Old 08-25-2013, 07:20 PM   #706
marguyo
marguyo's Avatar
Oddometer: 32
Originally Posted by MrBracket View Post
Marguyo,
I like your trailer and your bike! Nice work!
I played around with the angle of the hitch pivot quite a bit when building my first couple trailers.
I'm betting you'll find that your trailer feels more comfortable in the corners if you tilt the hitch pivot forward about 10 deg.
That air bag spring is nice, I bet that makes it easy to adjust your spring rate for different loads, very nice!
Great looking setup!
thanks! reel thank you ! i change my coupling this winter
all have two wheels which deserves to be run
marguyo is offline   Reply With Quote
Old 08-29-2013, 06:10 PM   #707
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
We got back to the TW200 trailer project today, the swing arm is built and mounted to the trailer, still waiting on a new tire. I hope to have the tongue and hitch arms built tomorrow, with any luck I'll pull it home Saturday.
Only a fool would attempt it, and God help me, I am that fool!
r80rt screwed with this post 08-29-2013 at 07:48 PM
r80rt is offline   Reply With Quote
Old 08-29-2013, 09:30 PM   #708
Salsa
Oddometer: 360
Marguyo,
What is the theory behind the 10 degrees or why SHOULD it be better?
Don
Salsa is offline   Reply With Quote
Old 08-30-2013, 04:59 AM   #709
Not the Messiah
Not the Messiah
Not the Messiah's Avatar
Oddometer: 161
Salsa,
HTML Code:
In a turn, with the bike (and trailer) leaned over AND the trailer at an angle to the bike (ie "trailing" into the corner) the front triangle of the hitch must move upward slightly to let this all happen. It's all about the geometry of the pivots. Anyway, tilting the pivot forward exagerates this upward movement of the hitch. I'm guessing a bit now, but I suspect that this stops the trailer "dropping" or "falling" into the corner and dragging the bike into more lean - by holding the trailer up it let's the bike feel more neutral.
I hope this makes sense. I tried to sketch it out but my tech drawing skills have left me...
Not the Messiah is offline   Reply With Quote
Old 08-30-2013, 06:13 PM   #710
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Today's progress on the TDub trailer. Here is the swing arm and shock finished. The shock from the front of the scooter was to soft so we used the one from the rear, it's much better.
A nearly done hitch made from 1 1/2 strap steel, the off set in the swing arm caused us a bit of extra head scratching, but we got it.
A test fit of the hitch. Anything that moves has a bushing and a grease zerk, I like things to be smooth. I got my new trailer tire in the mail today finally!. It may be a few days before we can finish it, but there ain't a lot left to do.
It's a little hard to see in this picture but the hitch pin leans forward 10 degrees, it's supposed to make them track better, I hope it does cause it was a pain in the neck to get right.
r80rt screwed with this post 08-31-2013 at 06:36 AM
Old 09-01-2013, 08:01 PM   #711
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Almost done
Old 09-01-2013, 08:15 PM   #712
Curtis in Texas
Oddometer: 202
Looks good! Have you calculated the lean angle in turns your going to be able to do before the front corner of the trailer strikes the ground?
Making a leaning turn into a driveway up a curb will tell if you've got enough clearance. If not, you'll figure it out real quick once you pick yourself off the ground.
I like the scooter wheel idea. I"m trying to figure out how to make one work on mine so I can add a brake on the trailer into the mix.
“It is not the critic who counts; not the man who points out how the strong man stumbles, or where the doer of deeds could have done them better. The credit belongs to the man who is actually in the arena" -Burt Munro
Curtis in Texas is offline   Reply With Quote
Old 09-02-2013, 12:18 AM   #713
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Originally Posted by r80rt View Post
Almost done
Very secksee.
Lizrdbrth is offline   Reply With Quote
Old 09-02-2013, 12:20 AM   #714
steveWFL
steveWFL's Avatar
Oddometer: 1,344
nice~
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 09-02-2013, 06:13 AM   #715
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Well if we've done everything right, I should have plenty of clearence, I'll find out today. If there are any problems I'll cut the front corners off at a 45 degree angle.
r80rt screwed with this post 09-02-2013 at 07:47 AM
Old 09-02-2013, 06:16 AM   #716
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,978
Sitting here on a picnic table enjoying the sunrise while Dirt Flirt reads a book. First time camping off the bikes is awesome! Trailer performed very well. Got the shocks all sorted out with some oil for damping and internal springs. Still get a slight swaying above 55mph but we're sticking to back roads and gravel on this trip anyway. I think I'm getting some flex near the steering head and already have plans how to stiffen it up.
Packed a good size tent, air mattress, blankets, cold beverages with ice in the insulated scooter bags, tools, food, and some other crap.
oPAULo is online now   Reply With Quote
Old 09-02-2013, 07:45 AM   #717
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Very cool!
Old 09-02-2013, 03:44 PM   #718
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Exclusive spy shot of the fat boy's first test ride of the trailer, it still needs to be disassembled and painted but it pulls like a dream and handles great, I'm big happy to say OldBrattrider has built me one hell of a trailer. I'll post finished shots as soon as the paint dries.
r80rt screwed with this post 09-08-2013 at 06:32 AM
Old 09-02-2013, 07:25 PM   #719
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Got it painted, but it got dark on me so the pic's aren't great.
http://www.youtube.com/watch?v=cvDm1o65Dw0
r80rt screwed with this post 09-02-2013 at 09:34 PM
Old 09-02-2013, 09:17 PM   #720
mwilliamshs
Oddometer: 222
r80rt...
what are those saddlebags?
mwilliamshs is offline   Reply With Quote
Times are GMT -7.   It's 08:15 AM.
