04-13-2007, 10:20 AM
#781 |
Oddometer: 7,607
Got mine on - Roger - I replaced those 45mm button heads with 50mm hex heads. I think the hex heads are a better solution, they can be tightened with a 10mm wrench with the top plate in place - I found it was easier to allign if everything was loose. Nice rack, very solid. Thanks for your help.
04-13-2007, 12:04 PM
#782 |
Physycotic gecko
Oddometer: 1,313
Had pretty much the same experience as richc, had to replace the 45mm button heads with longer bolts, i think i used 50 or 55mm bolts
(mid install ride to work to raid the bolt rack ) Other than that it went pretty smooth, just the way i like it Some piccys of the whole setup, all cases are 1550's Even tho i ordered a 1520 setup Ah well, if i want a 1520 i'll order it from roger ![]() ![]() ![]()
04-13-2007, 03:37 PM
#783 | |
Boulder CO
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,151
I'll have the DAKAR in here again next week and look at tweaking things a bit to align the top case more with the side cases. May be possible with some spacer changes, and maybe not due to the access needed for the seat latch, I'll check into it.
Roger Pioszak, Caribou Luggage Systems. Please see the beginning of the Pelican-Based Luggage Thread in the Vendor Forum . www.cariboucases.com Made in Boulder, Colorado USA PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain Time Zone |
04-13-2007, 03:46 PM
#784 | |
Boulder CO
Oddometer: 1,151
ok, all early product glitches, be gone with you
04-13-2007, 04:51 PM
#785 | |
Oddometer: 7,607
04-14-2007, 12:23 AM
#786 |
Physycotic gecko
Oddometer: 1,313
i'm happy with the 1550 case roger, thanks for the offer tho. I thought the 1550 would look out of place on the back but it sits there nice.
I don't know if you charged me for a 1550 setup, if not pm me and i'll settle the difference. I don't want no for an answer btw The bolts were nothing and Rich is right, its a top quality product for a fairly small market, You did good
04-14-2007, 12:22 PM
#787 | |
Oddometer: 53
Upon closer inspection of the photos I can see why having to open the access door would limit your mounting options somewhat. I second the above comments, by the way. Thanks for a great product and for being so accessible. Art |
04-14-2007, 04:36 PM
#788 |
1200gsa
Oddometer: 57
Roger, I see on your web site that you have adjusted the system to fit onto the 1200 GSA model and still retain the factory rack. Is it possible to have some pics posted to show the cases both on and off the bike.
Secondly, I see you offer two sizes in the case, the 1520 @25 litres and the 1550 @ approx 35 litres. I am considering the aspect of keeping the rear of the bike as narrow as possible, are the 1520 cases any narrower (on the bike) than the 1550? Thanks (in anticipation) Peter |
04-14-2007, 04:43 PM
#789 | |
Boulder CO
Oddometer: 1,151
The cases on the 1200GS with our re-designed rack sit exactly as the previous system, so the pics in this thread and on our site are accurate. I'll post a pic of just the new rack/brackets in a few days, along with the new 1200GS/Adventure top cases. The 1520 will be narrower by 1" per side (2" overall). Note that I have not yet made the 1520 case fit our case bracket (formally). There are some issues with raised features on the back of the 1520 case. Also, the 1520 is a day-trip or very light overnight case, not really enough room for multi-day travel. EDIT 2009, the 1520 case is no longer available.
Roger Pioszak, Caribou Luggage Systems. Please see the beginning of the Pelican-Based Luggage Thread in the Vendor Forum . www.cariboucases.com Made in Boulder, Colorado USA PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain Time Zone CaribouCases screwed with this post 02-10-2009 at 02:09 PM |
04-14-2007, 11:23 PM
#790 | ||
Poster Boy for Red Death
Dood, lower your expectations a little, the BMW GS isn't the Homecoming Queen OR Prom Queen, it's the band camp girl you really wanna take to the dance cause you know you are gonna have a good time. Quote:
2006 R 1200 Bayerische Motoren Werke Gelande Strasse (blue) the sexy color |
04-17-2007, 11:56 AM
#791 |
Boulder CO
Oddometer: 1,151
BMW R1200GS & Adventure Rear Top Cases and Cargo Plates
The new Caribou rear top case and cargo plate for the BMW 1200GS and Adventure are now available. For the Adventure model the system mounts to the stock stainless steel tail rack. Quick attach/release system allows you to take the case off the cargo plate in seconds. Cargo plate is 12" x 15" aircraft aluminum, mounted very solidly to the bike. Please visit www.cariboucases.com for more details and to order. Here are some basic pics (1550 size case shown) ....
Stock 1200GS rear tail rack position.... ![]() Cargo plate in both positons... ![]() 1200GS Adventure attachment to rear rack, two 1/2" square tubular steel rails run under the aluminum plate for maximum stiffness and support.... ![]()
Roger Pioszak, Caribou Luggage Systems. Please see the beginning of the Pelican-Based Luggage Thread in the Vendor Forum . www.cariboucases.com Made in Boulder, Colorado USA PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain Time Zone CaribouCases screwed with this post 07-09-2011 at 03:19 PM |
04-21-2007, 05:04 AM
#792 | ||
My problem is this. Since I put this GSA rack on my GS, I have no way to mount my Jesse box and am looking for an alternative to the Jesse and your product is looking better every day...... THanks
04-21-2007, 07:24 AM
#793 | |
Boulder CO
Oddometer: 1,151
![]() Our 1/2" steel tubing rails bolt to these L brackets.... ![]() and our aluminum plate bolts to the top of the steel rails. So the aluminum plate ends up about 1" above the stock Adventure rack. When you put 1/2" steel rails under the aluminum plate, you end up with a very stiff and strong platform.
04-21-2007, 09:45 AM
#794 |
Oddometer: 539
Honda XR 650L
Roger:
Any further development on a system for the XR650L? I cuurently have Ortlieb's dry bags but I'm looking to upgrade to hard bags. I'm considering buying the pelican cases from you and manufacturing some bracketry for mounting. Let me know your thoughts and current devel.opments for the XR650. Thanks, John |
04-21-2007, 11:53 AM
#795 |
Oddometer: 70
Uly cases
I installed the cases last sunday and they are absulutly great. Took a 300 mile trip to some rather rough roads in WV and they felt great. Thanks for a great product.
