Old 05-17-2012, 04:37 PM   #6781
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Originally Posted by Aron31 View Post
Yeah it's been raining almost daily here for the last month. So no dust. But plenty of mud.
That's how it was when I was up in Oregon in 2010... lots of greenery, lots of "wet" and mud. I didn't know how to ride dirt back then so I avoided most of the trails. Plus back then my only "off-road" bike was my DR650.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 05-17-2012, 06:34 PM   #6782
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,397
Finally got around to putting on the Powerbomb header laying around in my garage.
And I replaced the Powercore that I ran with the stock header with a new Q4.
The Powercore on this 351 version was louder than the one on my racebike. This is a noticeable difference. I like it.
I have a little-used Powercore slip-on if anybody is looking for one.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 05-17-2012, 07:37 PM   #6783
Aron31
Aron31's Avatar
Oddometer: 113
Rob
My other ride is a klr650. I got the klx for the wife to learn on but have found that since its so light I have much more fun driving hers offroad. It can do things that my Klr just shouldn't.
Aron31 is offline   Reply With Quote
Old 05-18-2012, 05:38 AM   #6784
Henderson757
Adventure~Rugby
Henderson757's Avatar
Oddometer: 411
New KLX owner
Hey guys,
New KLX owner here. Picked up a 07 with some good mods . . B&B kit, Upgraded Carb . . ECT. The few things I am trying to look for is upgrading the springs and the perfect sprocket combo. I have two wonderful kids that are 1 year and newborn. so money is in the equation.
Springs
I will be doing light road travel with a heavier focus on dirt, single track, low speed Technical riding. I want to have a load rate around 285LBS. (myself and gear) so any suggestion?
Sprockets
I dont really want to swap out sprockets, I'd like to just have a good combo that when running around 60MPH I am not going to put a lot of stress on bike. I dont plan on running the interstate but if I need to hope on it to get from trail to trail I would like to have the power. With that being said I would also like to be able to get the front end off the ground easier.
So feel free to suggest away and thanks in advance
Henderson757 is offline   Reply With Quote
Old 05-18-2012, 05:45 AM   #6785
mikesova
mikesova's Avatar
Oddometer: 1,937
Does anybody have any pictures of their KLX with the Alaska Leather buttpad made for dual sports? My seat, I'm quickly discovering, is a torture device for anything over 30 miles. I wear bike shorts with a gel pad built in, but that's not quite enough.
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is online now   Reply With Quote
Old 05-18-2012, 07:32 AM   #6786
goofus
Swamp Yankee 4Life
goofus's Avatar
Oddometer: 75
Installed the Zeta 3-finger levers on my 2010 KLX250s. Perfect clearance with the Moose Handguards. The Zetas are a perfect fit and include the switch actuator tabs for brake lights (and whatever the clutch side does). They also fold away from the bars if you happen to crash and they want to bend that way. Due to that forward articulation, they also have stops on them so you can move them out if you want more room when they are at rest. Really impressed with these.
http://www.zeta-racing.com/lever/piv..._cp/index.html
2008+ KLX250S Part #s:
3-finger brake lever: ZE41-3145
4-finger brake lever: ZE41-4145
3-finger clutch lever: ZE41-3127
4-finger clutch lever: ZE41-4127
Comparison of factory and Zeta lever- factory are completely cast, Zeta's are machined.
Installed with Moose handgaurds:
goofus screwed with this post 05-18-2012 at 08:39 AM Reason: Added stuff.
