Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 10-01-2012, 04:08 AM   #3106
leafman60
Oddometer: 1,885
The stock Hella aux lights have a reflector hood on the left left light that cuts the beam spread dramatically down. I assume this is a regulatory-inspired feature to avoid blinding oncoming traffic. The right lamp does help and I have mine splayed outward a bit to illuminate the roadside areas. For me, these lights are mostly helpful as conspicuity lighting.
On my BMWs, I normally have HID or led aux lighting to fill-in some much-needed candlepower.
Sheeze, with the Stelvio and its twin H-4 headlamps, I really do not see a need for more lighting. At one time I thought about adding twin HID H-4 conversions to the heads but, lordy, I see no need in it.
For those wanting to really "fry the weeds," many auxiliary offerings are out there.
leafman60 is offline   Reply With Quote
Old 10-01-2012, 05:49 AM   #3107
WitchCityBallabio
Guzzi weirdo
WitchCityBallabio's Avatar
Oddometer: 875
Originally Posted by NoobIAm View Post
I keep hoping to see someone make an accessory lens set for the Clearwaters that'll make them street worthy. Maybe a diffuser fronted by a fresnel would do it… as it'd have to be a custom 3-in-1 fresnel otherwise.
Street worthy? I've had mine on for 20k miles or more and they've been perfect No issues. I would like to see Clearwater make a screen/mesh protector for them for offroad work though.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio
2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe
1970 Moto Guzzi Ambassador
1966 Moto Guzzi Stornello
IBA # 35648
WitchCityBallabio is online now   Reply With Quote
Old 10-01-2012, 10:55 AM   #3108
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,287
Originally Posted by dirtymartini View Post
I finally got around to installing my Oxford heated grips..I decided to use the Oxford controller instead of hunting for the factory connectors and splicing and soldering. Using the switch bracket that came with the package I mounted it on the clutch perch and it looks like it belongs there! Someday when I have to remove the gas tank I may splice it into the OEM connectors but right now I am happy with how they look. Wow do they heat up nice!
You don't have to remove your tank to get at the factory heated grip connectors. Remove the left side panel and fish around to the right of where the factory TomTom GPS connector lives. The connectors are small(ish) and white, and are marked for left and right (SX and DX....don't ask me which is which 'cause I don't remember).
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-01-2012, 11:48 AM   #3109
pyoungbl
Colonel Blood
Oddometer: 530
SX should be the left one....sinistra in Italian, destra is right so DX.
on an earlier post, are you saying that your Gerbing heated vest drew more power than the fuze could handle? I would have thought that the maximum draw for most vests would be in the order of 7.5A (90 watts at 12 volts). If a vest will overload the wiring I guess I'll have to wire direct to the battery.
Growing old ain't for sissies!
pyoungbl is offline   Reply With Quote
Old 10-01-2012, 11:49 AM   #3110
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,850
Originally Posted by Blakebird View Post
That's not normal and shouldn't be happening.....and it's not because the oem battery is lacking. I've read one other person mention this over on Guzzi Tech. I'd have the shop look at it and see what's up.
Yeah I gotta take a pic and send it to the dealer - my ASSumption is that the sealed battery is venting thru the terminal blocks as a manufacturing defect and causing this
I've read a couple other notes about this on newer Guzzis (mostly Norges IIRC) but never remember any sort of resolution
As for the Oddesey - they seem to last better in the Houston heat then other sealed units so it's a pretty standard swap out I do
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 10-01-2012, 01:52 PM   #3111
dirtymartini
Shaken, Not Stirred
dirtymartini's Avatar
Oddometer: 2,619
I figured my Gerbings liner to be around 65 watts or so. I measured 2.2 ohms through the liner, about 5.5 amps or so. Enough to open the 5 amp.fuse when the controller was turned all the way up.
Sent from my ADR6300 using Tapatalk 2
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
dirtymartini is offline   Reply With Quote
Old 10-01-2012, 04:30 PM   #3112
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,484
I lived in Las Vegas for 8 yrs....never had a bike battery last more than a couple of years in that heat.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 10-02-2012, 07:24 AM   #3113
swmckinley
Oddometer: 84
Just got back from a 2800 mile trip over 5 days that included TX,NM,AZ and Utah. I wanted to find out out what the Stelvio was like on the long road. Bottom line is the bike is great for my mission, which is touring.
