Old 09-09-2012, 03:09 PM   #7201
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,794
Originally Posted by Rob.G View Post
CorNut and I at the Oregon Dunes today. His bike, my quad. Woulda brought my bike too but it's impossible to get both bikes and a quad in my truck without a trailer.
Rob
Is that paddle tire on the back of the KLX? Wild.
cjbiker is offline   Reply With Quote
Old 09-09-2012, 07:51 PM   #7202
Dan888
Dan888's Avatar
Oddometer: 427
Originally Posted by deej View Post
NICE!!! 06/07 in my opinion are the best years made.
Deej is half right
07 all the way
Nice looking bike there.
Dan
Dan888 is offline   Reply With Quote
Old 09-09-2012, 08:14 PM   #7203
CorNut
CorNut's Avatar
Oddometer: 23
it is, was a lot of fun
2012 Kawasaki KLX250S
CorNut is offline   Reply With Quote
Old 09-10-2012, 09:00 AM   #7204
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Yep! It fit. Barely. That little plastic shield that hangs down in behind the rear shock got a few inches snapped off. And when the rear suspension bottomed the first time, the reflector on the tail kit went bye-bye. I can only imagine what that tire would have done to my KLX, since it was lowered 1" with dogbones.
The bike did okay in the sand. I'd call it "passable." The poor KLX is just so underpowered. The only way it went anywhere was because of the paddle tire. You had to wind out 1st gear before 2nd was useful, otherwise it'd just bog. We could both get it up into 3rd gear for some 40-mph running on the flatter areas. Mild hills were okay, but anything steel was out of the question. BTW we put a 13T front sprocket on before the trip.
Cory did great, though! He went from no sand riding experience at all to being pretty darn good at it by the time we had to call it a day yesterday afternoon and head home. Trails are hard to do because we can't carry enough speed to keep the thing upright very easily. It turns into a major workout. He has long legs so it worked well for him. When I would try to ride it on trails, I would dump it almost immediately.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 09-10-2012, 01:00 PM   #7205
Jon
Jon's Avatar
Oddometer: 1,287
Has anyone fitted an '09 and up front fender to an early model? I noticed that the lower front fender on my 07 gets a lot of movement in high winds and wondering if a more aerodynamic front fender would make any difference in the buffeting. Replacing the front on my KLR with a KTM type and chopping one on an XR made a big diference. Just curious. Thanks
Jon is offline   Reply With Quote
Old 09-12-2012, 05:43 PM   #7206
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,397
I goofed.
So tonight I did the taillight swap on my '06 with an Acerbis unit to replace the stock one. As I was hooking everything up I got some wires crossed (for just a second) and noticed my headlight went out. I pulled the bulb and can't tell if it's fried or not.
Everything else works...brake light, signals, dash panel, etc. So did I fry the bulb or is that circuit fused?
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 screwed with this post 09-12-2012 at 05:47 PM Reason: Thank-you, auto-correct.
Bultaco206 is offline   Reply With Quote
Old 09-12-2012, 05:54 PM   #7207
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Can't remember...does the headlight have it's own fuse? I'm betting you blew a fuse.
TNC is offline   Reply With Quote
Old 09-12-2012, 06:09 PM   #7208
Bultaco206
Bultaco206's Avatar
Oddometer: 2,397
That's what I'm asking. I know there's a main fuse under the seat but don't see one listed on any wiring diagram. To the naked eye the bulb looks fine.
Old 09-12-2012, 06:14 PM   #7209
250senuf
250senuf's Avatar
Oddometer: 2,407
I doubt that an incandescant bulb is polarity sensitive. LED, yes.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 09-14-2012, 04:50 PM   #7210
Bultaco206
Bultaco206's Avatar
Oddometer: 2,397
Well, there IS a pair of fuses wired just down from the main fuse off the battery. Evidently when you accidently short out your new Acerbis taillight assembly during installation, it takes the fuse. Hence, no headlight or taillight.
Crisis averted.
Old 09-14-2012, 08:22 PM   #7211
djchan
djchan's Avatar
Oddometer: 1,173
I was wondering about LEDs being polarity sensitive. I helped a friend replace some rear blinkers with LEDs on the a CRF230. The lights must be wired directly off the battery cause you can turn on all the lights without the bike running. The LEDs didn't work.
I turned the wires thinking it must be polarity even though I've never had an issue with LEDs before. Still didn't work.
Are LEDs designed for DC only or AC only?
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Old 09-14-2012, 08:42 PM   #7212
Jon_PDX
Oddometer: 1,117
Most LED's are designed to run off DC voltage. There are some (tr-i color) that will run off AC voltage but that does not apply to your aplication.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 09-17-2012, 06:16 PM   #7213
DurtDevil
DurtDevil's Avatar
Oddometer: 69
Handlebar vibration
Anyone have solution for this? Just did long ride 600+ over weekend and fingers hurting. Used all the tricks - light grip, change grip, use palm of hand, shake out hand regularly - but nothing worked. Tips still hurt days later, after having done a few of the trips the last couple of years. Have Zeta hand guards, 351, and D606s. Bike was comfortable and capable enough in all regards but handlebars. Bike does see primarily woods, so I need to keep it trail worthy. But on these spring/fall adventures I need a solution (do Barkbuster B66s work/weigh enough to be wortthwhile?) besides a different bike which may be added in spring. But NOT replacing, this bike is way too much fun with the 351... Thanks.
2007 KLX351S, lots of farkles, even more scratches
DurtDevil is offline   Reply With Quote
Old 09-17-2012, 06:24 PM   #7214
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,196
Vibranators (http://www.vibranator.com/) I have 'em on my DR650, makes a world of difference. Also get a CrampBuster. That allows for a more relaxed hand position.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 09-17-2012, 06:32 PM   #7215
DurtDevil
DurtDevil's Avatar
Oddometer: 69
Rob
Sounds more like something for my wife, but I'll check it out.
Thanks Rob
Times are GMT -7.   It's 09:18 AM.
