Old 10-28-2005, 01:55 PM   #31
Dirtysouth
Stud fee waived for noobs
Dirtysouth's Avatar
Oddometer: 4,975
I am another one in line for a 05 weestrom. Let us know when.
Dirtysouth is offline   Reply With Quote
Old 10-28-2005, 02:23 PM   #32
cagiva549
whats a cagiva
Oddometer: 2,454
Very nice , I was about to U bolt a set of Pelicans on to KTM brackets ,but your brackets are much nicer . If you have 950's in your future I will wait . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 10-28-2005, 02:41 PM   #33
mdrsteve
Oddometer: 69
Any idea of the timeframe on your KLR650 system???
mdrsteve is offline   Reply With Quote
Old 10-28-2005, 03:31 PM   #34
Komet
The Voice of Reason
Komet's Avatar
Oddometer: 38,096
Very nice products!
Always mindful of obstruction, do your duty, never fail;
Keep your hand upon the throttle, and your eye upon the rail.
Komet is offline   Reply With Quote
Old 10-28-2005, 03:43 PM   #35
Marc
Just sayin...
Marc's Avatar
Oddometer: 8,967
How hot does the exhaust-side case get after a few hours of riding?
[i]"I mean, really ... when you get right down to it, does a man need anything much more than bacon
Marc is offline   Reply With Quote
Old 10-28-2005, 03:58 PM   #36
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,215
I honestly can't wait to do the KLR, it is one of my favorite bikes. Probably end of December for design, end of Jan for sale.
Roger Pioszak, Caribou Luggage Systems.
Please see our Pelican-Based Luggage Thread in the Vendor Forum .
www.cariboucases.com
Made in Boulder, Colorado USA
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain Time Zone
CaribouCases is offline   Reply With Quote
Old 10-28-2005, 04:06 PM   #37
CaribouCases OP
Boulder CO
Oddometer: 1,215
Ahhh, very, very good question. The Pelican case gets warm but not hot, it does not conduct heat like aluminum. Your nylon rain suit in the left case will not melt.
There is another thing I like when touring with these cases that I forgot to mention. I can leave the case unlocked. I don't have to fiddle with my key just to open the case to get something out like I have to with the BMW system cases. When your pounding out 700 miles a day in the mountains, it is the little things that begin to count.
Old 10-28-2005, 04:40 PM   #38
GB
Mod Squad
GB's Avatar
Oddometer: 56,545
Here's my experience with the Pelican cases as side panniers, and it's not all good, so this is a heads up to you, so you can maybe find a way to overcome this "problem".
I have a pair of well abused Pelican 1550's on my KLR. The problem that I encountered is that with repeated off road crashing, the bolts that hold the pelican cases to the mounting racks begin to enlarge the hole in the plastic of the pelican case. After repeated crashes, the bolt hole through which the securing bracket that attaches to the mounting rack is now elliptical because the securing bolt, I suppose, is stronger than the plastic of the case, so it deforms the plastic over repeated hard contacts.
I don't think anyone can ride the 1150GS in the rock climbs and technical single trails where I've ridden this bike, so it may not be a big issue, but I thought I'd mention it in case you want to somehow re-inforce the mounting holes.
As for the performance of the pelicans, they are strong, water and dust proof, but packing them requires the use of inner liner bags, or else when you open the lids, everything falls out.
Keep the good work, it looks good!
Old 10-28-2005, 04:47 PM   #39
GB
Mod Squad
GB's Avatar
Oddometer: 56,545
p.s. any plans to do a set for the KLR? Maybe I can get my cases mounted to your rack.
Old 10-28-2005, 04:55 PM   #40
jlsworks
Acid Stained
jlsworks's Avatar
Oddometer: 790
Nice bags!
Will there be topcases available for the 1150GS Adventure?
James
jlsworks is offline   Reply With Quote
Old 10-28-2005, 05:31 PM   #41
CA_Strom
Cunning Linguist
CA_Strom's Avatar
Oddometer: 2,225
Thumb Pelican 1430
Another one in line for the Wee-strom kit. I already have a Pelican 1500 bolted on as a top case, and it works great. Have you considered adapting the new 1430 top-load cases that Pelican has a side cases?? They look pretty roomy, and the top load feature would be a big plus. Also, they are only about $60 each.
I was ready to buy a couple and bolt them to an SW-Motech quick release rack, but I like your design much better. I'll be waiting....
CA_Strom is offline   Reply With Quote
Old 10-28-2005, 05:50 PM   #42
eric_the_bald
Gnome
eric_the_bald's Avatar
Oddometer: 426
Dakar
Keep us up to speed as you get close with the F650 bags.
With the weight of my Jesse's, I'm interested....
ΜΟΛΩΝ ΛΑΒΕ
Don't screw around with old folks,
They didn't get old by bein' Stupid!
eric_the_bald is offline   Reply With Quote
Old 10-28-2005, 07:24 PM   #43
CaribouCases OP
Boulder CO
Oddometer: 1,215
Gadget, did you use the 4 thick lugs on the Pelican cases to put your bolts through? This and using a hard plastic bushing to keep the sharp bolt threads away from the Pelican material would eliminate the problems. And a big fender washer on the inside of the case. Yes there will be a KLR system you can bolt your existing Pelicans onto. And yes I use kitchen trash bags to hold my clothes. I also pack things I need to access often in the right side, and I put the bike on the side stand so the right case is tilted up and nothing falls out. The lanyards help too.
CaribouCases screwed with this post 10-28-2005 at 07:46 PM
Old 10-28-2005, 07:33 PM   #44
CaribouCases OP
Boulder CO
Oddometer: 1,215
The new 1430's are too small capacity for the majority of the market, and they are very wide at the top and narrow at the bottom due to the large draft angle. Too heavy too, and too much material to remove off the back of the case to make a bracket fit. Not very suitable for Caribou luggage.
CaribouCases screwed with this post 11-29-2008 at 12:51 PM
Old 10-28-2005, 07:37 PM   #45
CaribouCases OP
Boulder CO
Oddometer: 1,215
Originally Posted by jlsworks
Nice bags!
James
Hmmm, the Adventure rear rack is different from the 1150GS. I'll have to take a look at my buddies Adventure to see if one top plate can be made to fit both bikes. Good point.
Times are GMT -7.   It's 09:46 PM.