goofus is offline   Reply With Quote
Old 05-18-2012, 08:00 AM   #6787
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,488
Originally Posted by RiverRunner757 View Post
Hey guys,
Springs
Sprockets
Welcome to the KLX world! There are several spring options and for that weight you're definitely going to want to upgrade if it's still stock. I used Race Tech springs in forks and rear, and their gold valves in the forks. There is at least one other company with comparable product. Are your sprockets still stock 14/42? If so, you could try a 13 up front and should still be able to do 60. I'm running a 45 on the rear now and switch between 13, 14 & 15 up front depending on what I'm doing. See gearingcommander.com
IDRIDR is online now   Reply With Quote
Old 05-18-2012, 09:45 AM   #6788
250senuf
250senuf's Avatar
Oddometer: 2,407
Check out "Seat Concepts". They sell replacement foam and cover kits. Haven't had a chance to ride mine yet but lots of good reviews over in the Kawi forum. If you can do without the seat for a while I now think it would be worth it to send it to them and have them do the install. DAMHIK.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 05-18-2012, 01:53 PM   #6789
djchan
djchan's Avatar
Oddometer: 1,173
Originally Posted by Lutz View Post
I live and ride about the same elevation range as you, generally just above 600' to maybe 2000'. I have an '09, but the stock exhausts are pretty similar. With my stock exhaust and snorkle out, I left the pilot jet stock 35 keihin, turned the air screw 2-1/2 turns out, put in an N1TC in the top or 2nd clip (don't remember which), and a 122 keihin main jet. It really ran quite well with that setup.
I've decided to put my money into suspension moreso than power on my 2007 KLXs.
I have everything I need to rejet laying around - so a couple questions. Lutz recommends a 122 Keihin MJ. I have a couple DJs laying around - a 120 and a 124. Which one would be closest to a Keihin 122? If they're both a little off - maybe I can order a Keihin. Good source?
I'd also like a go to a an aftermarket filter. Any recommendations - Uni, K&N, etc?
I know the DJ kit includes a lighter spring. I'm making it up as I go from parts I already have. How many coilss do I clip from the slide spring for better throttle response?
7/64ths or 1/8th on the slide hole?
Thanks again.
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Old 05-18-2012, 02:05 PM   #6790
kbuckey
Oddometer: 862
Got a Sargent for my KLX. Love it. That being said, I had a Seat Concepts for my Strom and really liked it too.
kbuckey is offline   Reply With Quote
Old 05-18-2012, 03:52 PM   #6791
jon_l
jon_l's Avatar
Oddometer: 3,289
Good plan
For what they cost, why not just order the right jets? http://www.rockymountainatvmc.com/search?term=jet
UNI is great. K&N can be controversial, but most feel they're OK for street more air / less filtering, but risky in dusty / off-road conditions. I'd go UNI.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 05-18-2012, 04:33 PM   #6792
djchan
djchan's Avatar
Oddometer: 1,173
Thanks Jon. Don't know how I missed the jets at RMATV. I have an order awaiting a few more items to fulfill the free shipping. Now which series of Keihin MJ do we take for the KLX?
I haven't had the carb out yet cause I don't want it unrideable while I'm waiting. So I have no measurements to go by for the Kehin series.
Uni it is. I've never had a K&N - but I hear of a few members that have them.
One more question - I noticed my KLX has dogbones labeled 117mm. Is this the stock length or did I inherit a shorter set designed to raise the rear?
Old 05-19-2012, 06:19 AM   #6793
bcliff
Oddometer: 147
+1 on the Sargent
bcliff is offline   Reply With Quote
Old 05-19-2012, 08:42 AM   #6794
IDRIDR
IDRIDR's Avatar
Oddometer: 1,488
Post #5839 may help with your jet questions, or search this thread for "jet conversion chart". http://www.advrider.com/forums/showp...postcount=5839
Old 05-19-2012, 06:53 PM   #6795
djchan
djchan's Avatar
Oddometer: 1,173
Thanks IDRDR. I finally ordered a couple jets (122 and 125) from RMATV. Decided to keep it in the Keihin family since I'll be using the N1TC needle from my old KLX300. I think the N1TC is designed to work with the inner profile of the keihin jets but I wouldn't wanna bet on that same situation with the DJ jets I had on board.
Also picked up a Uni, 13T front, new front tire and a few other goodies.
Times are GMT -7.   It's 04:26 PM.
