Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-06-2013, 12:44 PM   #106
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,882
Originally Posted by Countdown View Post
You do know that the "arrow on the screen" is you (position of GPS).
If it (you) did not move at the same speed you are riding, you have exceeded the speed of light or some other theroy of relativity.
True
Zoomed way out on the screen the turns are not visible enough to see as you "ride along" the route. Much easier to follow along if zoomed in to where turns appear at the same time you are at the turn.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is online now   Reply With Quote
Old 02-22-2014, 05:32 AM   #107
Seth650
Seth650's Avatar
Oddometer: 464
www.gpsvisualizer.com ?
2011 WR250R 2009 DR650
Seth650 is offline   Reply With Quote
Old 02-25-2014, 01:18 PM   #108
ohgood
ohgood's Avatar
Oddometer: 3,004
Originally Posted by Seth650 View Post
+1
it's the bomb
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is online now   Reply With Quote
Old 03-19-2014, 08:38 AM   #109
divimon2000
divimon2000's Avatar
Oddometer: 629
On my 350, the track line shows up on the map only if you "turn the track on" under apps. You can turn on as many tracks as you want. My line does not move and there is no arrow. Fwiw.
divimon2000 is offline   Reply With Quote
Old 08-27-2014, 04:43 PM   #110
MikeL59
Oddometer: 3
Just purchased my first GPS, a Garmin 62s and I have a lot to learn. I have Basecamp and topo maps installed on my computer. I tried to copy a gpx file from this site and my computer wants to save it as a php file. Why? Not sure what to do next? I did some searching but no luck.
thanks
Mike
MikeL59 is offline   Reply With Quote
Old 08-28-2014, 04:40 PM   #111
250senuf
250senuf's Avatar
Oddometer: 2,424
Pretty normal, no idea why it does that though.
Let it save as .php then right click on the saved file, select "rename" and change the php to gpx.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 02-08-2015, 08:16 AM   #112
scfrank
scfrank's Avatar
Oddometer: 9,411
I've tried the gpx viewer and like it. Put some gpx files in dropbox. Opened dropbox in ipad mini and saw the files. Used open with to view. Easy. Need to try on road next.
It's a great topic for discussion, but the participants need to act mature.
scfrank is online now   Reply With Quote
Old 03-11-2015, 10:11 AM   #113
Deckyon
The Raven
Deckyon's Avatar
Oddometer: 356
Is there a way to take a GPX file and split multiple tracks out of it by date or track name?
Deckyon is offline   Reply With Quote
Old 03-13-2015, 03:58 AM   #114
5 Hour Butt
5 Hour Butt's Avatar
Oddometer: 127
The Way I Do It
I always use Garmin Basecamp because you can select the GPX file and right click it to get the options of what to do! I have taken many GPX files and converted them to routes that way. I hope that helps!
Now thinking about changing my joking UserID to 100 Hour Butt since I've lost 160 pounds and no more pain in the butt any more. . .
5 Hour Butt is offline   Reply With Quote
Old 03-17-2015, 02:44 PM   #115
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,994
You can open the GPX file in BaseCamp and copy whatever tracks you want to another LIST.
Or, you could just open a new TRIP in FURKOT and then using the FIND > My other Trips/Tracks > File on my computer, select the GPX file with the Tracks in it and once they are showing on the Map, just select the Tracks you want into the new TRIP.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 03-18-2015, 10:58 AM   #116
Deckyon
The Raven
Deckyon's Avatar
Oddometer: 356
I was looking to split type/days/years into separate tracks, but Furkot wont be the best as there are thousands of waypoints, and there is no way I am going through selecting them one at a time. Basecamp seemed to work, I will have to dig further and see.
2012: Saturday Gravel, Saturday Pavement, Sunday Gravel, Sunday Pavement
2013: Saturday Gravel, Saturday Pavement, Sunday Gravel, Sunday Pavement
2014: Saturday Gravel, Saturday Pavement, Sunday Gravel, Sunday Pavement
Each day and type have over 1000 waypoints, so you can see why I wanted something that could split them up. The file itself is a mess with everything all in one messy track.
Old 03-18-2015, 01:33 PM   #117
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
BaseCamp is a much better choice for editing a file like that.
Although, I must say, that is a huge number of Waypoints for a two-day ride when you are using Tracks to navigate. They must be very long days.
Furkot doesn't have a batch import mode for "Skipped" Waypoints. I have requested such a feature though - as well as "Skipped Tracks".
The more people that ask for them the more likely we are to get them.
Cheers,
Dan
All Things GPS
Old 03-18-2015, 01:43 PM   #118
Deckyon
The Raven
Deckyon's Avatar
Oddometer: 356
Here is what I finally got it to do. I have also reached out to Natalia as well about tweaking the import as well as selecting multiple waypoints.
This is the map with EVERYTHING: https://trips.furkot.com/ts/bA3Bxl
This is the map with Saturday Pavement: https://trips.furkot.com/ts/7wYVqA
This is the map with Sunday Pavement: https://trips.furkot.com/ts/bvk7cn
This is the map with Saturday Gravel: https://trips.furkot.com/ts/ZSMRjz
This is the map with Sunday Gravel: https://trips.furkot.com/ts/fbrQgf
This is the map with only Gravel: https://trips.furkot.com/ts/Wk3K4P
This is the map with only Pavement: https://trips.furkot.com/ts/UDuiVn
Old 03-18-2015, 01:52 PM   #119
DRTBYK
DRTBYK's Avatar
Oddometer: 5,994
As I noted with the Trip Import feature, when you have a file like this you have to remember that Furkot is going to try and stitch all of your Tracks and Waypoints together into a single route. It will be (was?) a mess no doubt.
I don't think there is anything that the Furkot Team can do to a file like that since they can't read our minds. This is why I made the "Build a Trip from Tracks" video as I think it is the most direct way to get a GPX file with combined trips sorted out. As for the batch "skipped waypoints", more folks need to ask for it and it will happen - I'm sure.
Cheers,
Dan
All Things GPS
Old 03-18-2015, 01:56 PM   #120
Deckyon
The Raven
Deckyon's Avatar
Oddometer: 356
Yeah, I finally got it to where I needed it, as you can see from the Pavement and Gravel maps (both days combined). My hope was that the import engine would read the dates on the waypoints and put them together.
I use Furkot a lot, and want to make it my only maping and routing app, and it is nearly there. This file was just something I was sent, and it only has a single year of the routes from the trip. I have another that covers 2012 - 2014. I havent even looked at it yet, even in Basecamp.
Times are GMT -7.   It's 03:53 PM.
