03-12-2010, 05:47 AM
#15001 | |
Oddometer: 205
Other than the elimination of the desmogger and the crankcase breather air cleaner the actual airbox LOOKS stock to me, and unmolested at that. The two holes in the top of the airbox are stock, just like the pic in 5-9 of the manual. So I just drill out those rivets and call it good? I've heard of the desnorkling mod but have never seen it detailed anywhere. Also, page 1-7 of the manual shows the compression spec to be 92psi at 400rpm. Can you help me on where you got 160-170? jasonkop screwed with this post 03-12-2010 at 06:04 AM |
03-12-2010, 06:11 AM
#15002 |
Oddometer: 205
just called autozone and they have a comression gauge I can borrow. I already have beer so now i just need ot get off work so i can get cranking. With any luck my jest and airfilter will get here by tomorrow.
03-12-2010, 06:22 AM
#15003 | |
CDI REPAIR
Oddometer: 3,310
Yup,,drill out the two rivets,,pull the snorkle out.... As for the compression,it`s like i said,if you screw in the compression tester,open the throttle,and crank the engine over you should see arround 90 lbs of compression... But as per the manual,,,if you back off the right side exhaust valve adjustment to at least 0.82 clearance you see the actual engine compression without the decompressor in effect,lowering the reading.... See page 3-9 You do not have the decompressor??????????...if that`s true you just have to do a normal compression test,open the throttle,crank the engine. Now the manual says you should have 199 lbs of compression,since the decomp is not affecting the compression,because you do not have one... But........getting almost 200 lbs compression is sometimes hard to get,because rpm is hard to keep up with the small starter....and you are allowed a max difference of 25% in most engines of spec.. What this means is that if spec is 200 psi at 400 rpm..you are allowed as low as 150lbs.......any lower is considered a problem....leaking rings,valves,etc.... This 25% rule is a standard,in actuallity you should get at least 170 or better....... I f you have a high comp piston this goes out the window,you will see higher readings...just do the compression test and post the results..the aftermarket cam could affect your readings too,,but not much IMHO... Your readings would have to be awfull low to make it run the way you descibe though...... Brian
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
03-12-2010, 06:30 AM
#15004 | |
CDI REPAIR
Oddometer: 3,310
Hey..........where`s my beer???..i mean geeez i`m sittin here typin and tellin,and my mouth is real dry... I`m gonna have to buy ,my own again ..which kinda sucks B
03-12-2010, 06:40 AM
#15005 |
Enjoying my last V8
Oddometer: 5,295
Damm, I wanted to be on page 1000, 1001 will have to do. PHOTO OP!!!!
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, fritzcoinc screwed with this post 03-12-2010 at 06:57 AM |
03-12-2010, 06:45 AM
#15006 |
Off Road King
Oddometer: 11
XR 600R Long Range Tank
Hi Guys,
I am looking for a Acerbis 22 L fuel tank for my '99 XR 600R. Any tank available or on-line shp where i can buy it? Thanks MJ |
03-12-2010, 06:50 AM
#15007 |
Enjoying my last V8
Oddometer: 5,295
Page 1001 photo op!
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
03-12-2010, 06:52 AM
#15008 |
Mundane Commuter
me again...yeah I know
So the good news is:
I replaced the broken bolt... $.54 No extra pieces laying around SPARK - check GAS - check Ignition - sorta Idle - not so much Backfire - a bit LOUD banging inside - check
Integrity....an obsolete notion held to by irrelevant people. |
03-12-2010, 06:54 AM
#15009 | |
Oddometer: 205
FADDAH---Damn dude I was just sending good vibes your way....I must have been too late! |
03-12-2010, 06:55 AM
#15010 | |
Mundane Commuter
![]() ooooohh... you mean jeTS
03-12-2010, 07:44 AM
#15011 | |
Oddometer: 205
03-12-2010, 08:12 AM
#15012 | |
CDI REPAIR
Oddometer: 3,310
Looks like you guys had a lot of fun,,nice ride......... B
03-12-2010, 08:16 AM
#15013 |
Oddometer: 7,965
Carb Mods
Jason,
From Dave's Mods: Important Note: These XR650L carburetor modifications work in conjunction with a free-flowing aftermarket style air filter and removed airbox snorkel. These mods might actually make your bike run worse without replacing the air filter and pulling the snorkel.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
03-12-2010, 08:20 AM
#15014 |
CDI REPAIR
Oddometer: 3,310
Anyone using a different shift lever,like an MSR or somepin
...????????I took a pic today of the case saver,,there is no notch,i thought there was .so if an MSR lever will work i`ll get one,otherwise out comes the torches and mig welder.. Anyone runnin a XR`s Only case saver and havev a problem gettin MX boots under the lever B
03-12-2010, 08:46 AM
#15015 | |
Oddometer: 205
