Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 04-07-2013, 02:56 PM   #421
Roadinator
Roadinator's Avatar
Oddometer: 256
Looking at purchasing an '05 Tiger with 50K, Seems like it has been taken care of and has a service history. When do miles like this become an issue? What should I be concerned about - clutch, etc?
Roadinator is offline   Reply With Quote
Old 04-07-2013, 03:05 PM   #422
Photo Boy
Photo Boy's Avatar
Oddometer: 74
Dirty Bling (above) bought my 2006 Tiger that had 72,000 miles. The clutch was like new with only minor adjustment to the clutch cable, the original cable btw. I bet the clutch on that bike is good for another 50K.
Photo Boy is offline   Reply With Quote
Old 04-07-2013, 09:55 PM   #423
Roadinator
Roadinator's Avatar
Oddometer: 256
Nice.
Any issues with getting an older one with lower miles? I guess the displacement is different and the older ones with spokes took tubed tires? If you had a choice between a low miles (15 K) '99 or '00 and a high mile (50k) "04 and "05 with both having about the same extras and price tag - what would you choose?
Old 04-08-2013, 07:32 AM   #424
Photo Boy
Photo Boy's Avatar
Oddometer: 74
Originally Posted by Roadinator View Post
Nice.
I don't ride off road and only occasionally on a dirt road. I'd buy the higher mileage "05 or "06 because it has cast wheels and tubeless tires. I've had a blowout on the rear tubed tire on an earlier bike and it wasn't fun.
Old 04-08-2013, 07:44 AM   #425
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,989
Originally Posted by Drunk_Uncle View Post
2. The oil pan bolt is leaking.... only leaks a couple drops in 24 hours. Any Ideas?
Go to the hardware store and get some teflon tape. Get the yellow stuff that is for natural-gas fittings. It's tougher and will do better in your tool bag than the wimpy white stuff for regular plumbing jobs. When you wrap it on the threads of your drain bolt, wrap it so when you tighten it in the threads the tape is winding so the threads tighten it. if you wind it the other way it loosens the tape and it bunches up and sometimes it doesn't even work. Put about 2 full wraps of the stuff on the bolt. Put the rest in your tool bag,
I've used it for other tricks too. Once for a very sloppy brake pedal pivot. I wrapped a bunch on the shaft and slipped the pedal back on. It tightened up the fit and lasted a long time..
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 04-08-2013, 06:11 PM   #426
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,155
Well I found the culprit and will be replacing the oil pan this winter. I tiny bit of metal broke off at the bottom of threads and a small crack in the threads. So I used some permatex high temp thread sealant and ultra black smeared thinly on top edge of bolt and top edge of washer. Going to let that all cure for 3 days and add oil and see what happens. Just hoping it gets me through he summer and then a new pan.
A new pan is a much better option after consulting the shop manual. Only oil cooler and head pipes need to be removed to access pan. I was worried tank and radiator would have to come off.
"I refuse to tiptoe through life only to arrive safely at death"
'13 Tiger 800XC, '14 Street Triple, '00 KLR 650(current project), and a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 04-09-2013, 06:39 PM   #427
N9921X
Wins
N9921X's Avatar
Oddometer: 145
Sump cost.
Pray tell. What does a new pan cost these days?
I may be looking for one too.
Thanks.
Have a great trip to inuvik!
N9921X is offline   Reply With Quote
Old 04-09-2013, 07:42 PM   #428
Drunk_Uncle
Oddometer: 2,155
Its a little over 300 bucks on bikebandit.com. Unfortunately two days later the thread sealant is still not dried. It said 72 hours to fully cure, so we'll see tomorrow.
Old 04-10-2013, 05:33 PM   #429
TMORAN
Oddometer: 191
05 Tiger
Guys, looking for a little info as I'm hoping to be loading a nice 05 British racing green tiger into the back of my truck on Saturday. 12,500 miles, looks mint, owner stays it is and and boughgt it from the shop with 1000 mile son it. Alway serviceed witrh synthetic oil, stored in a heated gargage. It's a 160 miles one way, not a big deal, nice little trip with the wife. Anything I should be looking for? Very excited about this bike!
Tom
Life is like a roll of toilet paper. The closer you get to the end, the faster it goes.
