03-18-2009, 06:39 AM
#166 |
Ride Far - Ride Fast
Oddometer: 4,795
Here's another one in Quebec that has an open basket, adventure style carrier. Under $1000CDN so pretty cheap if you factor the advantage of the $US
http://www.cyclope2000.com/photos/Cy...615071651.html
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS, 99 R1100S, 2002 R1150GS, 2005 F650 Dakar Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
03-19-2009, 08:03 AM
#167 |
Oddometer: 2,470
Royal Enfield Trailer
I have been enjoying this thread. I had a Bushtech trailer on 1990 Honda Pacific Coast 800 for camping.
Just for ideas, go to http://store.royalenfieldusa.com/ and look at the RE trailer.
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
03-19-2009, 08:41 AM
#168 |
Broken Hearted
Oddometer: 9,543
Ironic that this got bumped.
Just last night I was thinking to myself - "self, it's time to look into a moto-trailer." |
03-19-2009, 10:16 AM
#169 |
Tiene Ruta Cuarenta?
Oddometer: 2,981
Updated the hitch
It ain't pretty, but the mock-up is ready to go to the welding shop...
Current wheelbase seems to be about 67". The tire clearance is a bit insufficient. ![]() ![]() ![]() ![]() ![]()
2013 Triumph Tiger 800 - 2007 Harley XL1200R Roadster - 2013 Husqvarna Terra 650 You can lead a politician to water, but you can't make him think. - Kinky Friedman Improve your cosmic karma here! ag_streak screwed with this post 03-19-2009 at 10:28 AM |
03-19-2009, 10:39 AM
#170 |
Oddometer: 4,795
Looking good
Are you fabbing if out of aluminum? I guess some of those pieces in steel would be really heavy.
03-19-2009, 12:14 PM
#171 |
Tim
Oddometer: 279
Hey ag streak, Looks great. Looking at the pin where the trailer articulates, remember to keep your torerances close.005-.010 and make sure to use a pin that is threaded, to be able to increase the hitch pin presure to better stabeleze the trailer. It looks great. I can't wait to see the finished trailer.
Tim Firefighter/EMT If you can read this, thank a TEACHER. If you're reading this in ENGLISH, thank a SOLDIER. God Bless us all. 88 NX 125, 99 Valkyrie, 02 KLR Pulling my homebuilt monowheel
03-19-2009, 11:01 PM
#172 |
az-peru
I started thinking about a trailer after imagining what could happen if I strapped my snowboard (sideways.. as a spoiler) on the back of the bike and hit a wind gust at 75 mph! hahahaha
03-20-2009, 05:27 AM
#173 | |
Oddometer: 2,981
2013 Triumph Tiger 800 - 2007 Harley XL1200R Roadster - 2013 Husqvarna Terra 650 You can lead a politician to water, but you can't make him think. - Kinky Friedman Improve your cosmic karma here! |
03-21-2009, 07:25 PM
#174 |
SuperSportTourer
Oddometer: 1,005
XR200R KTM 950SM CBR Fireblade-GTU Endurance racebike 1996 YZF 600-Lost Era racebike 1999 R6-Rookie Challenge racebike |
04-01-2009, 03:17 PM
#175 | |
Single Wheel Freak
Oddometer: 9
![]() The tow pivot has a M10 thread up the middle and fixes through your hollow rear axle with spacers to centre it. The “C” shaped parts are welded in the end of a “U” tube which forms part of the tow bracket around the rear wheel. The trailer is then simply offered up to and over the tow pins and the collets pushed on and pinned to attach the trailer to the bike J - and no – it won’t pull off!! EwokGB screwed with this post 04-01-2009 at 03:29 PM |
04-02-2009, 10:48 AM
#176 | |
East Coast Rider
Oddometer: 490
Nice!!..........
04-03-2009, 06:41 AM
#177 | |
Oddometer: 2,981
What are these called, what are they originally used for, and where do you get 'em?
Thanks! Quote:
04-03-2009, 07:00 AM
#178 |
Oddometer: 2,981
Plan B
Well, me and the welder didn't "click" I carefully explained what I was after, but he didn't seem to get it. I wanted a quick and dirty prototype, he wanted to maximize his price. He estimated $800 for the work, saying it was a lot of welds.
I see his point, so I designed another frame with fewer joints and welds. It uses a single tube main frame instead of twin flat-stock main rails. I thought the flat-stock idea was a bonus, but apparently, it causes more hand-work. A large-diameter tube would have great stiffness and can be bent to the shape below in minutes on a tube bender (the diagram has angled bends only because they were easier to draw). Then a simple three-piece hinge part for the swingarm pivot and a single hole for the main pivot. Simple. The swingarm is conceptually the same. The hitch is five easy pieces. Steel rod instead of aluminum wouldn't weigh much more, and can be bent without kinking (I'd still prefer a hollow-tube hitch loop.) The plates that mate to the bike axle could be the ones posted by Ewok.
04-03-2009, 07:26 PM
#179 |
Bald, old, crabby, & fast
Oddometer: 38
[quote=ag_streak]Well, me and the welder didn't "click" I carefully explained what I was after, but he didn't seem to get it. I wanted a quick and dirty prototype, he wanted to maximize his price. He estimated $800 for the work, saying it was a lot of welds.
I see his point, so I designed another frame with fewer joints and welds. It uses a single tube main frame instead of twin flat-stock main rails. I thought the flat-stock idea was a bonus, but apparently, it causes more hand-work. A large-diameter tube would have great stiffness and can be bent to the shape below in minutes on a tube bender (the diagram has angled bends only because they were easier to draw). Then a simple three-piece hinge part for the swingarm pivot and a single hole for the main pivot. Simple. The swingarm is conceptually the same. The hitch is five easy pieces. Steel rod instead of aluminum wouldn't weigh much more, and can be bent without kinking (I'd still prefer a hollow-tube hitch loop.) The plates that mate to the bike axle could be the ones posted by Ewok. [/quoteFWIW: I built something like your trailer during the boring winter of 2007 in Green Bay. Easiest pivot/best tolerances: use a universal joint yoke assembly (available at any farm supply store). The u-joint is way better than a bolt/bushing and it permits the appropriate up & down + side-to-side movement essential for a single-wheel trailer. Weld one end to your hitch assembly to attach to the bike & the other end to the trailer. Take pains to ensure the u-joint yoke is perpendicular to the ground (and parallel to the tire) before welding it on. My design has a swingarm (on a bushing) plus a coil-over shock from a youth ATV. I use the trailer to transport a tandem bicycle or excess gear (grocery shopping when I'm dragooned into the task). Bullet-proof - I've run 90+ mph: no issues behind my R12GS. Doesn't change the beast's fuel economy one bit. |
04-06-2009, 09:49 AM
#180 | |
Single Wheel Freak
Oddometer: 9
