Old 10-18-2005, 05:22 PM   #1
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
R80 g/s vs ST
If you wanted to convert an R80 ST into a g/s do you simply add a g/s rear shock or are the mounting tabs on the frame different?
Thank you,
Aaron
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-18-2005, 05:32 PM   #2
BlackHoof
REMF
BlackHoof's Avatar
Oddometer: 244
ST Conv.
I may be wrong, but I think the ST had the front end that was used on
the R65, & used different sized rims than the GS. I had a '83 ST that I
put 100k miles on, & loved it. If it were me, I would sell the ST & find a
good GS instead of dumping big $$$'s into the ST. My .02. Good Luck!
BlackHoof is offline   Reply With Quote
Old 10-18-2005, 05:47 PM   #3
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Hey Hoof, yea I was planning on just buying a g/s, but they command such a big buck in the market. Honestly, the first thing I would do is ditch the stock g/s fork and replace it with a WP unit, and the rear for works unit anyway.
I thought I could just find an ST for $2000-2500 less, and use the difference to upgrade. With a stock WP front fork from a KTM, I also get a much better front brake set up. If I did all that to a g/s I'm pretty sure the purists might be upset.
Aaron
Just say'IN
Old 10-18-2005, 06:34 PM   #4
JDowns
Sounds good, let's go!
Oddometer: 2,712
ST to G/S
Hi Aaron,
Your idea will work fine. I have two ST's and the mainframe and subframes are the same as the G/S. The monoshock mounts are the same on both bikes so the shorter ST shock can be replaced with a longer better aftermarket G/S shock no problem. Blackhoof is right about the front end, but that is not an issue if you replace it. The power train is the same with the ST having the same motor, tranny, single sided swingarm, driveshaft and three bolt 37/11 final drive as the G/S. Both bikes take the same rear rack and bagframes although the ST is chrome and the G/S uses the easier to weld and paint black. Crashbars are the same deal. Same part with the ST chrome, G/S black. Use the same speedo but the ST nacelle is different and includes the tach that is lacking on the stock G/S. The ST has chrome handlebars and the G/S has wider reinforced bars. Same wiring harness and switchgear. It's a sweet bike and is underappreciated. I have put 100K on one and the other has 50K. Have taken them down some pretty gnarly roads in Baja and up to Alaska and pounded them on gravel backroads down towards Guatemala. Maybe with a better front end the ST would be better on rutted jeep trails, mud, deep sand or single track. I'm too cheap. It works fine for me stock on logging roads, gravel backroads, Baja, and smooth riding down the paved sections in between.
My only caution would be to not dump too much money into a frankenbike unless you have the disease that has no cure. A lightly used well set up KLR will do the same thing you want for about the same money. Just not as smoothly.
Best,
John
JDowns is offline   Reply With Quote
Old 10-18-2005, 06:41 PM   #5
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
Add to that for dirt performance -
The front forks/brake/wheel is different.
Wider and braced handlebar.
You may find the side stand and centre stands are of different length too?
The sump is smaller (higher ground clearance) with a bash plate on the G/S.
Add to that for cosmetics
Front headlight/instrument panel
--- As there are fewer STs around than G/Ses I'd think you'd be better off waiting for a G/S to turn up than a ST.
Ps - the purists can go buy the bike too if they want to 'preserve' it.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 10-18-2005, 06:47 PM   #6
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by JDowns
Hi Aaron,
Best,
John
Thanks John for the words of wisdom! I own a KTM 640 ADV for trail beating, so the g/s would be for commuting and longer trips into the bush.
My goal is to ride to Alaska on a boxer before I turn 40 and the older g/s is my first choice. Like you said, the ST's are under appreciated, and fortunately(for me) priced accordingly.
Thanks,
Aaron
Just say'IN
Old 10-18-2005, 06:50 PM   #7
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Hi frank,
I found 2 ST's for sale that are priced very reasonably compared to all the g/s's I've been looking at. I found a g/s n germany for $2100, but eh shipping will be a killer.......
Aaron
Just say'IN
Old 10-18-2005, 07:19 PM   #8
JDowns
Oddometer: 2,712
[QUOTE]Thanks John for the words of wisdom! I own a KTM 640 ADV for trail beating, so the g/s would be for commuting and longer trips into the bush.
/QUOTE]
Hi Aaron,
Yes, you have the incurable disease I was refering to. The GSified ST sounds like the perfect project bike for your needs. Inexpensive to buy, easy to get parts for, and plenty of nice folks to help with questions you might have both on this list and the airheads list on micapeak. The R80G/S and ST are both fine bikes that are relatively easy to work on. I think you'll have fun with it!
People in other threads are lamenting not being able to find a decent smooth twin dual sport under 400 lbs. and 10K dollars. We'll keep this our little secret, m'kay?
Cheers,
John
Old 10-18-2005, 07:45 PM   #9
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Yup
Just say'IN
Times are GMT -7.   It's 05:38 PM.