13 KTM XCF-350 with street kit
08 KTM 530 XCRW Dualsported -For Sale!
05 Triumph Tiger
TMORAN is offline   Reply With Quote
Old 04-10-2013, 05:45 PM   #430
Photo Boy
Photo Boy's Avatar
Oddometer: 74
Tom
Tom,
Look for prior service records and for the 12,000 mile service to be done which would include valve inspection and adjustment if needed. Ask about any issues with the regulator/rectifier/alternator and battery output. Does it need new tires?
Old 04-12-2013, 02:57 PM   #431
keystiger
rat on a roll
keystiger's Avatar
Oddometer: 372
Tom
Not sure what your paying for it. But an 05 with that few miles has to be in decent shape, Photo Boy hit the nail on the head really. Post up some pics if you get her. Sounds an excellent deal.
I saw a subliminal advertising executive, but only for a second.
-- Steven Wright
keystiger is offline   Reply With Quote
Old 04-12-2013, 03:48 PM   #432
MTKNZ
Touring Kiwi
MTKNZ's Avatar
Oddometer: 104
Talking Really!
Wow you found this with only 12,500 miles on it, you better grab a lottery ticket while your luck is in!
Sounds like an excellent deal, check the service records of course and the usual obvious things tires, chain etc (dummy stuff). With that few miles on it there shouldn't be much to check TBQH
I would also ask about any mods that have been done, like the charging system, dual headlights change, remaps and things of that nature. Then I would go over them very closely to ensure they were done right, but I am weird that way.
Remember to post photo's when you get it!
If you can't laugh at yourself, you're just not paying attention!
MTKNZ is offline   Reply With Quote
Old 04-12-2013, 07:49 PM   #433
TMORAN
Oddometer: 191
Thanks guys!
Heading out at o"dark hundred with cash! Of course it just friggin' snowed here today...WTF? But I've got my truck loaded with ramps and tie downs. I do know that it has brand new tires, new battery a few weeks ago. Always had synthetic oil changes. Still has stock chain and sprockets, and he said it will be due for the first valve adjustment check at 15,000 but runs and sounds perfect,says it's like brand new, stored in a heated garage and always covered, it was his his baby. Talking with the guy and he sounds solid! When I get it I'll post pics (when I figure out how....)
05 Triumph Tiger
Old 04-12-2013, 07:57 PM   #434
Photo Boy
Photo Boy's Avatar
Oddometer: 74
Congratulations! You might be able to cut a slightly better deal since the valve check was due at 12,000 miles. Stock chain and sprockets might be needing replacement before 18,000 miles as well. A good DID chain and sprockets will last over 25,000 miles but the stockers don't.
Good luck and be sure to post photos!
Old 04-12-2013, 09:14 PM   #435
Idahosam
Set Adrift
Idahosam's Avatar
Oddometer: 4,126
OK, I don't do this normally but sometimes it's just get's under my skin. First I think your getting an excellent deal on the Tiger, and I am sure you will be happy with it. Now, about the valve check thing. I know someone will come at me but I have been riding bikes for over 35 years now and the valve check is not that important if the bike is running strong. It is a recommendation for the dealer to make some cash. That said, how about people like me who do there own work and servicing in my garage.... I don't have Service records except what I write in my Mead Composition Book for each of my bikes. BTW if someone tries that lowball crap on me I tell em to have a nice day
I assure you unless the guy abused it somehow I say just get on and ride it, stop worrying about trying to figure out how to chump the guy out of a little money. If it excites you and when you turn the bike on it turns you on whatever price you willing to pay is worth it "opportunity cost" Enjoy it would like to see some pictures when you get it.
Sorry for the rant but it really pisses me off to hear someone what to screw someone just for a couple bucks . 15K Hell it's still new. OH! and I can promise you when you take in for a valve check it'll be in tolerance. Mechanic or service manager says "she's good just a little tight" 300 dollars please.
Just ride the bike, and have fun; END of My Rant............. stepping off soapbox now.
My Ride South of the Border
Riding Nevada's Pony Express Trail May 2013
To travel is to discover that everyone is wrong about other countries.
Aldous Huxley
Idahosam is offline   Reply With Quote
Times are GMT -7.   It's 12:16 PM.
