11-26-2006, 03:24 PM
#121 |
Oddometer: 1,868
just thought that some of you guys would like a scorce of cheap a** heating pads, matrix, or what ever you'd like to call them. the g.f. bought a seat pad that....now get this- has speakers and an amp. made for an mp3 player installed ina car seat cover. it also has a messager built in it and it's also heated! intended power is from the 12v car system. she won't let me rip it apart to find out the actual size of the heating elements..but from the look of the finished thing i bet it'd be just right for heated clothing and or heater seat. the price.....you can't beat this.....23$us at" bed, bath, and beyond"
11-27-2006, 12:32 PM
#122 |
Oddometer: 33
I would like to make some heated boots, instead of using heated socks. Just wondering if anyone has attempted to sew up some heated insoles that can be slipped in the boots, and how they worked.
I would also be interested in hearing from anyone who has attempted making their own heated gloves. |
11-27-2006, 04:04 PM
#123 | |
Underground
Oddometer: 7,519
elements, 34 watts total. they work like a charm. Wifey used white interface material from a sewing store, and ironed it all together, using black felt for the outside. Then she sewed it all into the vest. Here it is with the pads sewn in.
Great minds think alike;small minds seldom differ... |
11-27-2006, 05:10 PM
#124 | |
Stromer
Oddometer: 61
11-28-2006, 07:34 AM
#125 | |
from B4 "adventure bikes"
Oddometer: 7,658
the former company I got my carbon fiber heat pads and heated glove lines from sold the insoles too, I keep thinking about them, but my feet rarely ge that cold with good socks in my Oxtar Matrix boots.
Do one thing every day that scares you. Baz Luhrmann Women and cats will do as they please, and men and dogs should relax and get used to the idea. Robert A. Heinlen Adventure is discomfort recounted at leisure. Flash / GSWayne Chrome don't get ya home. Rob Nye Stamp Out Hoplophobia in Our lifetimes. 1999 Tiger 885 1995 XT600E
11-28-2006, 08:31 AM
#126 |
Von Hochstaden's son
Oddometer: 45,095
i wonder if I could run those car seat pads in my leathers for heated insulation
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
11-28-2006, 09:06 AM
#127 | |
Oddometer: 7,658
hell stick 'em in with velcro on the FRONT each side of the zipper on yer chest or sew em into a fleece vest ... damn why didn't I think of that? ![]()
11-28-2006, 10:39 AM
#128 |
Oddometer: 45,095
I was thinking as for in my leather pants actually ... I have vest, arm chaps and gloves now.
Bling!!
11-28-2006, 06:59 PM
#129 |
Oddometer: 322
alright....wired up my own gloves, they are hot as hell when plugged right into a 12V source....figured that might be nice, I'll just get a powerlet controller thru the group buy. The gloves still work, just now thru the controller. The output of the controller when at 100% gives the same reading as 12V source.
Why would they not work with the controller?
'04 R1150GS '95 R1100GS / URAL Sidecar '83 R80(S) '80 Suzuki GS550E / 70's Spirit Eagle Sidecar BMWMOA - 124346 ABC - 9079 |
11-28-2006, 07:14 PM
#130 | |
Oddometer: 7,658
is there any output at say 50%? you'll need a DMM that'll read pulsing DC or frequency, do the glove liners NOT work off the controller? how much resistance in each? wired series or parallel? what resistance in the vest?
11-28-2006, 09:24 PM
#131 | |
Oddometer: 322
yes there is output at 50% Glove liners do not work w/ controller hmmm - have to double check on resistance in gloves (they do get damn hot and quick with just source) wired in series The only vest I have is a BMW heated vest that came with the bike, I'll have to check that too - I did notice that the vest takes alot longer, alot, to heat up. The vest did seem to work with the controller. I'll double check resitances....
11-30-2006, 08:45 AM
#132 |
Oddometer: 33
I have been doing some testing with my teflon coated wire. I found that a 12.7 volt source pushed about 3.4 amps through 24 ft of of the 30 gage wire. I measured 9.35 volts at the ends of the wire with the current running through it and connected to the battery, but this was without the bike running.
I will need to do some more tests with the engine running to see how the alternator affects the current supply. One thing I am beginning to wonder, is if the teflon coating isn't actually acting as an insulator and keeping alot of heat in the wire itself instead of letting it transfer the heat out. Eventually I guess the teflon will get saturated and reach close to the same temperature as the wire, but I can't help but wonder if it isn't actually inhibiting the heat transfer process. It seems like you would want an insulator material that helps the heat transfer out of the wire for this application. This may require some more experimentation with different wire types to see what works best. Obviously you don't want it to get so hot that the wire melts the jacket, but if you use wire that transfers the heat better, you should be able to run a smaller current through it and achieve the same level of heat. I think? I need to do more testing. Will report my findings, if I don't spontaneously combust first... |
11-30-2006, 09:14 AM
#133 |
Underground
Oddometer: 7,519
Actually, I think Teflon transfers heat pretty well.
Hell, they use it on frying pans!
11-30-2006, 09:18 AM
#134 | |
Underground
Oddometer: 7,519
I didn't think it would work, but it does. It alos doesn't seem to matter to much about frequency, it still works. Usually, when I build a multi-controller, I use a lower frequency than the single ones use...
11-30-2006, 05:58 PM
#135 |
Oddometer: 33
Well, I think I gave up on the idea of heated socks. Too much sewing.
So just for fun, I slapped together some heated insoles with scotch tape temporarily holding on the wires just so I could test out the concept. It works amazingly well, and produces heat up from the bottom of the boot into my foot. The soles I used have some gel in them, so that helps spread out the heat nicely. And the soles can easily be removed from the boots when not needed. I have the wires on the underside of the insole. I tried it on the top and it increased the amount of heat I felt since the wires were right under my sock. Not sure which is the best side to put them on. I may try putting a layer of aluminum foil under the insole to reflect the heat up so less of it gets wasted heating up the sole of the boot. This might actually work. I think I may try to make this in a more permanent fashion. One insole draws about 5.6 amps, which is a bit much, but if I wire two in series, it should cut that in half, which may be just about right.
