch job: 2WD, 5spd, 200K miles, good mechanical condition overall.
I figured it'd be about a $1000 job, but the 3 estimates I received (2 from reputable service shops, 1 from a dealer) range from $1700 - $1900, plus tax.
Two questions for those in the know:
1. Is $1000 unrealistic for such a job?
2. Any recommended shops or independent mechanics for the service? (I'm relatively new to the area, so was relegated to Google hits, yellow pages & advertisements for the estimates above.) Hoping to find that unadvertised "good guy" & potentially establish a long term automotive relationship.
Appreciate any advice. Extra credit for shops to avoid as well. Post or PM.
Thanks Guys!
Guano11
Time flies like an arrow.
Fruit flies like a banana.
Guano11 is offline   Reply With Quote
Old 09-01-2014, 09:35 AM   #2
Mr Dual Sport
Roamer
Mr Dual Sport's Avatar
Oddometer: 1,568
You have to drop the cradle/subframe to do it so there's quite a bit of labor involved. Good quality parts should run around $400 for a clutch kit and rear main oil seal. Then you have to turn or replace the flywheel as well.
If you were closer to Bend, OR I could help you out.
Whatever you end up doing, don't skimp on the job by letting someone use cheap parts.
This will most likely be the only time you have this done, so make sure you get someone that will use good parts even if it means spending a few hundred more.
You're never lost till you run out of gas....
Mr Dual Sport is offline   Reply With Quote
Old 09-01-2014, 11:32 AM   #3
Tork
Pinsetter
Tork's Avatar
Oddometer: 3,506
Was Mathewsons one of the quotes ? I know they do top notch work but will probably charge high for it .
:ymca
Tork is offline   Reply With Quote
Old 09-01-2014, 02:00 PM   #4
Guano11 OP
Half Decaf
Guano11's Avatar
Oddometer: 1,276
Whatever you end up doing, don't skimp on the job by letting someone use cheap parts. This will most likely be the only time you have this done, so make sure you get someone that will use good parts even if it means spending a few hundred more.
Agree on the quality parts; nothing but genuine Toyota parts on all previous maintenance (brake booster, distributor, timing belts). Labor costs, however, were quite varied, with anywhere from 9hrs to 14hrs for the job.
I also agree this will be the only time for the job. The unknown is whether or not the rest of the vehicle will hold up, or if I've reached the "nickel & dime" phase of its life. Been a good, actually a great, car for us (original owners).
Is the procedure any less involved for my 2WD vs. 4WD? (Was hoping the high quotes may have been for the more prolific 4WD).
Did not quote Mathewson's, but will give 'em a ring. Thanks for the vector.
Guano11
Guano11 screwed with this post 09-01-2014 at 09:16 PM
Old 09-01-2014, 03:42 PM   #5
Mr Dual Sport
Roamer
Oddometer: 1,568
Yes, there would be less labor for the 2wd for sure! Double check those quotes.
Old 09-01-2014, 03:53 PM   #6
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,463
Repair pal shows
Old 09-01-2014, 09:33 PM   #7
Guano11 OP
Half Decaf
Guano11's Avatar
Oddometer: 1,276
^^ Oy! ^^ Never knew about repairpal.com.
When I enter my own ZIP code, I get a range of $1645 - $2265 for a 2WD clutch replacement. Suddenly, $1700 doesn't seem so bad!
Guano11
Old 09-03-2014, 10:30 AM   #8
Guano11 OP
Half Decaf
Guano11's Avatar
Oddometer: 1,276
About $1800 plus tax....so right up there with the rest of 'em.
Guano11
Old 09-03-2014, 11:19 PM   #9
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,344
I suddenly feel a lot better about driving a 4runner over a RAV4.. my last clutch cost me $400 at my mechanics shop. You might consider moving on, or if you want to drive... Crosson's auto repair in lake stevens is one of the only mechanics I trust.
n16ht5 is offline   Reply With Quote
Old 09-04-2014, 03:26 PM   #10
Guano11 OP
Half Decaf
Guano11's Avatar
Oddometer: 1,276
Worth the drive for the right guy (just under an hour away); will give them a ring.
Moving on is a bit of a commitment since the Rav is very solid otherwise. Plus, part of me wants to see just how far it will go!
Internet led me to "Mr. Clutch" with 3 metro locations. They've rung in at around $1200 & use OEM parts.
Guano11
Guano11 screwed with this post 09-04-2014 at 03:36 PM
Times are GMT -7.   It's 02:44 AM.
