Old 12-07-2005, 11:01 AM   #1
Jarvis OP
DC GSer
Jarvis's Avatar
Oddometer: 10,882
anti-seize?
I'm putting a new sparky in the Stella and have the following (simple?) question:
Do I put anti-seize on the threads? If so, what flavor?
Thanks,
Support DC voting rights.
Jarvis is offline   Reply With Quote
Old 12-07-2005, 11:07 AM   #2
VespaFitz
No-good-son-of-a-bitch
VespaFitz's Avatar
Oddometer: 41,051
Thanks,
Liver and onions.
My other car was crushed by the Feds
AKA "Ham Steak" - Bumfucked Hillbillies MC
VespaFitz is offline   Reply With Quote
Old 12-07-2005, 12:56 PM   #3
Joe Dirt
Joe Dirt's Avatar
Oddometer: 236
I wouldn't bother but I don't see a problem with it. Don't goop it up though. Flavor? I didn't know there were different flavors of anti-seize. If you're confusing anti-seize with thread-lock then step away from the Loctite. Thread-lock on a sparkplug would be bad.
2007 KTM 990 Adventure
Average Joes View Of The World
Joe Dirt is offline   Reply With Quote
Old 12-07-2005, 02:26 PM   #4
DMZ
Castor Bean Addict
DMZ's Avatar
Oddometer: 10,119
When I was a diesel mech on a crab boat we used a product called John Crane, (which we called John Wayne), on everything. It was good for engines that run 24/7. Nothing worse than spinning the head off a bolt during a quick disassembly at sea.
DMZ is offline   Reply With Quote
Old 12-07-2005, 03:55 PM   #5
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,283
Like everything else on internet forums, there is a debate about anti-seize on sparkplugs. Use a very small quantity if any. Sparks plugs shed their heat through contact with the cylinder head and anti-seize can act as an insulator. I use a silver based anti-seize on the aluminum heads on my car but they are a pain to get at and are likely to be neglected. Silver is one of the best electrical and thermal conductors so it should be okay in small quantity on plugs. The brand name is "Silver Goop". It is quite expensive, something like $35.00 for that tube. I obtained it from a previous employer.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 12-08-2005, 12:15 AM   #6
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
I would reccomend a copper based anti-sieze for a couple of reasons...
1. It handles the heat better than the usual stuff (aluminum) since it will stay in a paste or liquid state longer (the aluminum stuff cakes up with the heat).
2. copper is a better conductor than aluminum (a minor point)
If you can find the silver stuff that would also be better than the aluminum, but the copper stuff is readily available.
Be sure to use the smallest amount possible, you don't want any on the ceramic or electrodes.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 12-08-2005, 06:29 PM   #7
Jarvis OP
DC GSer
Jarvis's Avatar
Oddometer: 10,882
A wealth of knowledge, as always. Thanks!
(Except for VespaFritz. )
Old 12-08-2005, 06:32 PM   #8
BikePilot
BikePilot's Avatar
Oddometer: 11,251
I've always used antizeize on 4-strokes, a little dab of whatever was handy - usually the grey or copper colored stuff. I've never bother on two strokes as they seem to autolube their plug threads I've also never had a plug get stuck or suffer anything related to thread prep or lack there of.
BikePilot is offline   Reply With Quote
Old 12-08-2005, 06:39 PM   #9
S/W
S/W's Avatar
Oddometer: 396
never sieze
Exhaust flange bolts shoud get NS and any nut where corrosion can buid up.
This would include dissimilar metals, such as a steel bolt into aluminum. Also
stainless to stainless hardware should have NS if it is a softer stainless
(300 series). In a lot of applications with out high heat, Loctite can be used to prevent corrosion and lock the fitting.
S/W
S/W is offline   Reply With Quote
Old 12-08-2005, 07:08 PM   #10
Stephen
Stephen's Avatar
Oddometer: 3,197
S/W
Yup.
As to the sparker, it's a good idea, was SOP when I was a VW mech, and it doesn't matter what kind. It's not a space shuttle. I bought a tub back in 1971, and I'm still usin' it. It's molybdenum-based. Works good. But it doesn't matter.
Stephen is offline   Reply With Quote
Times are GMT -7.   It's 02:12 AM.
