Old 06-16-2011, 08:53 AM   #1966
wesplains
Nothing normal please.
wesplains's Avatar
Oddometer: 255
Liners
Does anyone know how much the old style liners for the 1550s are, or do they still sell them?
I was here.
wesplains is offline   Reply With Quote
Old 06-16-2011, 10:50 AM   #1967
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,223
We call them "Inner Bags" and they may be found here on our web site... http://cariboucases.com/store/?name=...=i&item=000344
Thank you.
-roger
Caribou Luggage Systems.
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain
CaribouCases is offline   Reply With Quote
Old 06-16-2011, 12:01 PM   #1968
wesplains
wesplains's Avatar
Oddometer: 255
Inner Bags
Thanks for the link.
I was here.
Old 06-20-2011, 05:48 PM   #1969
inmate-n00b
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
would a bracket fit here on a 36L side case?
i would like to increase the distance between the two brackets
inmate-n00b is offline   Reply With Quote
Old 06-21-2011, 07:43 PM   #1970
CaribouCases OP
Boulder CO
Oddometer: 1,223
The bracket won't fit in there, but you can move it a little more outboard than we did in this install.
Old 06-24-2011, 09:29 AM   #1971
inmate-n00b
Ciao, Marco
Oddometer: 1,006
Do you mean on the lid? That would negate the advantage of side loading panniers.
I'd like to cinch down a small ortlieb back with straps. Would it fit ok if the brackets are placed the same way as in this photo? I'm worried about how well they will cinch down.....
Rack-Pack Small
Volume: 24L / 1465 cu.in.
Size: 9" dia. x 18" long
http://www.bestrestproducts.com/p-11...rack-pack.aspx
The case liners worked very well on a recent camping trip, btw.....
Old 06-25-2011, 07:14 PM   #1972
CaribouCases OP
Boulder CO
Oddometer: 1,223
Rack-Pack Small
Not on the lid for the reason you mention, but just a little bit more toward the latches. This 6" diameter stuff sack worked fine. Note that you can still access the latches and the lid lock so you can get into the case....
Old 06-26-2011, 08:03 AM   #1973
tinbasher
Oddometer: 54
Break sways
Just wondering if you sell the breakaways separately ? I have 640 love the idea of pelican cases but much smaller. 4 inch thick would be lots just need room for tools tubes etc. Can build racks myself but breakaways not so much. Thanks. 640 one of the best bikes ever with the smallest selection of aftermarket ever. WTF
tinbasher is offline   Reply With Quote
Old 06-30-2011, 01:29 AM   #1974
Chef Gareth
Live 2 Ride
Chef Gareth's Avatar
Oddometer: 238
Just ordered my set of 35L panniers for my dl650, cant wait to see them in the flesh as I have done a lot of research in to what pannier would best suit me. Just wanted to say a big thanks to Roger for his quick response to my inquires. It really makes a difference when you get a fast and informative response from the owner of a company.
Chef
Chef Gareth is offline   Reply With Quote
Old 06-30-2011, 06:05 AM   #1975
kmw
Adventure. Er...
kmw's Avatar
Oddometer: 243
Chef
Chef -
The case is crooked because I had just been rear-ended by a cage on I-95 and they hit the case. Here's a better one pre-crash (and without the extra tyres, camping gear, etc):
I really can't recommend this set highly enough, it's fantastic. I've since sold the DL and moved to a KTM 990 - as soon as I brought it home I emailed Roger about a plate and locks, had my reply that evening and less than a week later the top case was mounted on the KTM. I gave the side cases to a friend with a DL-1000 when I got rid of the 650 and regret every minute of it, I'd love to have them on the 990.
kmw is online now   Reply With Quote
Old 06-30-2011, 10:11 AM   #1976
CaribouCases OP
Boulder CO
Oddometer: 1,223
The break-away latches may be found on our web site here... http://cariboucases.com/store/?name=...&mode=d&id=011
But, when someone wants to build their own racks, I always recommend this kit... http://cariboucases.com/store/?name=...=i&item=000281 and or this kit if you have a set of old Givi racks to start with... http://cariboucases.com/store/?name=...=i&item=000280
We are quickly becoming DIY central for these type of projects. We offer a lot of bits and parts to attach side and top cases.
-roger
Old 06-30-2011, 01:55 PM   #1977
airheadpilot
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 287
Universal vs. Specific Top Case rack?
Roger,
Like many others here I have a Yamaha Super Tenere on order. I commute in freeway traffic everyday and really like having a top case to put my briefcase in instead of wearing a backpack. That said, when my bike gets here in a few more weeks, I'll be interested in putting a top case on it as soon as possible. I'd like to go with a 35L Caribou for my top case. I understand that you need a donor bike in order to make a bike-specific rack, and so that product won't be available for a while after the bikes arrive. How do the universal top case mounts compare to the bike-specific top case mounts? I guess another way of asking, am I likely to be perfectly happy with the universal and putting it on right away, or is the Super Tenere-specific top case mount going to be so much the dog's bollocks that I really should wait until it is available?
Andrew
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 06-30-2011, 06:45 PM   #1978
CaribouCases OP
Boulder CO
Oddometer: 1,223
Originally Posted by airheadpilot View Post
Roger,
Andrew
Andrew,
Boy, that's a good question. We just finished the top case design for the Tiger 800 and it was very straight forward because Triumph did it right and put a 4-bolt pattern right on top the the tail section. From the photos I have seen the Tenere also has a 4-bolt pattern on the tail section. This makes our design effort straight-forward, and also makes it fairly easy for a DIY'er. It is really good when the 4 bolts thread down into the steel subframe. If there is only plastic or cast aluminum back there it gets a little more involved with proper bracing. When you get the bike and can take a few measurements, send me an email.
Thank you.
-roger
Old 07-05-2011, 09:51 AM   #1979
GTMan
Oddometer: 34
Panniers for Triumph Tiger 800 XC
Roger
Couple of questions. The 36L side cases for the 800 XC. Are those Pelicans ?
If I order with the case liners, does how much time does that add to the order ?
GTMan is offline   Reply With Quote
Old 07-05-2011, 01:39 PM   #1980
CaribouCases OP
Boulder CO
Oddometer: 1,223
Originally Posted by GTMan View Post
Roger
Hi GT,
The 36L are Pelican Storm cases (previously Hardigg Storm and Pelican bought them out). The 35L are the standard Pelican case. The liners add no extra time to the order. I assume you mean "Liners" and not "Inner Bags."
Thank you.
-roger
Times are GMT -7.   It's 05:54 AM.
