08-26-2011, 05:11 PM
#5671 | |
Knurly Adventurer
Oddometer: 389
My plastic shrouds didn't go back on as easily as some others have reported. They took quite a bit of coaxing and cajoling to get them back on using all of the original mounting points and hardware. Not an issue with the Unabikers, just a wonky fit. Eventually, they went on but not perfectly. Not a big deal. Just an FYI. |
08-27-2011, 09:29 AM
#5672 |
former redriderofma
Oddometer: 1,009
Anybody have any ideas on how to make the brake peddle a little larger so it is easier to use? I have a 2007 KLX 250 and I need the peddle a little wider.
Unless we change direction, we are likely to end up where we are headed. It's county Fair time in New England |
08-27-2011, 09:52 AM
#5673 |
Occasional Venturing
Oddometer: 659
I saw a post on wider foot pegs where a flat piece of steel stock was bent, cut, notched, and welded onto the footpeg making a nice looking wider peg for the KLX (just about doubling its width). The same could probably be done for the brake.
08-28-2011, 12:45 AM
#5674 | |
Street Prophet
Oddometer: 92
Getting Shafted
Normal is the playground of the unimaginative Trophies Last Forever, Bones Heal, Chicks Dig Scars Suzuki PE 250 Ducati 1198 Katooom 350 SX-F |
08-28-2011, 05:08 AM
#5675 | |
All bikes are dirt bikes
Oddometer: 1,431
I just loosened my new to me bike's chain yesterday. Should have checked it before but the seller mentionned the bike had been set up by her mechanic at the dealership. That should have been a warning right there. The ground wire was also very loose on the battery. It caused the headlight to flicker at fast idle(choke). Probably didn't help the highway missfires that I was complaining about.
And what are you planning to do with your one and only life? |
08-28-2011, 06:55 AM
#5676 | |
PussyWagon™ Chauffer
Oddometer: 3,576
You can bend/pry the brake pedal outwards slightly so you can dab it easier with your boot. I've also seen guys weld on a partial small footpeg to their brake pedal for a larger surface area.
Steve 07 KLX250S w/300 kit, 05 DR650SE, 04 XT225 99 VFR800 w/870 kit, 96 GPz1100 |
08-31-2011, 01:28 AM
#5677 | |
Street Prophet
Oddometer: 92
08-31-2011, 06:05 PM
#5678 | |
Oddometer: 1,431
I thought the DR650 was the ultimate fun machine until I rode this little thing. What a blast! ![]() I just installed a 15 tooth counter-shaft sprocket and love what it has done to the bike. First gear doesn't run out as fast (obviously) and sixth gear at 120kph indicated is not bad now. Any need for more acceleration above 100, I can drop it down to fifth and still have room to accelerate. Hills will most likely require a downshift.
08-31-2011, 08:29 PM
#5679 | |
Oddometer: 372
I just put the 14 back on mine. I took it on the highway the other day with the 13 still on it - I was winding out at almost 9000RPM at 75 MPH! Poor little bike. I'll leave the 14 on it while my busted collar bone finishes healing up, since I'll be sticking to road for a while. No dirt for me for several more weeks. Don't want to be messed up for the upcoming snowmobiling season!
2009 KLX 250S If it ain't broke, take it apart and find out why!
09-02-2011, 01:45 PM
#5680 |
Oddometer: 840
Check out www.gearingcommander.com very usefull for gearing vs speed
2003 xt600e 118.000km on stock motor. 1986 xt350 94.000km |
09-02-2011, 03:35 PM
#5681 | |
Oddometer: 1,431
My GPS was conected all along. I can say it's almost exactly 10% off Anyways. I'll relate this in MPH taken from the GPS, not the speedo. The bike can hold about 70 mph in 6th going uphill on the highway(no wind) at 7500rpm. Most car speedometers are off too so it has no trouble keeping up with the trafic. Coming back I had a strong headwind and chose to ride a twisty road with more hils. The bike felt better in 5th gear for this kind of driving at 60 mph never going past 7500rpm. So that is my report for the 15 tooth sprocket. The bike has a Dynojet kit and KDX snorkel
09-02-2011, 07:24 PM
#5682 |
Oddometer: 1,355
Old tank bad~ new tank good
Awhile back Tom told me about a gas tank recall. as per usual I put it off.
![]() Then next thing I knew the gas was running out the bottom[side bolt hole] about as fast as I was putting it in. Local Kawa shop said they would get me a new tank, can you say back order. IMS here I come. On the 26th of Aug. I ordered up a clear and it showed up today. ![]() ![]() UPS stopped by with a box; big yawn, the wifes middle name is QVC. But this showed up. ![]() So out to my shop to move some orange out of the way and give Tom a call. ![]() Tom just put one of these tanks on his fast red KLX and knew all the ins and outs. I have to paint on the house this week end and didn't want to waste all my bad words putting on the tank. ![]() ![]() With Toms help all went good cept for me loosing a few bolts a few times. It turned out looking pert good. Near as I can figure it holds 3.2 gallons. ![]() We put in half a gallon and headed for the station. Made a mark on the tank at 1/2, 1 and 2 gallons just to see how it works. ![]() ![]() Thanks for the help Tom. Can't hardly wait to go empty it all out.
What has been seen can not be un-seen
turnsleft screwed with this post 09-26-2011 at 05:42 PM |
09-03-2011, 07:02 PM
#5683 | |
Oddometer: 372
BTW - My speedo was off exactly 9.7%, before I fixed it with a SpeedoDRD.
09-03-2011, 08:03 PM
#5684 | |
Oddometer: 1,431
I ride mostly dirt roads and trails but the highway is the only way to get there. First gear isn't a problem at all and I use the clutch when I get into tricky stuff. I like the idea of a 351 but hate the lost mileage with it. So far I get about 180km(110 miles) per tank and another 150km(95 miles) with the Kolpin tank. I push it hard on the highway and the dirt roads too. I'm now looking to store the tools and spare tubes lower on the bike but haven't found a good spot for it yet. A permanent place would be better. Next are custom saddle bags and that should be it for farkles (ya right ).I LOVE THIS BIKE!
09-04-2011, 01:25 PM
#5685 |
Nobody's Robot
Oddometer: 1,323
Does anyone know if the KLX250S shift lever is longer than the SF shift lever? I know the "S" is different, with a knurled aluminum tip vs rubber on the SF. I'd be happy to find out that it's longer, as the SF lever is too short for me. Thanks!
Edit: I'll make it easy, here's my SF shift lever for comparison:
cjbiker screwed with this post 09-04-2011 at 01:31 PM |
