Old 02-22-2007, 01:39 AM   #316
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,129
Where`s the ash tray??
nevgriff64 is offline   Reply With Quote
Old 02-22-2007, 02:08 AM   #317
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 19,960
Quit smoking... fast!
"Where's the ash tray?" Nev ? ... You just drop the glowing cig butt down that little hole under the black cap with the yellow hose in the middle... The nicotine craving dissapears almost instantly!
Originally Posted by Etienne;
"What ees all 'zis f5uss
fuss about...?"
troy safari carpente is offline   Reply With Quote
Old 02-22-2007, 02:15 AM   #318
Andrew2 OP
Team 250
Andrew2's Avatar
Oddometer: 5,215
Andrew2 is offline   Reply With Quote
Old 02-22-2007, 02:22 AM   #319
Andrew2 OP
Team 250
Andrew2's Avatar
Oddometer: 5,215
Old 02-22-2007, 02:28 AM   #320
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 14,129
would save a bit of money on Nicotine patches..
Old 02-22-2007, 02:35 AM   #321
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,107
NUMBER FIVE IS ALIVE
Mudguts is online now   Reply With Quote
Old 02-22-2007, 02:38 AM   #322
Mudguts
Mudguts's Avatar
Oddometer: 2,107
If you want to know those lights are the same as the sachs madas ( sachs are plactic thou) and not HID . So not really the same but look cool!!!!!
Old 02-22-2007, 02:45 AM   #323
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,489
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 02-22-2007, 03:36 AM   #324
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
I was siting here thinking how trick is the adjustable roadbook holder mount -
But then I though it only alows you to adjust the angle, like a normal mount does, but it requires more work to do so? (this shows my GPS holders, but the RB holder mounts the same way)
KTm's getting as bad as BMW putting extra crap on bikes for the looks, not the function.
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 02-22-2007, 04:25 AM   #325
Team f5ool
Oddometer: 19,960
And whats up this sleeve...?
What the picture doesn't show is the elongated holes that allow the nav pod to be raised and lowered also... Thats why the the turnbuckle strut for adjustability/stability.
I'm sure the boy's in the back room at Mattighoffen will be kicking themselves when they see your trick state of the art "hot water pipe bracket" GPS mounting solution Rhys...
PS: About the "putting extra crap on bikes for looks... not function" bit...
I always wondered what level of protection a protaper bar/clamp pad offers when one has a solid aluminium RB holder, tripmeter cluster, GPS, washer dryer and espresso machine mounted ABOVE them... It's not like it's the steering head that's gonna be the first thing your melon or chest comes in contact with ist it!
... Oh... you say it's for the "fambily jubels"... better get rid of that acerbis gas cap then too...
fuss about...?"
Old 02-22-2007, 05:44 AM   #326
rjf
rjf's Avatar
Oddometer: 4,376
What the picture doesn't show is the elongated holes that allow the nav pod to be raised and lowered also... But only the bottom hole is elongated, Troy, so it only alows for a change in angle.
Also, the the bolts for the elongated and non-elongated holes have rubber mounts, yet the struts don't. So the struts give it extra strength, but allow more vibration through. Thats why the the turnbuckle strut for adjustability/stability.
I'm sure the boy's in the back room at Mattighoffen will be kicking themselves when they see your trick state of the art "hot water pipe bracket" GPS mounting solution * Rhys... So they should, does the same job, only 2 bolts to adjust it (not 4 and 2 struts) and it'll rotate in an impact (from the riders head / chest / love spuds )
If figure put as much crap up there as posible, to spread the impact over a bigger area of your body and disipate the energy in a less concentrated, severe manner
* "My" trick state of the art "hot water pipe bracket" GPS mounting solution is actually
Part Number:58212090144
Description:ROADBOOK CARRIER CPL. ADV. 01
So the boy's in the back room at Mattighoffen actually designed it too
Old 02-22-2007, 05:54 AM   #327
Team f5ool
Oddometer: 19,960
Clarification...
Reply from TSC:
When I mentioned the rb brackets... I was refferring to the copper brackets not the frame... the frame is indeed a KTM part as you correctly point out
fuss about...?"
troy safari carpente screwed with this post 02-22-2007 at 06:31 AM
Old 02-22-2007, 06:05 AM   #328
rjf
rjf's Avatar
Oddometer: 4,376
Re : Clarification
copper !!! Thats annodized steel buddy ....
and there from Touratech, I have good idea's, terrible construction skills.
earlier today I spent about 1/2 an hout attempting to remove the float bowl. Fooking screws still didn't budge. I sense a dremel in there future.
Thakfully I redemed myself, as I just put the forks, shock and swing arm back on the 640. all in correctly, to the corect torque. took me about 3/4 of an hour.
Old 02-22-2007, 06:21 AM   #329
Mac
Mac's Avatar
Oddometer: 2,145
V-Max Enduro
I don't know if it was ever mentioned, but your thread just caught my eye. I see this thread is old and has morphed into something completely different, but as a former Vmaxxer, I've see than Enduro Vmax. It is basically a display bike made by F. Maerz Vmax in Germany. They are Vmax nuts and work on almost nothing else.
http://www.v-max-f-maerz.de/
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 02-22-2007, 06:24 AM   #330
Team f5ool
Oddometer: 19,960
KTM nerds swapping yarns...
You see; there was this swedish koala, a frenchman and a bloke from Gosford sitting in a bar...
As far as the RB mount on the new LC4 Rallye goes... I couldn't find a picture (better than this one or the one that you printed) that shows it in greater detail... but I was under the impression when I saw the bike that the rubber mounted upper mounting bolts (yellow arrow) had slotted holes (in the aluminium subframe plates behind) that allowed for adjustment... (I could be wrong).
As far as the turn buckle struts are concerned... IIRC I think that the bottom mount (to the frame head stem) is a rubber bushed heim joint... for compensating for the "vibes."
If not... then you have something to tinker with when you pick your up from the dealer later next month RJF...
Regards your float bowl screws... were they those "impossible to unscrew with a phillips head driver without chewing out the screw head cheap shit M6 Mikuni" type screws...? I replaced mine with M6 metric hex heads on my old LC4 for just that reason...
Cheers!
fuss about...?"
Times are GMT -7.   It's 12:22 PM.
