Old 05-29-2013, 07:35 PM   #631
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,850
Sweet.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 05-29-2013, 07:59 PM   #632
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,130
Originally Posted by ben2go View Post
Sweet.
+1!!
Way cool!
oPAULo is offline   Reply With Quote
Old 06-09-2013, 09:29 PM   #633
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,102
Mockup
Still working things out, but you don't know how its going to go until you put all the pieces together.
Here's what I got so far from this evening:
Next step is to find that hitch component that only swings side to side, and holds the trailer from tipping over. I plan to attach to the swingarm, possible through the axle or on the swingarm stand bolt holes.
Couple more pictures:
2012 BMW R1200GS
www.NYMSTF.org - Support NY Riders!
GHO100 is online now   Reply With Quote
Old 06-10-2013, 09:39 AM   #634
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,339
Awesome.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is online now   Reply With Quote
Old 06-10-2013, 10:24 AM   #635
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,352
I don't see how the suspension will work. What am I missing? Otherwise I love the idea of using a hand truck.
John
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 06-10-2013, 10:45 AM   #636
k-moe
k-moe's Avatar
Oddometer: 3,071
John
If you look carefully you'll see that the axle supports to the frame are being used as a bend-then-collapse-type suspension.
It should actually work fine so long as the loaded trailer is kept light. It'll be bouncy though. The only "suspension" action will be the flex of the forks and the frame.
k-moe is offline   Reply With Quote
Old 06-10-2013, 10:52 AM   #637
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 858
Like the idea of using readily available parts. Wondering if the forks will work as a trailing suspension part. The forks were originally designed as leading suspension and you have them as trailing suspension. Wondering if the forks would function better being mounted, more upright, to the plate. Just a thought.
2015 Yamaha Super Tenere ES - 1993 Chevrolet S10 - 2005 Kawasaki KLR - 2012 Yamaha Super Tenere (sold)
tomatocity is offline   Reply With Quote
Old 06-10-2013, 11:21 AM   #638
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,102
Thanks for the thoughts. I fought a lot on paper with how to do all this, and originally had a bicycle shock going to that cross bolt, and the other eye of it mounted to the plate. The trouble with that being the overall length, and how to attach the "spine" to the hand truck center rail.
something like this:
2012 BMW R1200GS
Old 06-10-2013, 02:23 PM   #639
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 7,030
Looks quite rigid to me. However, even if the forks were used in the geometry necessary to get them to rebound and compress the trailer would have to be heavy unless it was resprung/revalved for the lighter weight.
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick screwed with this post 06-10-2013 at 03:47 PM
DakarNick is online now   Reply With Quote
Old 06-10-2013, 03:25 PM   #640
lonewolf97
lonewolf97's Avatar
Oddometer: 2,408
I use hand trucks at work so much. There's no way I would pull one on my day off riding.
I'd rather be lost in the woods, than found at home.
lonewolf97 is offline   Reply With Quote
Old 06-10-2013, 06:26 PM   #641
k-moe
k-moe's Avatar
Oddometer: 3,071
Actually..... if you mount the fork to what is now the back of the trailer (the lift plate of the hand truck) and make it trail by about 10 (not going to do the math just now) it should work just fine. It might even work better without any trail. I'm envisioning that the fork clamp is attached along the top (used to be front) edge of the lift plate. There would be some fabrication of bracing though.
Old 06-10-2013, 07:30 PM   #642
boatpuller
Oddometer: 680
Four thoughts:
1. A small universal joint from a farm and home store at your hitch will allow all the movement you need, and prevent the trailer from tipping differently than the motorcycle
2. You should try to get the trailer, at least at the wheel end, lower. I pull a single wheel trailer behind my street bike, and load it heavier than you probably will, but it's amazing how much it tries to tip me over at slow speeds. At high speeds it doesn't, but first gear riding is much more work. I'd expect that each inch you lower the trailer, the less that would happen. AND, the more weight the trailer wheel carries, the less weighing down the back of your bike.
3. I'd try real hard to make the forks a suspension part of your trailer, by bolting them more vertically to the flat plate of the hand cart. You'll have to do a little more fab work for that, but it will make a very real difference when you use it.
4 If you can hook the hitch to a "sprung" part of your motorcycle, all the better. Adding the hitch weight to the swing arm will compromise your ride and handling, All suspension engineers try to minimize unsprung weight, and you're going to add more than you think, especially when the trailer bounces.
boatpuller is offline   Reply With Quote
Old 06-11-2013, 08:32 AM   #643
GHO100
Crazy George
GHO100's Avatar
Oddometer: 1,102
Thanks for the feedback.
1. We don't really have farm stores in NYC, so that'll be tricky to find, but I might canabalize a razor scooter to get the joints out of it. Got a picture sample you can show me of what you had in mind?
2. Good idea. Its a bear to manhandle right now, and pushing it around, it wants to flip itself over. Dropping the rear section a significant amount would help a lot, I think.
4. Where to hitch? I guess I was originally aiming for a setup like thirdwheel trailers, through or on the swingarm, which is what motobracket does too.
Another options would be the passenger footpegs.
I still haven't worked out that bit that goes from the bike to the trailer, basically. Bit harder to do without welding, metal shop access, etc.
Thanks again!
I'll post updates as I'm working
Originally Posted by boatpuller View Post
Four thoughts:
2012 BMW R1200GS
Old 06-11-2013, 08:54 AM   #644
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 720
The mower bone yard at a golf course is a good place to cannibalize u-joints. The big riding mowers that have a gear box blade drive, use u-joints in their drive shafts.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 screwed with this post 06-11-2013 at 10:05 AM
Danger4u2 is offline   Reply With Quote
Old 06-11-2013, 09:37 AM   #645
k-moe
k-moe's Avatar
Oddometer: 3,071
Her are a few inexpensive choices. http://www.surpluscenter.com/sort.as...search=u-joint
Shop around and you may find a better price.....maybe.
Times are GMT -7.   It's 08:12 PM.
