01-24-2010, 05:23 PM
#151 | |
Oddometer: 107
I spend a lot of time in that area and it is a confusing blend of deeded private property, leased state land that is treated like private property, BLM and Forest Service with leased grazing rights that shouldn't be treated like private property, and reservation property. The section where the questionable roads are located is private land. The questionable section of road with the gates and close proximity to the ranching operations can be avoided via a parallel road to the west. On the map below the blue line represents your track and the green line represents an alternative route. The alternative still crosses private land, but avoids the often closed gates and the ranch buildings. The black line represents the paved road out of San Mateo (I haven't indicated the whole paved section, just the portions close to the routes in question). The actual path of the legal county road is confusing (the county doesn't maintain it), but I think it follows the green line. ![]() I've attached a gpx file that provides a track of the alternative section. Howard |
01-24-2010, 05:42 PM
#152 | |
Fart Letter
Oddometer: 3,830
Confusing
Hi Howard,
This spot is getting confusing------this all came about because of some bicycle riders observation--and he gave the coordinates of the private spot and it is a few miles south of your new alternate route. And my buddy late this year rode thru using my track with no problem after the bicyclists said it was private--and talked to everybody he saw. thanks for the help Howard----we'll see how this plays out. No matter what---If a guy has problems it's no problem to find your way around. Nothing for riders to worry about. Mark Quote:
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" |
03-02-2010, 09:32 AM
#153 |
PAK-MEISTER.COM
Oddometer: 947
bump
03-04-2010, 08:02 AM
#154 | |
Deaf on Wheels
Oddometer: 2,048
Labrador Ride 2008: Alaska Ride with Sidecar- 2009: Newfoundland 2010 TAT 2011-2012 |
03-04-2010, 03:01 PM
#155 |
Oddometer: 178
While I wouldn't presume to answer for BigDog, (or any other GPS guru), one mistake that I made is trying to open gpx files when you don't have something to open them into. I tried various things (before I got a 60csx) to no avail (so I could study the routes) , then when I loaded the Mapsource file onto my PC and then downloaded his file- presto.
Maybe you've already done that, and I'm exposing myself to be a particular kind of dunderhead, but ..... Hope to see you on the trail-- I'm leaving Edmonton in early july. |
03-04-2010, 04:05 PM
#156 | |
Oddometer: 3,969
Like above said, do you have Mapsource?
Jerry Counts |
03-04-2010, 05:05 PM
#157 | |
Deaf on Wheels
Oddometer: 2,048
03-07-2010, 02:36 PM
#158 |
BAGSTR
Oddometer: 548
GD Tracks
Thanks BigDog for the Tracks. I will us them in conjunction with the Adventure Cycling Mountain Bike maps this August. The resources here at AdvRider are amazing.
PS At first I had difficulty opening the gpx file in Mapsource. Once I placed the file on my desktop, it could be drug into the open Mapsource page, and boom it was converted to gdb.
03-07-2010, 03:42 PM
#159 | |
Fart Letter
Oddometer: 3,830
Although there are many places where your rig will have many other problems. There's a creek crossing where the sidecar will float. Then there's the impassable when wet roads where a 200lb. 250cc bike can't move till it dries out. There is one really steep nasty hill that is rutted and washed out----I've owned many a sidecar rig--your rig won't make it up that hill (going South) but probably could be pushed end over end tearing it into pieces going down with gravity giving you a big shove. I'm not kiddin'. This is the easy way
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" BigDogAdventures.com screwed with this post 03-07-2010 at 04:01 PM |
03-07-2010, 08:20 PM
#160 | |
Deaf on Wheels
Oddometer: 2,048
03-07-2010, 08:34 PM
#161 | |
Oddometer: 3,969
Jerry Counts |
03-08-2010, 08:02 AM
#162 | |
Noob
Oddometer: 1,739
Mark,
I think you by passed this piece along the old railroad line just before going into Yellowstone\Teton. At the end the tunnel is blocked and you have to go around a narrow path--don't think the side car will make it. ![]() ![]() There are also a bunch--maybe 3-4 of these on the old railroad grade. ![]() This I think is where you think the side car might float ![]() I started out to check out the gates over north of Grants last Friday but got turned back by cold windy weather and the threat of rain\snow. Will get them checked out soon--today woke up to 2" or so of the white stuff--will have to wait until a warmer day. Will still get it done. Sy Quote:
03-08-2010, 08:13 AM
#163 |
Fart Letter
Oddometer: 3,830
Good Points
AKASY---you brought up some points I had forgotten. That old railroad grade where they had those metal ramps to go up a over----that was some brutal whoop--tee-doos thru there--------I hate woop--tee--doos
03-08-2010, 12:37 PM
#164 |
Deaf on Wheels
Oddometer: 2,048
Hi AKSAY and BIGDOG....
Any idea of how wide that cattleguard hump is? The total width of the sidecar n' bike is 68". Ground clearance is 13", so that's plenty. Oh, hell I can easily disconnect the sidecar and drag it over the grate... I have yet to download your GPx/CDT file as it doesn't seem to be downoadable with this Asus eePC and half asleep Mapsource. I wanted to scour the trail that has these obstructions and see whether I can by-pass some of them without having to backtrack too far due to gas availability. Slew the Canyonlands at MOAB.....hairy but got through... ![]()
03-08-2010, 04:14 PM
#165 |
occasional wanderer
Oddometer: 709
Old Railroad grade with cattle grates
There is an easy dirt bypass for the section with the collapsed tunnel. No problemo.
Bruce 2000 Suzuki DRZ400S, 2012 Yamaha Super Tenere My Great Divide Ride 2009 Great Divide Part 2 |
