Old 01-10-2006, 11:58 AM   #16
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
Originally Posted by ZZR_Ron
Screw that flasher stuff. Do you want the schematic for one of my vest controllers? Simple and effective. You have to order a special transistor though, they have a low "on" resistance, which means you don't have to use a heat sink.
YES
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 01-10-2006, 12:08 PM   #17
Gringo
simple by nature
Gringo's Avatar
Location: a small drinking village with a fishing problem
Oddometer: 1,349
I've done four garments like this - I used 28Ga. wire, and for my next I would probably use 30Ga. to reduce the amt. of wire needed to to get the same resistance; weaving the wire into the jacket with a needle is tedious work. These things work well, if you use the right kind of jacket as a base. First I did an old shelled fleece jacket and that was not too satisfactory since the fleece was between me and the heater wires; next I got a poofy quallofil down-like jacket that worked better but it was hard to keep the wires close to the inner liner fabric in such a loosely-quilted jacket, and also that sort of jacket compresses too easily whereever your outer jacket is snug, so you still get cold spots. My most successful one so far was the diamond-quilted liner that came with my wife's IXS 'Sheila' jacket - I measured enough wire for resistance that would give 45W of heat but she has still complained it's too hot (but being from a tropical country, she doesn't ride below freezing), so I'm gonna have to get some kind of heat controller to step it down. She actually got a burn on her arm from where I left a tiny bit of wire exposed where it poked out as I crossed over one of the quilt stitches - she was using it on the interstate in summertime wearing only a T-shirt underneath, she said one spot felt real hot and when we stopped she had a little blister on her arm. So be meticulous about burying your wires well, or wear full coverage clothing underneath.
After I had good heat up top, I even tried to add heat to the legs of my old 1pc Aerostitch. I took all the wire I had left over and ran it up and down beneath the inner liner around the thighs. It worked but not great - too patchy - you do need a little insulation behind your wires to get the most out of your heaters.
Next project is to wire up the liner of my Motoport jacket, just in case I ever need it. So far though, it's been warm enough without any help from Georg Ohm...
- Gringo
"I mean seriously, what is funnier than Helen Keller" - Mutineer
"Ah, yes, Greasing the nipples is really the cure all for a whole host of ailments." - Stagehand
Gringo is offline   Reply With Quote
Old 01-10-2006, 12:19 PM   #18
xtphreak
xtphreak's Avatar
Oddometer: 7,963
my version of the e-vest
ok this cost like twice what the roll of wire etc etc costs
seems it was $50
I had a fleece ski vest $0
heating panels from Kreamer Sports $50 (I think)
SAE plug (2 for $1.99 @ NAPA)
roller lamp switch ($1 Lowes)
12v LED ( $2 @ Radio Shack)
the panels are like a silicon rubber panel inside a nylon pouch, they said you can sew right thru it with no prob
the surface temp is like 104 deg F (I think they said)
they come in a pre-wired set of 3 (I have one each side of my chest & the center one over my kidneys)
I'll tell ya this ... they get really warm for 24 watts of power
I got two more panels for my biceps, just never have added them in
the glove liners are abso-fukin-lutely great
15 watts ... uninsulated gloves
no handguards
no cold fingers
Robert A. Heinlen
1999 Tiger 885
1995 XT600E
xtphreak screwed with this post 12-17-2009 at 05:39 AM
Old 01-10-2006, 01:53 PM   #19
ZZR_Ron
Looking up
ZZR_Ron's Avatar
Oddometer: 8,188
I built my heated vest from a 10 dollar heated car seat at WalMart...
but I don't know if they sell them in the USA.
About 50 watts. Lots of heat!
Great minds think alike;small minds seldom differ...
ZZR_Ron is offline   Reply With Quote
Old 01-27-2006, 11:35 PM   #20
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,582
Toasty warm
OK, here's a brief description of my trials & tribulations in building an electric jacket that wouldn't (immediately) immolate me.
http://www.crystalinks.com/shc.html
Step 1: Pick up a cheap pile jacket & a cheap nylon jacket with mesh liner. Pile jacket: $10 at Target. Cheap 2nd hand golf jacket: $8.
Here are a couple pics of the nylon jacket. Finding something with a thin shell & a mesh liner is critical. The shell will become the part laying against the rider, and the mesh will hold the woven wire:
Mesh Liner:
Step 2: Obtain some stranded 30ga wire with teflon insulation. Newark doesn't carry it any more, but I found some at www.mouser.com
For white wire, the p/n is 566-83000-100-09
Cost for wire: ~$24 with shipping. I used less than half of the 100' spool.
Step 3: Decide how much heat you want and cut the appropriate length of wire. Wire resistances can be found at http://www.powerstream.com/Wire_Size.htm
Power = Voltage^2/R. Important: remember that your operating voltage isn't 12V, but ~13.5V for a system that is charging. This is very important since the power is proportional to the voltage.
I selected a length of ~40feet to give me a power around 40-45W.
Step 4: Turn the windbreaker inside out & weave the wire thru the mesh using a large needle. I wove some thru the collar area, the upper arms, back and front of the jacket. I ran a higher weave density in the collar and front of the jacket than I did in the back. Here are a couple shots of the wire in the mesh liner:
Step 5: Place the liner into the pile jacket & stitch into place. Put in suitable power connectors (& a 5A fuse). I sewed them together along the lapels, and the ends of the sleeves. I left the bottom unstitched until I was done fiddling with my wire distribution. I ended up reweaving a couple of sections due to hot spots. When I was finished I basted the bottom together in 5 spots.
