09-17-2009, 07:17 AM
#16 |
Oddometer: 606
I'd have to dissagree with everyone who favours SV650. I had 2000 SV650, then I had 2005 SV650, and now I ride 2008 DL650. All three bikes I rode to work and back every day. These bikes were my basic mean of transportation. Vstrom is easier to manuver in the trafic, you are sitting up more and the handlebars are wider. It does not have as much pep as the SV650, but it is much more confortable and you don't need that much pep for the comute. Now SV is funner bike through the curvy roads, and on the freeway where you can just turn the throttle and feel the power. The same is with the Wee but not as drastic. If you like long rides, and if you are going to use the bike for your daily comute, my vote goes to DL650. This comes form a guy who had both bikes, and used them for commuting and long rides. Good luck.
Stroms will invade Poland |
09-17-2009, 07:35 AM
#17 | |
El cheapo
Oddometer: 4,873
IMO, SV is not more fun on the freeway, if anything the fairing and windshield on the WeeStrom make it more suitable for freeway riding. |
09-17-2009, 08:41 AM
#18 | |
Oddometer: 606
09-17-2009, 09:33 AM
#19 |
Man of Mystery
Oddometer: 984
Wow, old thread revival---but I have a (slightly farkled) 04 DL650 and a (moderately tweaked) naked Curvy SV650.
The DL is a surprisingly nimble bike (with that wide handlebar) with a sweet motor, practical (bright lights, straight up riding position, big luggage rack, comfy passenger accomodations, protection from the elements, really good range on a tank of gas. It also handles very neutral (maybe the 19" front / 17" rear tire combo?). The height of it is nice in traffic to see over cars...and maybe be seen by cars. Is a bit topheavy and can be tough to back up out of inclined parking spots of you are a little short on inseam. Somehow, the sv is a just happy puppy dog of a bike. Puts a grin on my face everytime, guaranteed. The lighter weight makes it much snappier than the DL and gives it better handling. The newer S models have an unnecessarily aggressive riding position, I think. For strictly in town or sport riding, I prefer the SV --until i need to pick up groceries, give my GF a ride, etc. The SV experience is more...visceral, with no big fairing in front of me, somehow it hits me right in the gut. The DL is so practical it hurts. SpaceManSpiff screwed with this post 09-17-2009 at 09:42 AM |
09-17-2009, 10:39 AM
#20 | |
El cheapo
Oddometer: 4,873
2009 Suzuki V-Strom 650 (DL650) - USA Specifications Model Number DL650K9 Type DualSport Warranty 12 month unlimited mileage limited warranty. Suggested Retail $6,999 Engine 4-stroke, liquid-cooled, DOHC, 90° V-twin Bore & Stroke 81.0 mm (3.189 in) x 62.6 mm (2.465 in) Compression Ratio 11.5 : 1 Fuel System Fuel injection Overall Length 2290 mm (90.2 in) Overall Width 840 mm (33.1 in) Overall Height 1390 mm (54.7 in) Seat Height 820 mm (32.3 in) Ground Clearance 165 mm (6.5 in) Wheelbase 1555 mm (61.2 in) Dry Weight 217 kg (479 lbs) Specifications: 2003 Suzuki SV650 Base Price: $5,899 Warranty: 12 mos., unltd. miles Engine Type: Liquid-cooled, transverse 90-degree V-twin Displacement: 645cc Bore x Stroke: 81.0 x 62.6mm Compression Ratio: 11.5:1 Valve Train: DOHC, 4 valves per cyl. Wheelbase: 56.5 in. Rake/Trail: 25.0 degrees/3.9 in. Seat Height: 31.5 in. Dry Weight: 165kg (375 lbs.) |
09-17-2009, 11:09 AM
#21 | |
Oddometer: 606
09-17-2009, 11:35 AM
#22 | ||
El cheapo
Oddometer: 4,873
09-17-2009, 05:13 PM
#23 |
Man of Mystery
Oddometer: 984
470ish pounds should be the wet weight for a DL650. Dry wieght is around 417 or so. ABS probably adds about 10lbs.
09-17-2009, 09:59 PM
#24 |
Man of Mystery
Oddometer: 984
470ish pounds should be the wet weight for a DL650. Dry weight is around 417 or so. ABS probably adds about 10lbs.
09-19-2009, 12:54 PM
#25 |
Uncouth Sloth
Oddometer: 977
Just picked up a SV650 '05 model naked. Did you know that you can add taller/wider bars to the SV to make it more upright? That's my plan. Several posts here criticizing the SVs bars. I'm gonna do it right and spend $20 whole dollars on some Bikemaster Daytona's.
![]() The DL650 feels like a pig on the street compared to the SV but that's only in my very limited experience on both bikes. Just happy to be free of the death machines called dual sports for road riding. I agree the SV wants to go fast but it's up to the rider whether it's appropriate to twist that throttle. That said, I can lug and chug and idle through parked traffic and then pull away like I robbed a bank. 0-60 in 3.5 seconds if necessary.
XR650L fun machine, CR250 modded for trail riding |
09-20-2009, 08:12 AM
#26 |
Oddometer: 275
In a nutshell, the DL650 is taller, softer, and more roomy. The SV650 is lighter, zippier, and a lot smaller (not great for us talk folks). The DL's high seating position is great in traffic, and although it is top-heavy, the wide bars and upright riding position make it very maneuverable. I plan to keep both my DL and my SV for a long time -- the SV for around town and the DL for long trips.
09-21-2009, 05:17 AM
#27 | |
Southern Ontario
Oddometer: 1,978
The '09 ABS DL650 is 485 lbs wet, according to Suzuki Canada website (http://moto.suzuki.ca/Product%20Lines/Cycles.aspx). The same site lists the SV650S ABS at 445 wet, the naked bike at 11 lbs less, 434lbs.
So the real weight difference between DL and SV would seem to be more like 50 lbs. Quote:
09-21-2009, 03:46 PM
#28 |
One wheel wonder...
Oddometer: 6,277
Anybody modded a DL motor to SV specs? This would be my plan if I got a Wee.
"Tough times don't last, but tough people do." Robert A. Schuler
09-21-2009, 03:55 PM
#29 | |
Southern Ontario
Oddometer: 1,978
10-07-2011, 09:32 PM
#30 |
Dodgin' the Ditches
Oddometer: 1,157
Old thread...
But today I found a good deal on CL for an 04 SV650S, 3400 miles for $2000. I got sort of excited, because I'd confused it with the V-Strom 650 which I knew was a upright riding "do-all" type bike. Anyway, I was disappointed when I saw the SV and realized that it had such low handlebars. I wasn't sure what was "wrong" but figured that I'd mistaken the VStrom's "letters". Oh well, "live & learn". Btw, if anybody here want's a nice 04 SV650 the guy's in Charlotte NC (btw, the rear brake doesn't work. It feels "dead" like there's no fluid in the res or the seals are shot. Probably not much to fix, but I don't know. Besides that it's a sweet looking bike.) His add says $2600 or $2500, but he said $2000 was good since the rear brake issue. I just didn't want that type of riding position. |
