Old 08-22-2012, 10:30 AM   #7171
brieninsac
brieninsac's Avatar
Oddometer: 206
Does the cam adjuster add anything in performance and is it an easy install?
2012 Kawasaki KLX250S
Dynojet • FMF Q4 • K&N Air Filter • KDX Snorkel • RAM Mount
15/42 • Pirelli Scorpion MT 90/AT • Pro Moto Rack • Seat Concepts
brieninsac is offline   Reply With Quote
Old 08-22-2012, 10:58 AM   #7172
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
No, and yes in that order. :)
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 08-22-2012, 11:03 AM   #7173
CHECK_OIL
CHECK_OIL's Avatar
Oddometer: 369
Rob
+1
Do it...If the cam chain jumps ur F-ed
CHECK_OIL is offline   Reply With Quote
Old 08-23-2012, 10:59 AM   #7174
Aron31
Aron31's Avatar
Oddometer: 113
[IMG]Photobucket Pictures, Images and Photos[/IMG]
Took a little video. Don't know if it anyone can hear the noise. It's just a light ticking.
I removed the tensioner and made sure it wasn't gummed up or anything. Made sure it went all the way out. Then reset it and put it back in. It only clicked about twice before it stopped. So it wouldn't appear the chain is wore or anything. Maybe checking the valves wouldn't hurt. At least would rule that out. Anyone have specs for an 09. My kawi manual hasn't come in yet.
I would just buy a tensioner at this point if I hadn't just dropped over 500 on my klr to get it back in good running condition. So the tensioner will have to wait at least another pay period.
My 2008 Klr 650 (orange)
Wife's 2008 Klr 650 (red)
Aron31 screwed with this post 08-23-2012 at 11:10 AM Reason: Damn video didn't work
Aron31 is offline   Reply With Quote
Old 08-23-2012, 11:08 AM   #7175
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
I can't play the video at work to listen... but can you hear it at idle? If so, get a long screwdriver and use it like a stethoscope and see if you can pinpoint where the sound is coming from. If it's coming from the head area, then it might be the valves.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 08-23-2012, 11:09 AM   #7176
Navin
Navin's Avatar
Oddometer: 8,159
Does it go away with slight RPM increase? Is there a centrifical decomp on the cams? Those can tick a bit, might need an idle adjustment?
Navin is offline   Reply With Quote
Old 08-23-2012, 11:25 AM   #7177
Aron31
Aron31's Avatar
Oddometer: 113
Well I tried several ways. Video just won't work... Damn photobucket.
I can hear it at idle. With slight rpm increase it goes away. But approaching 6k comes back again.
Old 08-23-2012, 12:06 PM   #7178
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,488
video works for me. I don't hear the classic "rocks shaking in a coffee can" sound like mine did, but it's hard to tell on my cheapo laptop speaker. Around 6K rpm is the right range though for a CCT issue.
IDRIDR is online now   Reply With Quote
Old 08-23-2012, 01:13 PM   #7179
Aron31
Aron31's Avatar
Oddometer: 113
Oh I see. It just doesn't have a pic preview. Just the "?" thing. But if you click on it it will still take you to the vid.
Old 08-23-2012, 01:59 PM   #7180
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,464
Originally Posted by Aron31 View Post
...I can hear it at idle. With slight rpm increase it goes away. But approaching 6k comes back again.
Originally Posted by IDRIDR View Post
...Around 6K rpm is the right range though for a CCT issue.
While I'm always skeptical of internet troubleshooting, and I can't say for sure I hear it in the video, by your description it really does fit a cam chain tensioner problem. At least in early stages you may hear it at idle, and it becomes very prounounced in the 'approaching' 6000 RPM range, then quiets back down at higher engine speeds. Have you ridden it since removing and reinstalling the tensioner? As a temporary measure, you may want to try the method of 'manually adjusting' the automatic tensioner, just to see if it quiets it down.
Lutz is offline   Reply With Quote
Old 08-23-2012, 02:05 PM   #7181
IDRIDR
IDRIDR's Avatar
Oddometer: 1,488
Yes, fair method of diagnosis, but keep it "temporary" as Lutz suggests. Krieger gives a very good explanation of why this method puts too much tension on the cam chain and can be damaging.
Old 08-24-2012, 08:32 AM   #7182
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,678
Axle f/r diameter?
Anyone happen to know the axle diameter of a 2007 KLX250S?
Old 08-29-2012, 05:41 PM   #7183
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,397
Does anybody know for sure if the IMS fuel tank for the KLX300 will fit on an '06 250? I see a lot of conflicting info on the web.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 08-29-2012, 06:54 PM   #7184
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Well, I think the conflicting info centers more on the KLX300 tanks fitting the '09 and later models. I have the '06 KLX250S with the KLX300 Acerbis 3.7 gal. tank. Fits perfectly. The '06 and '07 250S are the same bike. I think the major differences came with the '09.
TNC is offline   Reply With Quote
Old 08-29-2012, 08:27 PM   #7185
djchan
djchan's Avatar
Oddometer: 1,173
SW Motech skidplate for 250S?
I had another member offer to sell a SW Motech skid but can't find a lot of info anywhere. No one seems to recognize it at the Kawasaki forums.
Does anyone have pics of this plate on the bike?
I see the pics at Twisted Throttle (not installed on a bike) and it has an odd angular look with a lot of cutouts. Might look great on the bike though.
Good/bad feedback from real users?
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Times are GMT -7.   It's 09:51 PM.
