Old 03-12-2010, 02:43 PM   #15061
Northern Dog
Gnarled up Northerner
Northern Dog's Avatar
Oddometer: 710
Originally Posted by jasonkop
ok, so i just got done with the compression check and it came out about 150psi so it's not too bad. The honda mechainc that did the comp check said he thought the plug was lean but not dangerously lean. I borrowed the autozone compressiom check kit but it didn;t work because it was for big toy plugs.
I also tried taking plates out of the supertrapp. There were 8 and I took it down to 2 and that made it run even worse.
gonna replace the jets when they get here in the mail and then complete Dave's mods if it seems as though I'm on the right track.
I'm gonna throw in my 2 worth at this point ...
I've seen problems in the past on bikes and cars where the ignition/spark would break down once you reached a certain rpm range. Have you tried swapping out the coil and/or CDI yet? ... it also may be something as simple as a faulty plug wire/cap.
~You don't stop riding because you get old, you get old because you stop riding~
Northern Dog is offline   Reply With Quote
Old 03-12-2010, 02:46 PM   #15062
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,328
+1 it`s a possibility,if the CDI is going send it to me for a free rebuild,i`ve rebuilt 7 so far in 2 months,more coming,and like i say i do it for free for guys here and at TT.....
B
techforlife is offline   Reply With Quote
Old 03-12-2010, 02:50 PM   #15063
Kawidad
Kawidad's Avatar
Oddometer: 4,851
Originally Posted by techforlife
Is it longer than the OE Kawidad ,,bent differently or anything
B
As I recall it is the same length and bend.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 03-12-2010, 02:54 PM   #15064
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
I use the MSR shifter, but it is hard to get my toe down to shift with MX boots on. I kind of use the side of the boot and the edge of the sole.
screamin injin is offline   Reply With Quote
Old 03-12-2010, 03:00 PM   #15065
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
It could also be as simple as a loose connection. I had a loose coil wire cause me grief with my 600 and it was dependent on rpm and not throttle input. The plug was also black regardless of jetting which made me start suspecting ignition. Pinched the connection down tight and it ran great.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 03-12-2010, 03:01 PM   #15066
jasonkop
jasonkop's Avatar
Oddometer: 205
nope and i was thinking the same thing.....stay tuned!
And thanks for the offer techforlife, i might just take you up on it!
jasonkop is offline   Reply With Quote
Old 03-12-2010, 03:16 PM   #15067
mcma111
mcma111's Avatar
Oddometer: 12,285
Cdi
Jason,
Pop's has a spare CDI that you could probably borrow for testing.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-12-2010, 03:17 PM   #15068
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
stay tuned!
Jason I have been following this saga for a while now and I originally thought dirty tank, water, dirty carb. I've seen engines that will idle and run at low rpms but stall when the throttle comes up. Trash or water has been the culprit. But I think that has pretty much been eliminated. It seems that it is RPM related and once the engine gets to a certain point and still wants more fuel the carb can't deliver any more. Hopefully bigger jets will cure it.
That said I am a carpenter so I usually use a hammer to fix everything
good luck
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 03-12-2010, 03:26 PM   #15069
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,986
Originally Posted by mcma111
Jason,
CDI and coils - yessir
JasonKop-I also have those jets 55/158 you are waiting on.
I'll be in your area again on Wednesday
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX screwed with this post 03-12-2010 at 03:34 PM
FatherX is offline   Reply With Quote
Old 03-12-2010, 04:06 PM   #15070
techforlife
CDI REPAIR
Oddometer: 4,328
If it ends up being the CDI FX....why don`t you let him borrow it and send me the bad one to fix...if that`s alright with you...then i`ll send it to him when done...or he can keep that one,,and i`ll send the repaired one to you...whichever,i`m not fussy
I haven`t seen a CDI do this yet,usually stalling and no-starts...but a weak solder joint can let less power go to the coil,causing weak spark and missfiring under load..so it is possible...
I`d try a coil and wire first..
B
Old 03-12-2010, 04:54 PM   #15071
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,986
B
at this rate he'll probably end up with the whole thing
JK
maybe
no JK
Old 03-12-2010, 05:10 PM   #15072
techforlife
CDI REPAIR
Oddometer: 4,328
JK
maybe
no JK
What are ya doin now,carb cleanin
B
Old 03-12-2010, 05:14 PM   #15073
FatherX
eXiled
FatherX's Avatar
Oddometer: 4,986
B
u?
Old 03-12-2010, 05:18 PM   #15074
techforlife
CDI REPAIR
Oddometer: 4,328
u?
Nope,,i did that last night
I`m just "chillin"
B
Old 03-12-2010, 05:23 PM   #15075
techforlife
CDI REPAIR
Oddometer: 4,328
Length looks the same,,,but yours is alot farther out from the case than mine... ...me thinks the mig welder may get to talk to this tomorrow...
EDIT:::
I went out, took a pic of mine the same way,,looks like the MSR is definately different...i wonder how long the tip is on the MSR from the tip,,to the right angle bend????????????????
techforlife screwed with this post 03-12-2010 at 05:56 PM
Times are GMT -7.   It's 10:40 PM.
