10-14-2005, 05:16 PM
#1 |
Don't buy from Brad
Oddometer: 7,403
valve stem problems
took my rear wheel off and took it to a local honda bike shop.
was originally quoted $20 to replace tire and valve stem. they ended up charging me 25 and THEN making me pay for this junk-butt valve stem. had to pay it to get my tire back. anyway, they're absolutely worthless at that shop. My valve stem is so bloody long that i can't get a pressure gage or pump on it, even the flat 90 degree kind. i'm not happy. any suggestions on how to fix it? can i buy a different valve stem like the one pictured on the front tire? see pics below. http://www.datchew.com/r100/rear.jpghttp://www.datchew.com/r100/front.jpg and can someone PLEASE tell me how to put pics in the thread? the little yellow mountain icon doesn't work and neither does this "[img]www.whatever.com[/img]"
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
10-15-2005, 07:56 AM
#2 |
Albuquerque
Oddometer: 868
I you were smart you would have purchased the correct valve stem from BMW and taken it to your tire mounter.
Fear of BMW dealers strikes again.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S, '84 R80G/S |
10-15-2005, 11:18 AM
#3 |
Adventman
Oddometer: 1,236
...do you still have the old valve-stem? All they need is an o-ring and maybe a new valve, easy stuff to get. Advantage of the OEM valvestem is if you slice open your tubeless tire and you need to install a tube, the stem is easily removeable without a knife. You also don't have to carry spare rubber stems in case you cut your old one off. I'd stick with the original stem personally.
To post photo's you need a www.smugmug.com account or something similar. Then you cut and paste the URL of each photo to the box opened when you hit the mountain icon. |
10-15-2005, 03:05 PM
#4 | |
Don't buy from Brad
Oddometer: 7,403
What happened was that I didn't know I NEEDED to purchase a special valve stem. I figured the local shop jackasses (and i do mean jackasses) would have all the types of stems that I could need. Either way, when I got the wheel with new tire (and bad stem) back, they had already disposed of the short original one. I DID however just happen to ask about valvestems at the dealer today and they gave me one of the shorties. So now, I just have to figure out how to install the thing. Can I just remove the tire and simply PUSH it into place from the inside of the rim or do I need a special tool??? As for the pics hosting, I host my own pics. Tried several different combo's of what you said. Just didn't work. Will try hosting from another site... have a couple. thx.
10-16-2005, 06:08 PM
#5 |
Don't buy from Brad
Oddometer: 7,403
well, no responses yet. so here's an update.
I let all the air out and tried like hell to break the bead on the tourance. Used a large crowbar and both of the little tire spoons that come in the bike's toolkit. Simply couldn't do it. Maybe i'm doing something wrong. So unless I get some brilliant hint on how to go about this, I guess I'll go to another bike shop and ask them to install the new CORRECTLY SIZED valve stem. anyone? ...anyone?
10-16-2005, 06:52 PM
#6 |
N00b, obviously.
Oddometer: 347
well, one good thing to come out of your experience is... making me feel better about bringing my tires to the not-so-convenient bmw shop. I almost had the local jap-bike shop do them.
'88 BumbleBeemer "Minds Awaken on roads less Taken" -- Magic Hat bottle cap inscription |
10-16-2005, 07:38 PM
#7 |
Don't buy from Brad
Oddometer: 7,403
he he he.
glad I could be of help. So I guess the new rule is this: If you're gonna have a squid bike shop put your tires on, make sure you have some oem valvestems to give them or else they'll screw everything up.
10-17-2005, 03:21 AM
#8 |
Yinz, blinkers are on.
Oddometer: 9,988
Okay buy a Coates 220. Makes bead breaking and tire changing a breeze.
Try large C clamp to break bead. Lots, Lots of lube to remove tire from rim. Don't ding up rim. Find some type of plastic/teflon protectors for rim. Apply lots of sweat equity, Best luck to you.
If your looking for me. I will be at Rella's eating Blackberry pie. http://www.youtube.com/watch?v=qri3VhRQA7Q http://www.youtube.com/watch?v=_ampAFmwP_E |
10-17-2005, 05:39 AM
#9 |
Don't buy from Brad
Oddometer: 7,403
well, i'm hoping not to remove the tire completely, but to just squeeze in one side enough to access the valvestem and put in the different one.
is that feasible or do you think i'll have to take the whole bloody thing off?
10-17-2005, 06:37 AM
#10 | |
drinkin'
Oddometer: 8,079
Then you will need access to compressed air to reseat the tire on the rim. And be very careful to make sure it is seated all the way around properly. Not to sound insulting, but from your questions I'd say you have little or no experience mouting and balancing tires. You may be better off from a safety stand point to get this done by someone with more experence. Improperly mounted tires can be dangerous.
Loose nut holding the handlebars ![]() Hes one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape" |
10-17-2005, 06:43 PM
#11 | |
Don't buy from Brad
Oddometer: 7,403
We did mark the rim and tire to keep the balance correct. This weekend, i'm gonna try and break just one side with 2 large c-clamps and pull it over just enough to swap out the valve stem. Hopefully, i won't have to take the whole tire off. If it doesn't work to my highly meticulous (some say anal) satisfaction, I'll take it to the shop. I appreciate the advice.
