Old 03-12-2010, 08:57 AM   #15016
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by FatherX
So the good news is:
I replaced the broken bolt... $.54
No extra pieces laying around
SPARK - check
GAS - check
Ignition - sorta
Idle - not so much
Backfire - a bit
LOUD banging inside - check
WHAT? Knocking? Bad loud banging or good as in running.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 03-12-2010, 09:05 AM   #15017
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by techforlife
Anyone using a different shift lever,like an MSR or somepin ...????????
I took a pic today of the case saver,,there is no notch,i thought there was .so if an MSR lever will work i`ll get one,otherwise out comes the torches and mig welder..
Anyone runnin a XR`s Only case saver and havev a problem gettin MX boots under the lever
B
I don't have the XR case saver but it looks like a wheel on a 4" grinder and I could make a notch.
MX boots are always stiff when I first get them. Stand then in a tub of warm water for 30 minutes. Put 'em on wet and walk 'em dry. Might take a few hikes to get them dry over a couple days but they will loosen up. Mink oil after they are completely dry. The ones I have now are still stiffer than regular boots but I can easily shift with the shifter in the stock position. They got soaked on a 5 hour ride the day I got them and they are very comfortable now.
John
Old 03-12-2010, 09:07 AM   #15018
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,218
John
not sure
running shitty...might just be rough because of baja gas
lunch
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX is offline   Reply With Quote
Old 03-12-2010, 09:14 AM   #15019
mcma111
mcma111's Avatar
Oddometer: 12,403
John
John and All interested parties.
Pop's contacted me this AM and we have been doing a long distance carb check / o-haul. Plugged jets, 3 month old Mexican gas, won't idle, etc.
Stay tuned...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2010, 09:18 AM   #15020
jasonkop
jasonkop's Avatar
Oddometer: 205
Originally Posted by fritzcoinc
I am watching this with interest. My bike acted the same and I ended up with 52/152 jets. How is your bike running at this point?
could you elaborate.
My bike starts easy when cold. After very little time (5-10 sec) I can turn choke off and it idles smoothly with little engine noise. It takes off ok enough but is lacking in power (IE... no power wheelies). It bogs down in all gear but seems to become worse at higher speeds.
I'm led to believe that a certain amount off bucking etc is to be expected when you hit high rpm's in any gear as the thumper can't keep up. That's not what this is. What I'm experiencing seems more relative to LOAD than to actual engine speed. I can rev the bike in neutral and it doesn't sputter etc. However, if I get up to third gear and crank on it, it bucks like mad and cuts out 45mph. if I creep up to speed and shift early and be smooth I can get to that 45mph (in3rd) and I still get it cutting out. If I'm in 4th it happens at 50mph, and 5th I can ride 55. From there (55 in 5th gear) even the slightest of wrist turning will throw me forward on the handle bars as my momentum carries me forward when the bike peters out. If I back off it'll settle back nicely at 55. Not a good feeling to be on a bike knowing you don;t have the power to get yourself away froman inattentive cager. Plus I wanna fvcking power wheelie this would be beast!
jasonkop is offline   Reply With Quote
Old 03-12-2010, 09:20 AM   #15021
Wattner
Wattner's Avatar
Oddometer: 5,361
not sure
lunch
Wanna buy my KTM???? Runs like a scalded ape, jets perfect, runs perfect, has every goodie known to man on it
Wattner is offline   Reply With Quote
Old 03-12-2010, 09:21 AM   #15022
mcma111
mcma111's Avatar
Oddometer: 12,403
Jets
Jason,
Try a smaller main jet like a 152. You may be running to rich
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2010, 09:34 AM   #15023
jasonkop
jasonkop's Avatar
Oddometer: 205
Originally Posted by mcma111
Jason,
the jets are stock 52/152. plug show lean if anything. hard to tell since the plug is new and the miles are few...hey that rhymed!
Junior at xrsonly thought it needed bigger jets so I have them coming. 55/158.
Old 03-12-2010, 10:27 AM   #15024
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,218
are you mocking my ssstutter?
anticlimactic but progress I guess
man that hurts
Old 03-12-2010, 10:29 AM   #15025
jasonkop
jasonkop's Avatar
Oddometer: 205
sell it!
Old 03-12-2010, 10:31 AM   #15026
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,218
Originally Posted by jasonkop
sell it!
make me an offer
Old 03-12-2010, 10:34 AM   #15027
mcma111
mcma111's Avatar
Oddometer: 12,403
sell it!
Your a big help
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2010, 10:37 AM   #15028
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,218
he's just trying to get a hold of a donor
he's really a nice guy
really
Old 03-12-2010, 10:42 AM   #15029
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,218
sure
take a check ?
i be po...maybe next year
Old 03-12-2010, 10:42 AM   #15030
jasonkop
jasonkop's Avatar
Oddometer: 205
thanks faddah.
so tell me how you cleaned out the carbs? i take it you removed all the removable stuff like jets and what not?
Times are GMT -7.   It's 05:16 PM.
