Old 03-13-2010, 02:57 PM   #15121
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Originally Posted by SenorPeligro
Thanks techforlife. So... since I installed FMF Q4 pipe, I've been getting a lot of popping on decel. Before I go up a pilot jet size, it sounds like I should adjust the pilot screw. I understand that more than 3 turns out indicates the need to go up to a bigger jet.
Yup,,sounds about right,,usually a 55 is right for most people,,keeps it arround 2-2.5 turns...what`s in yours ..or do you know..
B
techforlife is offline   Reply With Quote
Old 03-13-2010, 03:01 PM   #15122
SenorPeligro
Proper Naughty
SenorPeligro's Avatar
Oddometer: 1,962
B
mcma111 did me a great turn and did the Dave's mods for me while I watched in awe. 55-158. I think we left the screw at about 2.25. The new pipe did wonders for the running temp. I think I can bring it down a little lower with a richer mixture... the popping suggests it is currently lean (amongst other things).
It's just good clean dirt.
Video Antics
Where am I Riding?
Baja Blitz Yard Sale
SenorPeligro is offline   Reply With Quote
Old 03-13-2010, 03:21 PM   #15123
Bronco Driver
Bronco Driver's Avatar
Oddometer: 175
Xr628l
Originally Posted by mcma111
The XRL crank is actually longer on the left side for the start gear. If you want the XR stroke install a XR rod on a XRL crank.
The XR trans will bolt straight in the XRL
You are correct about the l/h crank length,however ,installing an 600 rod on the L crank doesn't change the stroke.
I just worded it wrong-Must modify the L l/h crank half and mate it to the r/h 600 crank half. Or destroke the L crank.BUT the L crank is way heavier. As is the flywheel.(XRL flywheel weighs 8 lbs!).
To bring the flywheel weight down to 600 weight must remove added weight ring and machine .100" off the outside diameter.
I've done this to my L and it's a much more fun and a happier motor.
2006 XR650R with too much stuff.
Bronco Driver screwed with this post 03-17-2010 at 10:31 AM
Bronco Driver is offline   Reply With Quote
Old 03-13-2010, 03:44 PM   #15124
mx760
mx760's Avatar
Oddometer: 158
Picked up the fram from powder coating
Picked the frame up this week started to put it back together. The is just the bare fram had some reinforcments welded on. found out what Wattner was talking about the b battery support will not bolt on now have to come up with a creative solution.
mx760 is offline   Reply With Quote
Old 03-13-2010, 03:50 PM   #15125
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
well that makes me feel a bit better
Originally Posted by miweber929
I ran my XR250 once with about a cup of oil in it; not a huge deal after all the freaking I did about it but it DEFINITLEY isn't right.
Mike
Well I'm keeping my fingers crossed on the oil issue...
on to more great news... I think my CDI just crapped out. Bike just stopped running. Idling good and, stop, cranks fine, won't start.
This is starting out to be a great season... Anyone have an extra working CDI I could put a deposit on to see if it cures it. I'll return it to you when I'm done. I'm just thinking this could be an easy way to check the cdi without buying a new one.
just a thought
after thought here... I better make sure it has enough gas it should.
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 03-13-2010, 04:14 PM   #15126
techforlife
CDI REPAIR
Oddometer: 4,329
just a thought
You can also send it too me,i can rebuild it and test it....for free...your call..jcomptu has 3 on the way back to him...
B
Old 03-13-2010, 04:54 PM   #15127
Wattner
Wattner's Avatar
Oddometer: 5,359
SWEET!!!! Those look 2010!
I am in Orlando if you can get out for a ride and/or A beer...
Wattner is online now   Reply With Quote
Old 03-13-2010, 05:40 PM   #15128
HeadTrauma
\_(ツ)_/
HeadTrauma's Avatar
Oddometer: 1,260
I just worded it wrong-Must modify the L l/h crank half and mate it to the r/h 600 crank half. Or destroke the L crank.BUT the L crank is way heavier. As is the flywheel.(XRL flywheel weigs 8 lbs!).
