01-12-2013, 02:35 PM
#3751 |
Oddometer: 180
01-12-2013, 02:46 PM
#3752 | |
Oddometer: 34
[QUOTE=Chuck in Indiana;20467040]
Haven't installed yet chuck. Are you the guy that on Wildguzzi who was in the process of installing the Rostra cruise control? You commented that it was a work in progress and when you had it tweaked, you would share the install. So I was kinda waiting for you to post your results so i can get after it. Cliff
2009 Moto Guzzi Stelvio |
01-12-2013, 03:21 PM
#3753 | |
Oddometer: 1,027
![]() ![]() (Not even bad in the snow...... ) ![]() Work real well on or off road with a great lifespan to top it off.
![]() Whoever undertakes to set himself up as a judge of Truth and Knowledge is shipwrecked by the laughter of the gods. Politics is a pendulum whose swings between anarchy and tyranny are fueled by perpetually rejuvenated illusions. Albert Einstein
Forseti screwed with this post 01-12-2013 at 03:29 PM |
01-12-2013, 04:18 PM
#3754 | |
Oddometer: 180
[QUOTE=Renman1117;20467120]
I have a few longer trips planned for this coming riding season, so solving the problem is a high priority. |
01-12-2013, 04:40 PM
#3755 |
NTXer
Oddometer: 705
Cheapest. Simplest.
I once was lost but now I'm...no wait, I'm still lost .
01-12-2013, 04:42 PM
#3756 |
Oddometer: 1,027
Cheap??..... easy???
Perhaps....... But no where near a cruise control.
01-12-2013, 05:18 PM
#3757 | |
Oddometer: 34
Cruise control
[QUOTE=Chuck in Indiana;20467795]
Yes I read with interest your posting @wildguzzi. Hope you get it sorted out. What seems to be your best guess a s to why the unit won't hold a constant speed? I would really like to install one. Cliff
01-12-2013, 05:27 PM
#3758 | |
Oddometer: 34
Mita Tires
or do they really hold a curve moderately well? Since I am a Illinois flatlander just getting to trails and curves involves a 500-700 mile jaunt. I would like the tire to not be twitchy on the pavement.I read the entire MITA thread about 6 weeks ago and came away scratching my head as to whether or not they might be something i would consider when i am ready to upgrade. Is the above tire mounted on an 09 Stelvio ? Thanks for sharing.Cliff
01-12-2013, 09:04 PM
#3759 | |
Corporate slave
Oddometer: 1,556
[QUOTE=Mr. B;20465496]
This means I can fill up once a week vs. 2-3 times per week (60 mile daily commute to work). And yes, it means I can go pretty much anywhere and not have to worry about fuel, but honestly that's just a bonus since I do a "big" ride once a year where I might need that range, but I ride to/from work daily so that matters more to me.-SM
aka NoVector Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad ![]() Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on....... |
01-12-2013, 09:12 PM
#3760 | |
Corporate slave
Oddometer: 1,556
Plus, I need an education on their line since they've got so many different models. Adventure, Badlands, Latitude, Traverse....sheesh! I tried on the Latitude and Traverse and the Traverse seem much better as an overpant, where the Lattitude (and the rest of their top of the line gear) all seem to be focused towards wearing them over a "base layer" like high-tech long underwear (which they also sell). I need something that can go over jeans comfortably.-SM
01-12-2013, 09:13 PM
#3761 | |
Contrarian
Oddometer: 1,574
[QUOTE=Sock Monkey;20469769]
I was simply saying that if I already had a non-NTX Stelvio, I probably wouldn't get a new one for the bigger tank. But that's just me.
'07 DR650, '12 Moto Guzzi Stelvio NTX |
01-13-2013, 03:47 AM
#3762 | |
Oddometer: 180
[QUOTE=Renman1117;20468258]
The Servo needs a strong, steady input signal. That signal is then used as the control point that the unit works against. I used an engine signal (#1 spark plug) on my '08 C-14 and basically controlled to engine speed rather than bike speed. On my '09 Wee-Strom, I used bike speed (from the front wheel speed signal) and controlled that way. On the NTX, the bike speed is from a signal from the ABS pickup/ring going back to the ECU, from both ends of the bike. Those signals also factor into the Traction Control for the bike. I was reluctant to cut into the ABS wires for fear of messing it up and, instead, went with the Pick-up Coil and Magnet Accessory that Rostra sells. It uses a Coil (that I have mounted on the front wheel assembly) and magnets (I am using four that are attached to the inner parts of the brake disc). I think my problem/inconsistency may be in this pick-up arrangement, somehow. Unfortunately, our weather is closing in again, so any work I do for awhile will have to be in my garage. Sorry. |
01-13-2013, 06:41 AM
#3763 | |
Guzzi weirdo
If you haven't already, don't forget to check out the Motoport stuff. Indestructable, incomparable construction, custom fit and big bang for the buck. I have the Air Mesh Kevlar II and the Kevlar pants. With the liner in on the mesh I can ride comfortably down to 32 degrees and if I go colder I just toss in my Powerlet heated gear. In the summer, it's cooler than riding in a tee shirt.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio 2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe 1970 Moto Guzzi Ambassador 1966 Moto Guzzi Stornello IBA # 35648 |
01-13-2013, 06:52 AM
#3764 | |
That's gotta hurt
Oddometer: 13,936
"There are no bad guys, only good guys and mother fuckers." |
01-13-2013, 07:54 AM
#3765 | |
Oddometer: 1,027
They are not twitchy at all. hold line very well. I have dragged pegs with these on. Never had a but pucker with them. In fact I trust them to hold better than the tourance or anakee I have run previously. You must have the 4.25 rim on the rear as they only come up to a 150 size.
