Old 03-15-2010, 04:55 PM   #15226
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Originally Posted by techforlife
Weren`t you rebuildin an engine John... ...
B
Yeah but my trip to Texas and work have it on the back burner right now. Plus I am painting the outside of my house and wrapping the trim with aluminum this spring. About half done with that. Gotta pay to play.
The shifter was welded to the shaft when I got the motor so I have been lurking around trying to pick up a used shaft. New they are about $65. Trying to keep costs under control. I have managed to find a lot of what I need by being patient and I think I have found a shaft. I can afford to wait since the motor is a spare.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 03-15-2010, 04:56 PM   #15227
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,329
Originally Posted by Ben99r1
Ruben. I have a spare carb with a cracked body. But all the parts inside are good. So If you want a stock needle and stock spring? Pm me and will work something out. Ben
+1 on that Ben.........if you guys can work something out Ruben can go back to a stock carb,,and just rejet,drill the slide(already done) and stock needle so anyone helping you diagnose will know that he has a well tested modded carb..Dave`s Mod carb is well tested and known to perform well under most conditions/see level altitude..........
B
techforlife is offline   Reply With Quote
Old 03-15-2010, 04:58 PM   #15228
techforlife
CDI REPAIR
Oddometer: 4,329
John
Cool...good plan......a man in a rush pays the piper.a little patience saves big bucks...
B
Old 03-15-2010, 04:59 PM   #15229
ShooterDave
Oddometer: 1,381
She lives. I got the '02 bike off the stand today and started her up. She still has a lot to add to her, she doesnt even have a chain yet. But my questions is: I added header wrap and is there some kind of spray i need to spray it with? I started up the bike and the stuff smoked, also it was very hot to the touch. Isnt it supposed to be cool to the touch? Is there a break in period?
My Lower 48+ ride on my XR650L - http://www.advrider.com/forums/showthread.php?t=565350
ShooterDave is offline   Reply With Quote
Old 03-15-2010, 05:04 PM   #15230
techforlife
CDI REPAIR
Oddometer: 4,329
It will be hot,but nowhere near as hot as if you put your hand on the steel pipe..i never bothered with the stuff so no idea on a spray??????????..i think the shield,,or buyin the FMF shield is a longer lasting lasting idea.i`ve heard of the tape trapping in moisture and rustin the pipe..mine didn`t need more rust
B
Old 03-15-2010, 05:07 PM   #15231
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
Originally Posted by jasonkop
you're missing my point. I was just hoping I could buy the filter rather than piling up aluminum cages that end up getting recycled. Should it rot in a year or two? I have no clue how long is a reasonable time to expect it to last if it's washed/oiled regularly.
Also, I fired up the bike with the new CDI and the new coil (separate tests) and it's still bogging down. I'm gonna put the new jets in when they get here and if that doesn't do it I'm not sure what to do next.
Could post some pics of your carb???????? with it on the bike,,,, wondering if its the hoses routed wrong??????????
08 XR650L
Billet Aluminum Xr Oil Cooler http://advrider.com/forums/showthread.php?t=578914
If your ever caught traveling back in time,,,and meet someone traveling forward in time,,, it's best not to make eye contact,,,, just saying...
vanpelt999 is offline   Reply With Quote
Old 03-15-2010, 05:07 PM   #15232
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,118
Originally Posted by screamin injin
That what she said
if she is coherent enough to talk then.....
what? Wrenching isn't my thing.
I love these goofy bikes and their "let's go make coffee some place stupid, instead of, a stupid place to buy coffee" mentalities.
FatherX is online now   Reply With Quote
Old 03-15-2010, 05:10 PM   #15233
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,118
Originally Posted by mcma111
Pop's,
Since the Phoenix has risen AGAIN (thought they only rose once) how about getting back to your other thread?
Sooon man. All of a sudden I have work and Prep for summer classes is gearing up.
I'll get into it again. Thanks for the push.
Can't believe you sold my Duc
Old 03-15-2010, 05:11 PM   #15234
ShooterDave
Oddometer: 1,381
B
Should there be more then 1 layer. Ive heard that too, but i know with the heat it gives off it will be dry in no time.
Old 03-15-2010, 05:17 PM   #15235
techforlife
CDI REPAIR
Oddometer: 4,329
Overlapped so you are overlapping about 1/2 way on each layer is what i`ve seen..but i don`t see why more wouldn`t be better??????????
B
Old 03-15-2010, 05:20 PM   #15236
jasonkop
jasonkop's Avatar
Oddometer: 205
could be, there aren't any hoses on it? The air cutoff valve has a hose barb but onthing attached to it. The "vac" line is just capped off. Other than that the only other "hose" is the drain for the carb bowl. My bike has the aicv removed. Sound right?
EDITED TO CORRECT STATEMENT
jasonkop screwed with this post 03-15-2010 at 06:03 PM
jasonkop is offline   Reply With Quote
Old 03-15-2010, 05:28 PM   #15237
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,118
could be, there aren't any hoses on it? The accelerator pump has a hose barb but onthing attached to it. The "vac" line is just capped off. Other than that the only other "hose" is the drain for the carb bowl. My bike has the aicv removed. Sound right?
I know my bike is NOT the model
but
I don't have a "capped off" line of any sort???
Old 03-15-2010, 05:40 PM   #15238
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,118
Laugh Hey Hey Hey
This just cracked me up
Old 03-15-2010, 05:45 PM   #15239
FatherX
eXiled
FatherX's Avatar
Oddometer: 5,118
Jay
I've been doing some hunting and it sounds like another guy was having this issue do to a bad vacum line or a slide assist ??
Don't know anything about either but the symptoms sound the same.
I'll keep looking
FatherX screwed with this post 03-15-2010 at 06:32 PM
Old 03-15-2010, 05:53 PM   #15240
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,192
B
I've always wondered what the purpose of the wrap is ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Times are GMT -7.   It's 06:54 AM.
