Old 09-02-2013, 09:36 PM   #721
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Originally Posted by mwilliamshs View Post
what are those saddlebags?
They are British surplus haversack / gas mask bags, got them for $8 in a pawn shop. Sportsmans guide has them in camo.
Only a fool would attempt it, and God help me, I am that fool!
r80rt is offline   Reply With Quote
Old 09-03-2013, 08:57 AM   #722
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Some better finished trailer pic's,
You can go with this,
Or you can go with that,
Old 09-03-2013, 11:22 AM   #723
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,987
Looking good R80rt!
oPAULo is offline   Reply With Quote
Old 09-04-2013, 12:41 PM   #724
oldNbold
Oddometer: 127
Looks pretty low slung. Built in skid bars? to get over tall rocks and curbs. Doesnt look too bad. I hope to build a trailer this winter for myself.
1977 Harley Davidson FLHS
2013 Harley Davidson FLD
oldNbold is offline   Reply With Quote
Old 09-04-2013, 01:02 PM   #725
MrBracket
MrBracket's Avatar
Oddometer: 258
Nice work r80rt!
You mentioned cutting the front at 45deg, that would be a great solution to being low to the ground. That or add some rounded "skis" in the front like a snow sled might have. Just to get you up over obstacles rather than smacking them straight on.
You'll be able to haul more weight with it lower to the ground. A single wheel trailer is a lot like a hammock. You want the weight below the axles of the wheels if possible. If the center of mass is above the axles, the trailer wants to flop side to side. In theory, the taller the trailer wheel the better, it allows the load to be higher off of the ground.
http://www.facebook.com/MotoMule http://www.moto-mule.com
2010 Husaberg FX450, 2011 Husaberg FS570, 1994 Yamaha TW200, Next bike?? - A twin cylinder adventure bike. Why? Because most thumpers sound like two skeletons making whoopie in a trash can!
MrBracket is offline   Reply With Quote
Old 09-04-2013, 01:49 PM   #726
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Thank you! Your Moto-Mule inspired me to build a trailer ya know. I really appreciate all the tips and advice you've given to us home builders.
I've just loaded it up and tested it through much rougher ground and bad roads than I ever intend to use it on, and it worked perfectly. I still may 45 the front corners but for now I can't see a reason to. It'll be used on dirt roads, but not off road, so I should be fine. Thanks again for the inspiration!
r80rt screwed with this post 09-05-2013 at 07:37 AM
Old 09-04-2013, 01:51 PM   #727
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Thanks, I have 8 1/2" of ground clearance and two full length runners on the bottom. I'll only use it on dirt roads so I doubt I'll never hit the ground with it. Good luck on your build and post pic's!
r80rt screwed with this post 09-05-2013 at 04:38 PM
Old 09-04-2013, 11:36 PM   #728
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Nice work.
Kudos to Bracketdood for sharing some of his hard-earned R&D.
Lizrdbrth is offline   Reply With Quote
Old 09-05-2013, 06:21 AM   #729
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
Thank you Lizrdbrth, and yes kudo's to MrBracket for all the excellent advice
Those other pictures are a little deceptive because of the angle, the trailer isn't as low slung as it looks in them. Here are a couple with the bike propped up almost level with a loaded trailer. I put a a coffee can under it for perspective.
Here's another look, this time it's on the sidestand and loaded.
r80rt screwed with this post 09-05-2013 at 08:33 AM
Old 09-05-2013, 09:49 AM   #730
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,824
Nice!!!
"Good Times & Good Friends Make Life Better"
www.artworks-unlimited.com
Patrick46 is offline   Reply With Quote
Old 09-05-2013, 05:14 PM   #731
oldNbold
Oddometer: 127
These last pics show the ground clearance much better. Looks like there is plenty. And honestly if it is little low it should be easy to drag over a high spot. Nice.
Old 09-05-2013, 06:31 PM   #732
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
We got out today and took the trailer back through the washed out deserted roads for further testing. My riding partner and trailer builder OldBrattrider was the camera man, and I am the test pilot. The video doesn't really show how steep, rough and rocky it is, but you'll get some idea. This little trailer will follow me any where!
http://www.youtube.com/watch?v=rqEiU-ClOEI
r80rt screwed with this post 09-10-2013 at 08:09 AM
Old 09-06-2013, 05:50 AM   #733
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,109
I didn't see you load the beer & ice....? You sure went to a lot of time & effort building that sweet trail trailer for just hauling a little camping gear.
Have you experimented with seeing what's a comfortable load capacity ?
Good job. Wish I had one.
GlennR is online now   Reply With Quote
Old 09-06-2013, 06:21 AM   #734
r80rt
Dirt road nomad
r80rt's Avatar
Oddometer: 128
No beer on that ride, well maybe a little when we got home... My camping gear and fuel weigh in at 30lbs, I don't think I'd want to carry a lot more than that, maybe 50lbs would be max for me.
r80rt screwed with this post 09-06-2013 at 09:55 AM
Old 09-06-2013, 01:27 PM   #735
Curtis in Texas
Oddometer: 205
Very nicely done video. Looks like you've built another winner.
I'm thinbking 80 lbs will be my max weight on my trailer because of the shock spring. The frame and suspension will handle more but I'm not wanting ton try and stop too much weight. Remembering my other trailer I built years ago and the braking problems it created behind my Suzuki GS 750.
Yours looks like it belongs back there. The optional bare cargo rack is a nice touch because it gives you the option of dropping the Action Packer at camp and foraging for firewood.
I have a set of panniers built for my little trailer, but the width will be a problem on the trails. And I've got monster panniers on my KLR already.
So I really don't need more space!
I'm planning on riding up your way through Missouri, Arkansas, Tennessee and Kentucky on the way to North Carolina next month, so if you see me rolling by, be sure to flag me down. Not going to be in a hurry, so I'll have time to stop and say hi!
“It is not the critic who counts; not the man who points out how the strong man stumbles, or where the doer of deeds could have done them better. The credit belongs to the man who is actually in the arena" -Burt Munro
Curtis in Texas is offline   Reply With Quote
Times are GMT -7.   It's 05:43 PM.