Here are some of the finished pic's:
I experimented with the power connector & switch. I wanted a lighted rocker, so I kludged one into the wiring. For the power connector I chose a co-axial type for an easy disconnect, should I forget to unhook myself after dismounting.
That's about it. After a couple rearrangements of the wiring, I'm very happy with the warmth. The heated collar is great. Heating the upper arms is very nice. There's still plenty of power left over for the torso.
Here's hoping that I don't become a human transformer the first time I ride under some high-tension power lines.
-Jeff-
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle screwed with this post 01-27-2006 at 11:48 PM
HellSickle is offline   Reply With Quote
Old 01-28-2006, 07:56 AM   #21
Mimosa
Oddometer: 49
Total cost including labor?
You said you were an engineer. Props for the DIY project, but if you factor in how much labor/time costs, it would have been easier to buy off the shelf.
Jacket liners cost from $150-200
-mim
Mimosa is offline   Reply With Quote
Old 01-28-2006, 08:23 AM   #22
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Mim
Im with Jeff! There is a certain satisfaction that a lot of more 'sensible' monetary wise individuals just won't couldn't and will never either appreciate of understand - the satisfaction of having made or built it yourself.
Absolutely nothing wrong with that and I wish I was sometimes able to excercise the sensible approach more, but hey like I say Im with Jeff, you made it buddy, let someone else buy one!
Great post and thanks for sharing!!!!
Pilbara is offline   Reply With Quote
Old 01-28-2006, 08:42 AM   #23
ebbo
ebbo's Avatar
Oddometer: 150
I had a go at this a couple of years back, it worked well. I used 28awg wire as I couldn’t get anything as fine as 30awg at the time. I followed the iron on stichwitchery route but when the wires got warm it softened the bond and the wires dropped off the liner I would use the needle and thread route next time
These were the sources for my build.
http://www.ibmwr.org/otech/heatedclothing.html
http://webpages.charter.net/hondapotamus/heat.htm
http://www.ridemyown.com/articles/ot...clothing.shtml
Martin Ebdon, England,
R1200RT replaced by MX5
ebbo is offline   Reply With Quote
Old 01-28-2006, 08:49 AM   #24
SKSLT05
MountainBeemerDreemer
SKSLT05's Avatar
Oddometer: 5
Originally Posted by HellSickle
Hey, maybe it will be easier to trip traffic signals?
-Jeff-
Let us know on THAT one, Jeff!!!
SKSLT05
We sack, we ransack to the utmost sands
Of native kingdoms, and of foreign lands:
We travel sea and soil; we pry, and prowl,
We progress, and we prog from pole to pole.
BMWMOA#:122975
BAM#: 984365
SKSLT05 is offline   Reply With Quote
Old 01-28-2006, 11:26 AM   #25
HellSickle OP
Scone Rider
HellSickle's Avatar
Oddometer: 9,582
-mim
Total material cost was ~$45. My engineering consulting rate is $125/hour. I spent perhaps 3 hours on the jacket. Thanks for the tip! I'm headed for Ebay to sell this baby. Reserve will be set at $400!
I like doing these projects. Invariably, I will learn something that I can apply somewhere else. Perhaps more heated garmets. Perhaps an invention for another product. You never know where the knowledge will come in handy.
Besides, now I have something that is Exactly what I want. No compromises.
Widder electric vests go for $100+. They don't have heated arms. The electric jackets I've seen go for $200+. If either of these items were to break, I would probably be SOL. Since I built mine, I can repair it.
Perhaps you should reread ZAMM by Pirsig. It's not about the item itself. It's about having an inate understanding of the substance of these things.
-Jeff-
Old 01-28-2006, 11:33 AM   #26
ZZR_Ron
Looking up
ZZR_Ron's Avatar
Oddometer: 8,188
-Jeff-
Personal satisfaction of knowing you built it: Priceless!!!
Old 01-28-2006, 12:37 PM   #27
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,067
Thanks for the write-up! This has been a plan of mine for several months now. As soon as I get back to Germany, this project is one of the first on my list!
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
walrond is offline   Reply With Quote
Old 01-28-2006, 02:14 PM   #28
Vesa
HappyHappy JoyJoy
Vesa's Avatar
Oddometer: 202
-Jeff-
Cheers! Guess who just ordered a 30m roll of 30AWG wire for a whopping 12,30€
Vesa
http://www.moposivut.com
Vesa is offline   Reply With Quote
Old 01-28-2006, 04:20 PM   #29
KL5A
Bugs are the new black
KL5A's Avatar
Oddometer: 4,486
Here's mine-
http://www.advrider.com/forums/showthread.php?t=54013
It's worked fine for me.
I just got back from a shopping trip. I couldn't find the heated car seat pad at wally world, but I did find the 555 timer and the MOSFET I needed at Radio Shack so I guess I'm building a controller this weekend!
Northern Hydraulics had a 12v electric blanket in their catalog-another possibility!
Now a word for the naysayers out there....
We are sorry that you don't have the ability or the understanding to undertake such a task. Kindly refrain from telling us that we are going to die as an inevitable result of our experimentation . Thanks for your cooperation.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Only dead fish go with the flow.
KL5A is offline   Reply With Quote
Old 01-28-2006, 09:56 PM   #30
dwillie57
Oddometer: 53
At some of the larger truck stops, you can find the 12v electric blankets the truckers use to keep warm in their cabs while sleeping. I've seen full size blankets selling for less than $20.00 They already have power conectors and the wiring istalled. Tear off the fabric and attach the wires to the vest of your choice and you're all set. d.
dwillie57 is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
