Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 04-30-2013, 08:44 PM   #481
Roadinator
Roadinator's Avatar
Oddometer: 256
So I was taking some pics of my shock to post a question on tiger triple about rear shock adjustment and I noticed something in the picture...
Can you see what I see?
Roadinator is offline   Reply With Quote
Old 04-30-2013, 09:04 PM   #482
MTKNZ
Touring Kiwi
MTKNZ's Avatar
Oddometer: 104
ooooohhhh boy that's not good
If you can't laugh at yourself, you're just not paying attention!
MTKNZ is offline   Reply With Quote
Old 04-30-2013, 09:37 PM   #483
Roadinator
Roadinator's Avatar
Oddometer: 256
Yeah, nice surprise eh?
I am not in front of the bike, so I can't crawl in and take a look, but I am pretty sure that is what it looks like. I wonder if this is common on Tiger's? On the the other forum it was recommended to weld or replace with an ebay swing arm. I took a look and there was a '05 listed on ebay for $59.95 with $20 for shipping. Got it, so at least I have a low cost replacement (other than time to do the swap).
Dodged a bullet with that one...
Old 04-30-2013, 10:09 PM   #484
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,156
Damnit, now I have to go look at my bike. My Sprint ST 1050 was recalled for something similar and sure enough the link had completely failed and lucky I didn't have a suspension failure.
"I refuse to tiptoe through life only to arrive safely at death"
'13 Tiger 800XC, '14 Street Triple, '00 KLR 650(current project), and a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 05-01-2013, 06:00 PM   #485
N9921X
Wins
N9921X's Avatar
Oddometer: 145
Grip vibes
Yeah, it could be me. I didn't know if heavier bar ends would help? What about a crossbar brace?
The bike also has been laid over recently and I know the screw holding the right bar end bent a little. I think it also has smaller grips than stock.
Don't remember a numb right hand 23 years ago, but I've been rode hard and put away wet to many times since then...
I ride a 6 yr old tiger 1050 and find some buzziness too. I put on some grip puppies and it really helped. Kinda like waterski handles. Took about 2 ,minutes to get used to the larger diameter grip, but so be it.
N9921X is offline   Reply With Quote
Old 05-01-2013, 09:36 PM   #486
Roadinator
Roadinator's Avatar
Oddometer: 256
I just ordered a pair of grip puppies. Was also thinking of trying a crossbar? Cheapest things first, so grip puppies are on there way.
Old 05-03-2013, 10:21 AM   #487
Roadinator
Roadinator's Avatar
Oddometer: 256
Just an update. No crack in the swing arm, just a phantom pic scare you type of thing. On to swapping a tire and more riding!
Old 05-03-2013, 11:23 AM   #488
Hatley Rocket
Hatley Rocket's Avatar
Oddometer: 318
'01 fork setup
Roadinator,
Your swingarm and shock are dirty, FYI.
I took my front forks apart, I wanted to change the oil to a heavier weight, and add pre-load spacers to stiffen up the front end. When I removed the internals, I was surprised to find a 6" to 7" long aluminum pre-load spacer already in the fork, along with a progressively wound fork spring. I think they came with "triple rate" springs, but these looked like they only had two separate windings. Anyway, for anyone who has had their '01 apart, are these what would be stock fork internals, or have these been upgraded to progressive or another aftermarket spring? Also, how much oil do I put back in? I've had the tubes upside down and pumped them quite a bit, so most of the oil is out. Should I go with 10w, 15w or 12.5w?
T
Hatley Rocket is offline   Reply With Quote
Old 05-03-2013, 04:07 PM   #489
Sir. Waffles
Sir. Waffles's Avatar
Oddometer: 90
I also have an 2001 and put 12.5 wt oil in mine. I find it a little soft sometimes, I weight a good 205 lbs though and usually have luggage and/or passenger on. I feel if it wasn't for the brake dive I would be okay with it. I think I will be tweaking it as the season goes on, maybe a little more oil to help things out.
2001 Triumph Tiger 955i
New England Exploration
Sir. Waffles screwed with this post 05-03-2013 at 04:13 PM
Sir. Waffles is online now   Reply With Quote
Old 05-03-2013, 06:40 PM   #490
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 635
10 weight oil with about an inch more of preload spacer on the springs works well................
mustang is offline   Reply With Quote
Old 05-03-2013, 09:06 PM   #491
lvscrvs
lvscrvs's Avatar
Oddometer: 634
choose your fork oil carefully... i put 10wt silkolene pro in my tiger and it was too stiff.... had to dump it out and go to 5wt
http://www.peterverdone.com/wiki/ind...spension_Fluid
Ginormous Beasts go to the Eastside
Tiger 955i / Yamaha WR250R < Tiger 955i / DRZ400S / R1150GS < FJR1300 < DL1000 < BMW R1100RS < Ducati ST4 < DL650 zzzzz 30+ years zzzzz 125 Honda Elsinore < Suzuki TM250 < Yamaha 90 Enduro < Taco
lvscrvs is offline   Reply With Quote
Old 05-04-2013, 07:26 AM   #492
Hatley Rocket
Oddometer: 318
Even longer preload spacer?
Mustang,
Should I go with an even longer spacer, your serious then? I figured they were already pretty long. I don't want to affect the suspensions ability to use full stroke with jamming in preload stilts. I guess I'm still not sure if its already been fiddled with or if that's a factory setup.
Lvscrvs,
That's a lot of information! I have 10 wt oil, I guess I'll have to look at the brand and check the cst rating of the factory oil vs what I've got.
T
Old 05-07-2013, 08:04 PM   #493
Sir. Waffles
Oddometer: 90
Rereading your post about you fork internals sounds similar to what I found in my 2001. I tried to find a picture of the internals but it seems to be the one thing I didn't take pictures of when I had the bike apart. I feel safe saying they were the originals based on what I know about the guy who owned the bike before me , had it from almost new. Inside was also about a 6 inch piece of pipe that looked like a fence post and progressive spring.
My Tiger had about 20,000 miles on it when I changed the oil. It was truly wore out, and made the forks unpredictable. Just changing the fluid I feel will make a difference for you, which has been my experience with other bikes. Also given the amount of time it takes to change the fluid and only cost 25$ for 2 liters. I would start at 12.5 wt or 10 wt (stock wt) and then if it doesn't suit you add more fluid or include a spacer. You won't know it until you try. For reference I used Maxima fork oil, just my 2 cents.
Old 05-16-2013, 03:42 AM   #494
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 260
I'm the proud owner of an 01 girlie!!!!!
Just had to share.
Now to get some plates
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 05-16-2013, 06:00 AM   #495
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,990
and maybe some pictures!
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Times are GMT -7.   It's 11:32 AM.