Something else you could do is try to find the crankshaft from a mid '80s XL600LM, Paris-Dakar, or Pharaoh. They have an e-start system just like the 650L, but all the engine specs I find show that they have the XR600's 97x80mm bore x stroke, not the XL600R's 100x75. I don't know if the crank or flywheel is any lighter than the 650L's, though, and those XL variants were never sold in North America....and perhaps not even in the western hemisphere.
BTW, the 650L conrod is 132.25mm center-to-center and the XR600/XL600 rod is 134mm if anyone was wondering. I made a chart of those and other dims available below. Right click -> Save As:
http://img.photobucket.com/albums/v5...ns-printWM.jpg.
It looks like a link to the TT thread was posted some time ago, but here it is again. Big thanks to valverule and stepho over on TT for their help getting measurements. Pictures of the pistons are for visual aid only and do not represent the pin's actual proximity to the oil ring.
Please don't anyone embed the image in another post without hosting it on your own account somewhere. It will load every time that forum page/post accessed and take a big bite out my free Photobucket bandwidth. If my bandwidth allocation runs out, it kills access to all my linked images until the monthly "billing period" rolls over again. Thanks. If anyone has dims from other pistons, like the HRC XR600 slug, for example, I would like to add them to the chart.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma screwed with this post 03-13-2010 at 05:57 PM
HeadTrauma is offline   Reply With Quote
Old 03-13-2010, 05:57 PM   #15129
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Nice
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 03-13-2010, 06:06 PM   #15130
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Originally Posted by Barron
I'm using the stock one in the air box. If you want to check it out let me know. I guess riding tomorrow is shot but it kinda works out cause I'm going to make some beer instead.
Everybody needs a hobby and some people need two.
-Barron
Yeah, I have to work tomorrow, but I'll check it out one day. You mentioned beer, a buddy at work has got me interested in doing some brewing. He has made some really good stuff, he gave me some pumpkin ale last week.
screamin injin is offline   Reply With Quote
Old 03-13-2010, 06:22 PM   #15131
El Birdo
El Birdo's Avatar
Oddometer: 908
I like the idea of the the lighter smaller battery but since I ride year round I have to keep high CCA for those cold mornings. I looked at doing something similar as what you are talking about with the electronics but in the end it just made more sense to me to put everything in the airbox. That way you lose the steel tube and the box back there plus all of the plastic from the air filter to the carb. As for my side panels, well I got rid of those too. They're in my shed. I made some panels that use the original mounting screws and they have worked out great. I had to trim the panel side of the airbox to make it flush with the panel then install weather stripping to keep it water resistant, and again I have had no issues. I'd post a pic for you but I'm on my ship right now and posting pics just plain ain't possible, but tomorrow I can send you some if want. Just let me know.
-Barron
I'd like to see those pics of your side panels. Post em' here please.
Riding something on two wheels
El Birdo is offline   Reply With Quote
Old 03-13-2010, 06:23 PM   #15132
Grape_Ape
It Feels Good
Grape_Ape's Avatar
Oddometer: 585
Rear Fender and Tail Light Options
I'm looking for options to replace the stock rear fender and tail light assembly on my 2001 XR650L with a slick low profile setup. I'll need a place to mount the license plate also.
Any ideas? Pics?
Thanks.
Grape_Ape is offline   Reply With Quote
Old 03-13-2010, 07:12 PM   #15133
radar69
radar69's Avatar
Oddometer: 18
Any ideas? Pics?
Thanks.
I just replaced the light. Cleans things up quite a bit
radar69 is offline   Reply With Quote
Old 03-13-2010, 07:36 PM   #15134
mcma111
mcma111's Avatar
Oddometer: 12,401
Fender
Any ideas? Pics?
Thanks.
Here ya go...
http://www.4strokes.com/tech/honda/xr650l_rear_fender/
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-13-2010, 07:48 PM   #15135
O Captain My Captain
Modern Day Walter Mitty
O Captain My Captain's Avatar
Oddometer: 505
Any ideas? Pics?
Thanks.
I think the stock fender can still serve you well. See the following thread where I posted pics of my fabbed license plate bracket onto the stock fender after installing a WPS tail light. The plate bracket is very solid. My post is #574
http://www.thumpertalk.com/forum/sho...t=#post7732727
RADAR69, please do tell what that rear rack is.
O Captain My Captain is online now   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
