01-29-2006, 08:02 PM
#31 | |
Viel Spass, Vato!
Oddometer: 25,809
Super thread! Thanks for posting. A few questions: 1. Where did you buy the coax connectors? 2. I assume you don't connect the 30 ga wire to the coax connectors, but instead to a larger, stronger wire which can handle the stress of human contact which then connects to the coax. Correct? 3. What ideas do you have re connecting your vest to, say, Gerbing's heated gloves? I suppose you'd run a separate (connected in parallel) wire from the coax to each sleeve where you would install another coax for the gloves? ![]() Thanks!!!
Gracie's Gold |
01-30-2006, 03:45 AM
#32 |
Underground
Oddometer: 7,473
Why don't you just use SAE connectors, Lobby? They're available anywhere, and are even the standard on a lot of commercially
built heated equipment.
Great minds think alike;small minds seldom differ... |
01-30-2006, 05:56 AM
#33 | |
Viel Spass, Vato!
Oddometer: 25,809
1. I've got some gerbing's equipment that uses coax connectors and would like to make everything work together. 2. SAE connectors, once together, require some force to pull apart. Being a bit of an airhead (me, not the bike), I sometimes forget to disconnect the clothings from the bike before walking away. With coax, everything just slips apart cleanly. But with SAE, I'd break wires and stuff.
Gracie's Gold |
01-30-2006, 09:08 AM
#34 | |
Scone Rider
Oddometer: 6,715
I often carry a small electric pump for the bike. It's wired to an SAE connector. Until I routed a non-accessory circuit for the jacket, my pump power came off the grip heater circuit, which was wired off the headlight power. This required me to run the headlight while operating the pump. With the engine off, this would quickly drain the battery. I'm glad I now have the extra circuit. The 2-wire SAE connector will stay tucked under the front of the seat until I need it. -Jeff-
We don't stop riding because we get old, we get old because we stop riding. |
01-30-2006, 09:11 AM
#35 | |
Scone Rider
Oddometer: 6,715
The 2-wire SAE connectors are securely anchored into the jacket pocket. The 30 gage wires are soldered and shrink wrapped to the 16 gage wire. I'd have to rip a big hole in the jacket to put any strain on the 30 gage wires. I run heated grip covers, rather than heated gloves. -Jeff-
01-30-2006, 09:12 AM
#36 |
Underground
Oddometer: 7,473
Im running exactly the same as you, but with out the coax connectors.
I keep the SAE connectors lubed up though, for my own klutziness. All my accessories are wired for them. I even have an SAE to cigarette lighter adaptor for my tail bag.
10-17-2006, 10:33 AM
#37 |
Adventure Poser
Oddometer: 1,062
OK, I've got my 30 ga wire threaded through the mesh lining of a thin cross-country ski jacket I had, and I'm trying to figure out a simple on/off switch. I was thinking of a "feed through" or "cord through" switch so that I can turn the jacket on and off without having to unhook it, but the only ones I can find are rated for 125V. If I get a switch rated for 10 amps at 125V, will it be able to handle the 3 amps of current I'm drawing at 12.5V?
2000 Shadow 750 (the "trainer") - Sold 2005 DL650 - The "real" bike Money gives back small echo to the cries of calumny. - Samuel Hopkins Adams Heaven and Hell are one and the same when desperation's all you can afford. - Warren Haynes |
10-17-2006, 10:38 AM
#38 | |
simple by nature
Location: a small drinking village with a fishing problem
Oddometer: 1,348
- Gringo ____________________________________________ "I mean seriously, what is funnier than Helen Keller" - Mutineer "Ah, yes, Greasing the nipples is really the cure all for a whole host of ailments." - Stagehand |
10-18-2006, 11:08 AM
#39 |
Underground
Oddometer: 7,473
Just thought I'd post a couple of things in here, in case they're useful to any one.
Here's the schematic for the heated vest controllers I built for me and some of my friends: (Paul Mondor will be using two when he crosses Canada this winter)
Great minds think alike;small minds seldom differ... ZZR_Ron screwed with this post 10-19-2006 at 09:04 AM |
10-18-2006, 11:11 AM
#40 |
Underground
Oddometer: 7,473
Here's the completed unit. I use the thos things for hiding keys as cases,
they have a nice hefty magnet to stick the tank. If your using a tankbag, just throw a fender washer in the window to stick it to.
10-18-2006, 11:15 AM
#41 |
Underground
Oddometer: 7,473
And here's a completed circuit board.
I've built about 40 of these for friends over the last few years.
10-18-2006, 12:13 PM
#42 | |
4,949
Oddometer: 5,998
It takes less time to do things the hard way than to be too nervous to even start at all. -Juanito on the Yahoo! |
10-18-2006, 12:14 PM
#43 | |
Adventure Poser
Oddometer: 1,062
http://store.qkits.com/moreinfo.cfm/MX033 The store-bought PWM costs $18 plus shipping, and the parts to make the thingy you made cost about $16. I think I might just buy the pre-made one, although it has been interesting to read about capacitors and such.
10-18-2006, 12:20 PM
#44 | |
Underground
Oddometer: 7,473
I am merely posting for anyone who's interested. If your not, don't bitch about it.
10-18-2006, 12:49 PM
#45 | |
Adventure Poser
Oddometer: 1,062
Again, my apologies for apparently touching a nerve. Sheesh!