1.) First day was spent on I-10 getting out of Texas where speeds were 85 mph + and I saw 38 mpg average over 2 tanks.
2.) Second day Fort Stockton to Show Low, AZ was a 600 mile + day @ 75 mph returned a 42 mpg day.
3.) Third day Show Low, AZ to Torrey UT (600+ miles)@ 65 mph average returned 46 mpg.
4.) Fourth day Torrey, UT to Lubbock, TX (850+miles) 80+ mph saw 45 mpg.
5.) Fifth day Lubbock, TX to Austin, TX (370 miles) @ 75 mph saw 42 mpg.
So mpg is improving as bike gets miles on her. She has 5K on her now. The stock seat is wonderful. Best stock seat I have ever been on. The Hella aux lights keep on breaking, but only the right one, been thru three bulbs. Has not used any oil. I saw all kinds of weather from 100+ down to 40 degrees with rain and the bike did not miss a beat. Good weather protection, and sure footed in the wet stuff.
Steve Mckinley
Austin, TX
swmckinley is offline   Reply With Quote
Old 10-02-2012, 09:44 AM   #3114
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,850
Originally Posted by swmckinley View Post
Just got back from a 2800 mile trip over 5 days that included TX,NM,AZ and Utah..
I just did the same but included some of CO for almost 4k miles - ran into a bunch or rain thru West Texas into Luling
Checked my CARC gear oil last night and it was contaminated with water -will be doing the remote breather thing ASAP - will post pics later
Old 10-02-2012, 10:01 AM   #3115
James Adams
A few crayons short.
James Adams's Avatar
Oddometer: 10,263
Do you have a link to any info on the remote breather mod? This makes a lot of sense and I guess it would also apply to the GSes too.
505 XC-F · DUKE 690
James Adams is online now   Reply With Quote
Old 10-02-2012, 10:02 AM   #3116
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,924
Riding in the rain is almost unavoidable. Even water crossings can be expected on some rides.
I'd love to see how it's done. Plz let us know what parts are involved. I'm also curious how you remove that breather vent on the CARC.
'12 Moto Guzzi Stelvio NTX
'06 Honda Helix
Mr. B is offline   Reply With Quote
Old 10-02-2012, 10:41 AM   #3117
Chuck in Indiana
Oddometer: 322
Originally Posted by Mr. B View Post
.. Plz let us know what parts are involved. I'm also curious how you remove that breather vent on the CARC.
The breather vent just unscrews from the main housing with a typical right hand thread. I bought a banjo bolt from NAPA (their P/N 82703, $2.66) with the Metric 10mm thread for replacement. For the connection, I had an old BMW rubber brake hose with banjo fittings on both ends, so I cut off one end. I bought 3 ft. or so of rubber vacuum hose from the local parts house to slide over the banjo fitting and ran it along the CARC arm and then up under the fuel tank. A few zip-ties to hold it in place.
Edit: I used a couple of copper gaskets on the top/bottom of the banjo fitting to seal it.
Ride safe.
Chuck in Indiana screwed with this post 10-02-2012 at 10:43 AM Reason: Add one sentence
Chuck in Indiana is offline   Reply With Quote
Old 10-02-2012, 11:33 AM   #3118
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,924
Ride safe.
Thanks I'll watch for your pix.
'06 Honda Helix
Old 10-02-2012, 12:26 PM   #3119
Chuck in Indiana
Oddometer: 322
...I'll watch for your pix.
I haven't learned how to do that yet. The word description is the best I can do.
Old 10-02-2012, 12:32 PM   #3120
WitchCityBallabio
Guzzi weirdo
Oddometer: 875
If you're so inclined and don't want to hunt for parts, Pete Roper makes a kit that bolts right on. You can find it by searching on Guzzitech.com
IBA # 35648
Times are GMT -7.   It's 06:48 AM.
